zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Hi Jerome,
Can you pm me a quote for the following fridges? Thanks in advance.
Panasonic NR-BY602XS
Samsung RT5582BTBWW
Samsung RT5982BTBSL
Appreciate it.
Regards
  On 9/25/2013 at 5:10 AM, zero said:
Some Sharing Regarding Rinnai RB2CG
Rinnai gas cooktop (see PIC 1) incorporates recessed, inner-flame burners into a Schott Ceran glass-ceramic panel to create an appliance that provides high-performance cooking capabilities with convenience and an easy-to-clean surface. A vortex of flame (See PIC 2) is created by angling the burner ports on the horizontal plane. The swirling flame aids combustion by helping to draw air. The unique flame also assists in distributing heat evenly across the bottom of the pan.
Inner-flame burner improves heat transfer efficiency.
Cutaway view of Rinnai’s inner-flame burner shows how the individual flames coalesce and rise toward the center. When the cone of flame hits the bottom of a pan, it flows outward across the bottom to ensure even heat distribution and efficient heat transfer.
o o o
Appliance-maker Rinnai Corp., Nagoya, Japan, has turned burner design completely around with its inner-flame burner. Instead of shooting flames outward from the burner perimeter, as with a conventional burner, Rinnai’s inner-flame burner is ported so that flames shoot inward toward the center.
The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan.
In addition to aiming the ports inward, two other design factors assist in shaping the flame. One is that the burner sits slightly below the surface of the cooktop, helping the individual flames to coalesce toward the center as they rise through a hole in the cooktop surface. Secondly, and more importantly, the burner ports are angled slightly on the horizontal plane. (See top view in lower photo.)
The effect of the flames shooting out an angle is to create a fiery vortex. The swirling flame is meant to accomplish two things. One, it assists in driving the flame outward across the bottom of the pan, helping to evenly bathe the pan bottom with flame. Two, the vortex creates a pressure drop that assists in drawing air in for combustion.
The large version of the inner-flame burner has 24 ports and delivers a maximum output of 15,872 BTUs/hr. The burners are lit by direct-spark ignition.
Rinnai originally intended the inner-flame burner to be installed into a metal panel cooktop. Instead, Rinnai began working with Schott Corp. to find a way to implement the novel burner into a Ceran surface panel.
Schott’s technical support staff worked closely with Rinnai to address a number of issues. One of the biggest was concern over how to protect the burner and other components from spills going down the hole. Another big concern was protecting the Ceran from direct exposure to excessive heat. Schott’s engineers devised a special burner sleeve to solve these potential problems. Schott also assisted with the design of the cooktop’s framing and a ventilation grid in the cooktop which serves two purposes: one, to provide primary air supply for the burners and, two, to vent exhaust from a fish griller beneath the cooktop.
Rinnai incorporated many of Schott’s design ideas in the final production model of the appliance.
The result was a unique appliance that successfully combines a novel, high-performance burner design and a convenient, easy-to-clean cooktop surface.
Schott says that the popularity of Ceran is growing in the Japanese market because the material’s cleanability is a big advantage in a region where cooking methods involve a lot of frying.
Rinnai says the cooktop with the inner-flame burners has been adopted by many Japanese cooking schools because the burner system is amenable to cooking different regional styles of meals, including Japanese, Chinese and French.
PIC 1
Uploaded with ImageShack.us
PIC 2
Hi jerome, can quote me on the the above, tks
Powerlux Instant Heater : $199 * Free gift (Panasonic) worth $39
Brand : Powerlux SS8
ULTRASLIM SS8 Instant Heater
- 1st and only instant heater equipped with NANO PLATINUM anti bacteria protection technology heating tank that provide a more hygiene and healthier shower and water
- Flexible installation with 3 ways cable entry point
- Smallest chip set that reduce the failure due to moisture exposure
- Smallest and most compact instant heater in the market
- High quality and classical surface finishing with double layers water printing technology that provide high glossy and embedment of texture to match wall paper theme
- Range of colours for different taste preference and design back ground catered for more vibrant and lively concept
- 3 functions hand held shower for different shower experience
- 12 months on site labour and parts warranty from date of purchase; 5 years parts warranty against inner tank leaking and heating element
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Cheapest Instant Rain Shower Heater : $299 * with Free Gift(Panasonic) worth $39
Model : BeeBest S8R
1) INSPIRE S8R Rain Shower Instant Heater
- Real overhead rain shower c/w 1000 X 380mm vertical rod and adjustable ball join 8" overhead shower rose for adequate clearance and adjustable standing position (1st real rain shower in instant heater market )
- Adjustable brackets position to adapt existing shower set to ease installation
- 2 X metal coil with plastic coating flexible hose with both ends conical join that prevent twisting
- Colour matching 5 functions hand held shower for different shower experience
- 3 way function diverter for different water output
- Single control knob operation (local version) for friendly usage especially elderly
- High efficiency Japan made Matsu****a 3.0KW heating element provide optimal heating performance and energy consumption simultaneously
- High quality and modern surface finishing for long lasting appearance - matt black or platinum grey
Thank you.
Regards,
Jerome
92256638
I am interested in getting the following from Samsung:
1. Samsung WF806 (washing machine)
2. Samsung Series 6 F6300 40" (SMART TV)
3. Samsung BD-F6500 (Blue ray smart player)
4. Samsung HW-F450 ( Sound bar)
Thanks
Hi
Pls help to quote on the following (with and without installation). Will need to purchase soon.
1. Whirlpool Built In Oven ALZM654IX
2. Kuche Hood KCW698XL
3. Kuche Hood KCW598X
3. Kuche Hob KGH93SG (Town Gas)
Thanks!
Ed
Hitachi Side by Side French Door RW691FMSX : $1299
Net Capacity 550Litres
Key Highlights
  • Side by Side French Door
  • Minus-Zero Hybrid Cooling System
  • Nano Titanium
  • Front Jet Freezing
  • Net Capacity 550Litres
  • Electronic Control
  • Tempered Glass Shelves
  • Smart and Functional Vegetables Compartment
  • Water Dispenser
  • Auto Ice Maker
  • Available in Glass Black & Glass Sliver
  • 845(W) x 1,800(H) x 715(D),mm
Thank you.
Regards,
Jerome
92256638
o o o
PIC 1
PIC 2
Edited by zero
Can you quote me the following
1) Mitsubishi MR-F51C
2) Mitsubishi MR-F55C
3) Mitsubishi MR-F62C
4) Hitachi R-Z582EMS / R-Z582EMSX
5) Samsung WF806
6) Miele W3370 & T8812C
7) Electrolux EDH3497RDW
8) Bosch WTS86516SG
Thanks
Samsung Washer Cum Dryer WD0804 : $9**
Brand : Samsung
Model : WD0804
Price : $9**
Feature
Fuzzy Logic Control : Yes
Standard Cycle Time : 110min(with bubble)
Express Wash Time : 15 minutes
Jog Dial : Yes
Spin Speed Max : 1,400
Door Lock Display : Yes
Child Lock : Yes
Rinse+Spin :Yes
Baby Care : Yes
Hot/Cold Water : Yes
Eco Bubble™ Technology : Yes
Time Saving : Yes
Intensive :Yes
Ceramic Heater : Yes
Diamond Drum : Yes
Wrinkle Prevent : Yes
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hi Zero,
Please help to quote the following:
1. Ariston HOB (PK 741 RQO IX)
2. Ariston Telescopic HOOD (AH 90IX) Extraction 722m/hr
3. Hitachi 3-Door Fridge RSG37BPS-ST (Stainless steel)
4. Recommend a full function 60cm built-in oven
Thanks.
Hi Jerome,
Can you quote me below:
Rinai - RB-3CG
Rinai - RB-2CG
Fujioh - FX900R
FHD LED TV TH-L32E6s
Hitachi R-ZG481EMS
Hitachi R-WB550P2MS
707 Princeton Heater
any promo for the above?
rdgs
Edited by spidy
Panasonic Fridge NRBK265SNSG : $399
Brand : Panasonic
Model : NRBK265SNSG
Price : $399
Minimize Energy Use. Maximum Space.
Capacity :
• Up to 20% Energy Saving ( MELS
rating: 3 ticks)
• Twin Jumbo Freezer & big vegetable
case
• Anti-bacterial deodorizing Ag clean
• Multi-purpose tray & split tray
Thank you.
Regards,
Jerome
92256638
