zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Some Sharing Regarding Rinnai RB2CG
Rinnai gas cooktop (see PIC 1) incorporates recessed, inner-flame burners into a Schott Ceran glass-ceramic panel to create an appliance that provides high-performance cooking capabilities with convenience and an easy-to-clean surface. A vortex of flame (See PIC 2) is created by angling the burner ports on the horizontal plane. The swirling flame aids combustion by helping to draw air. The unique flame also assists in distributing heat evenly across the bottom of the pan.
Inner-flame burner improves heat transfer efficiency.
Cutaway view of Rinnai’s inner-flame burner shows how the individual flames coalesce and rise toward the center. When the cone of flame hits the bottom of a pan, it flows outward across the bottom to ensure even heat distribution and efficient heat transfer.
o o o
Appliance-maker Rinnai Corp., Nagoya, Japan, has turned burner design completely around with its inner-flame burner. Instead of shooting flames outward from the burner perimeter, as with a conventional burner, Rinnai’s inner-flame burner is ported so that flames shoot inward toward the center.
The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan.
In addition to aiming the ports inward, two other design factors assist in shaping the flame. One is that the burner sits slightly below the surface of the cooktop, helping the individual flames to coalesce toward the center as they rise through a hole in the cooktop surface. Secondly, and more importantly, the burner ports are angled slightly on the horizontal plane. (See top view in lower photo.)
The effect of the flames shooting out an angle is to create a fiery vortex. The swirling flame is meant to accomplish two things. One, it assists in driving the flame outward across the bottom of the pan, helping to evenly bathe the pan bottom with flame. Two, the vortex creates a pressure drop that assists in drawing air in for combustion.
The large version of the inner-flame burner has 24 ports and delivers a maximum output of 15,872 BTUs/hr. The burners are lit by direct-spark ignition.
Rinnai originally intended the inner-flame burner to be installed into a metal panel cooktop. Instead, Rinnai began working with Schott Corp. to find a way to implement the novel burner into a Ceran surface panel.
Schott’s technical support staff worked closely with Rinnai to address a number of issues. One of the biggest was concern over how to protect the burner and other
components from spills going down the hole. Another big concern was protecting the Ceran from direct exposure to excessive heat. Schott’s engineers devised a special burner sleeve to solve these potential problems. Schott also assisted with the design of the cooktop’s framing and a ventilation grid in the cooktop which serves two purposes: one, to provide primary air supply for the burners and, two, to vent exhaust from a fish griller beneath the cooktop.
Rinnai incorporated many of Schott’s design ideas in the final production model of the appliance.
The result was a unique appliance that successfully combines a novel, high-performance burner design and a convenient, easy-to-clean cooktop surface.
Schott says that the popularity of Ceran is growing in the Japanese market because the material’s cleanability is a big advantage in a region where cooking methods involve a lot of frying.
Rinnai says the cooktop with the inner-flame burners has been adopted by many Japanese cooking schools because the burner system is amenable to cooking different regional styles of meals, including Japanese, Chinese and French.
PIC 1
Uploaded with ImageShack.us
PIC 2
Rinnai Oven
RBO85ETIX
http://www.rinnai.sg/images/products/product_83_x.pdf
• 8 Functions (Conventional Heating, Delicate
Cook, Upper Heater, Grill, Grill and Fan, Bake,
Defrost, Rotisserie)
• Maximum Temperature: 250°C
• Cool-Touch Door
• Mechanical Turn-Knob Control
• Digital timer with auto end cook function
• Cooling Fan
• Catalytic Liners (2 sides & 1 rear)
• With Rotisserie
Thanks
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
20sets only!
Rinnai Hob - RB-7502D-GBSM * NEW Model
2 Burner Glass Hob
Cast Iron Pan Support with Safety Devices
Cut out size (mm): (W) 650 - 735 x (D) 350 - 421
Angle: R50
Product Dimensions (mm) : (W) 780 x (D) 469 x (H) 134
Fujioh Hood - FX900 * Parts from Japan
Oil Suction Rate : 83%
3years warranty
Thanks
Regards,
Jerome
92256638
Edited by zero
Hi Jerome,
Kindly provide me quote for the following items:
1) Ariston Hob PK741RQO GH + Hood SL191 PIX (bundled)
2) Turbo Hob 703VTSC-Col-2 in white + Hood TSL-90 (bundled)
3) Hitachi Steam Microwave Oven MRO-AV200E
Thank you
Dare To Compare Cheapest BRANDED Hob & Hood & Instant Heater
Rinnai Hob - RB2CG * Made in Japan
Fujioh Hood - FX900 *Parts from Japan
707 Compact Heater * Copper Tank
Price : SMS / Email * Money Back Guarantee
*Strictly for purchase made between 20/4/13 to 31/5/13.
Thank you
Regards,
Jerome
92256638
Edited by zero
To add on, may I also know how many years warranty do the washing machines come with, and is there extended warranty to buy?
Thanks!
  On 4/16/2013 at 3:49 PM, absolutjo said:
Appreciate if you can provide me quotes, with delivery, for the below:
1. LG WFT8061DD
2. Hitachi SF95PJS
3. Hitachi SF85PJS
And also, may I know where is your physical shop location so that I can go down to have a look.
Thanks!
1. LG WFT8061DD
2. Hitachi SF95PJS
3. Hitachi SF85PJS
Thanks!
Can give me quotes for the following?
Aerogaz AZ-383TRC
Cornell 22L Electric Oven CCO22GY
TAIYO ELECTRIC OVEN (28L) TE38S
Mistral Oven MO200C
Or if you have any other suggestion? Just want a convention and temperature that goes below 100.
Thanks alot!
I am looking for Hob and Hood for daily cooking.
Hob Looking for 3 stove and for hood looking at slim and flat hood.. not chimney hood
Any recommendations of brand? Please me the price too.
Thanks
Edited by elfto
Italian Brand Sink and Tap!
Sink
Description
1 Bowl (Undermount)
Dimension
L758 x W459 x D228 mm
Bowl Size
L705 x W405 x D228 mm
Complete with 3½" waste fittings only
Anti-frost coating & Anti-noise pad
1.2 mm thickness
Tap
Type of product: Sink cold tap
Cartridge body: 40mm
Water efficiency: 2 ticks (Very good)
Water consumption: 4.30 litres/min
Registration Nos: SKT/BT-2010/005770
Package : $275
Thanks
Regards,
Jerome
92256638
Edited by zero
Fanco Fan !
Life Time Motor Warranty!
Best for all BTO Living room. 54inch.
Model : FF707
Comes with Remote control!
Price :$270
THanks
Regards,
Jerome
92256638
  On 3/3/2013 at 2:09 PM, zero said:
Branded HOB, HOOD, HEATER Deal!!!
BUY RINNAI HOB AND HOOD, FREE 707 INSTANT HEATER!
Worth Stocks lasts!!!
Rinnai 2 Burner Hob
Rinnai Cooker Hood
FREE
707 COMPACT
PRICE : $699
THANKS
Regards,
Jerome
92256638
Hi Jerome,
Can I know what model is this Rinnai hob & hood? Is the promotion still ongoing?
Can you also give me the quotation for Brandt Microwave oven - ME655XG and ME1055X
Thank you.
Edited by jojojo0209
