zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Toshiba 50L2300 HD LED TV
Description:
  • 50" FHD
  • LED TV
  • REGZA Engine
  • 10-Bit Video Processing
  • Contrast Ratio 12000 : 1
  • AMR 100Hz
  • Football Mode
  • AD Control
  • Spectrum Analyser
  • PC Input
  • Intelligent Backlight Control
  • 3D Y/C Comb Filter
  • Resolution 1920 x 1080
  • USB (28 Video Formats, 4 Audio Formats, 2 Picture Formats)
  • External Hard Disk Compatibility
  • 3D Colour Management
  • Auto Clean
  • Auto Signal Booster
  • Auto View
  • HDMI X 3
  • Narrow Bezel
  • Power Bass Booster.
Price : $1039 *inclusive of free delivery and Wall mounting
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Hitachi Side by Side French Door RW691FMSX : $12**
Net Capacity 550Litres
Key Highlights
  • Side by Side French Door
  • Minus-Zero Hybrid Cooling System
  • Nano Titanium
  • Front Jet Freezing
  • Net Capacity 550Litres
  • Electronic Control
  • Tempered Glass Shelves
  • Smart and Functional Vegetables Compartment
  • Water Dispenser
  • Auto Ice Maker
  • Available in Glass Black & Glass Sliver
  • 845(W) x 1,800(H) x 715(D),mm
Thank you.
Regards,
Jerome
92256638
Why is Rinnai Inner Flame Special??
Rinnai gas cooktop (see PIC 1) incorporates recessed, inner-flame burners into a Schott Ceran glass-ceramic panel to create an appliance that provides high-performance cooking capabilities with convenience and an easy-to-clean surface. A vortex of flame (See PIC 2) is created by angling the burner ports on the horizontal plane. The swirling flame aids combustion by helping to draw air. The unique flame also assists in distributing heat evenly across the bottom of the pan.
Inner-flame burner improves heat transfer efficiency.
Cutaway view of Rinnai’s inner-flame burner shows how the individual flames coalesce and rise toward the center. When the cone of flame hits the bottom of a pan, it flows outward across the bottom to ensure even heat distribution and efficient heat transfer.
o o o
Appliance-maker Rinnai Corp., Nagoya, Japan, has turned burner design completely around with its inner-flame burner. Instead of shooting flames outward from the burner perimeter, as with a conventional burner, Rinnai’s inner-flame burner is ported so that flames shoot inward toward the center.
The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan.
In addition to aiming the ports inward, two other design factors assist in shaping the flame. One is that the burner sits slightly below the surface of the cooktop, helping the individual flames to coalesce toward the center as they rise through a hole in the cooktop surface. Secondly, and more importantly, the burner ports are angled slightly on the horizontal plane. (See top view in lower photo.)
The effect of the flames shooting out an angle is to create a fiery vortex. The swirling flame is meant to accomplish two things. One, it assists in driving the flame outward across the bottom of the pan, helping to evenly bathe the pan bottom with flame. Two, the vortex creates a pressure drop that assists in drawing air in for combustion.
The large version of the inner-flame burner has 24 ports and delivers a maximum output of 15,872 BTUs/hr. The burners are lit by direct-spark ignition.
Rinnai originally intended the inner-flame burner to be installed into a metal panel cooktop. Instead, Rinnai began working with Schott Corp. to find a way to implement the novel burner into a Ceran surface panel.
Schott’s technical support staff worked closely with Rinnai to address a number of issues. One of the biggest was concern over how to protect the burner and other components from spills going down the hole. Another big concern was protecting the Ceran from direct exposure to excessive heat. Schott’s engineers devised a special burner sleeve to solve these potential problems. Schott also assisted with the design of the cooktop’s framing and a ventilation grid in the cooktop which serves two purposes: one, to provide primary air supply for the burners and, two, to vent exhaust from a fish griller beneath the cooktop.
Rinnai incorporated many of Schott’s design ideas in the final production model of the appliance.
The result was a unique appliance that successfully combines a novel, high-performance burner design and a convenient, easy-to-clean cooktop surface.
Schott says that the popularity of Ceran is growing in the Japanese market because the material’s cleanability is a big advantage in a region where cooking methods involve a lot of frying.
Rinnai says the cooktop with the inner-flame burners has been adopted by many Japanese cooking schools because the burner system is amenable to cooking different regional styles of meals, including Japanese, Chinese and French.
PIC 1
PIC 2
Rinnai Inner Flame Made in Japan 3 Burner Hob
Brand : Rinnai
Model : RB3CG - Made in Japan
Price : $9XX * Inclusive of FREE MYSTERY GIFT WORTH $39
* 10SETS ONLY
*ONLY FOR RENOTALK MEMBERS ONLY!
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hitachi Black Glass Fridge RZG451EMS
Brand : Hitachi
Model : RZG451EMS
Price : $830 * Free delivery!
Minus-Zero Hybrid Cooling System & Front Jet Freezing. Net Capacity 365Litres
Key Highlights
•Minus-Zero Hybrid Cooling System
•Nano Titanium Technology
•Net Capacity 365Litres
•Tempered Glass Shelves
•Smart and Functional Vegetable Compartment
•Slided Out Chilled Case
•Front Jet Freezing
•Electronic Control
•Moldproof Door Gasket
•Anti-Baterial Door Panel
•W650mm x H1,695mm x D705mm
Thank you.
Regards,
Jerome
92256638
Edited by zero
Cheapest Ariston Made in Italy Slimline CookerHood SL191PIX
Brand : Ariston
Model : SL191PIX
Price : $359 * Inclusive of FREE Panasonic 1.8L Rice Cooker & FREE!* Happycall® 20cm “Alumite Ceramic” Die Cast Pot worth $159
Specifications:
•90 cm Slimline Hood
•500 m3/hr Extraction Capacity
•3-Speed Setting
•Aluminium Grease Filter
•Light Bulbs: 2 X 40W
Height: 130 mm
Width: 899 mm
Depth: 512.5 mm
Colour: Stainless Steel
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hi Jerome,
Could you quote me the following item:
1. Samsung Frontload washer - WF1804
2. Samsung Frontload washer - WF806
3. Hitachi Fridge - RZ481EMS
Thanks!
Hi Jerome,
Can you quote me on the following item.
1) LG 47LA690T
2) LG 47LA623T
3) Samsung WA90F5S5QWA
4) Samsung RS552NRUA1J
6) PHILIPS AIR FRYER (2.2L)HD9220 (BLACK)
Promotion, while stocks last !
Samsung 46 LED TV
Model : 46F5500
Price : $1145 *inclusive of free delivery and wall mounting.
Features
Samsung’s One Design maximises the viewing experience as well as enhances your home interior. With Dual Core processor, the speed allows you to perform multiple tasks at one go. Also enjoy a greater level of home entertainment realism than ever before with 3D full HD Samsung TV.
The gateway to a revolutionary entertainment experience
Get in right where the action is. Samsung’s Smart Hub creates the best environment for top notch entertainment. With games, apps, videos and music, you will never feel bored. Enjoy great apps from your Samsung Smart TV. And even access photos, videos and clips on all compatible devices like a smart tablet, a PC or a camera.
*screen image picture is a representation and may not reflect actual user interface.
*content, TV services and capabilities may not be available in all region and territories.
Dual Core makes multitasking fast
Dual Core’s faster processing speeds allow you to perform multiple tasks at the same time, such as using an app while downloading another one. It also enables faster web browsing while playing apps or TV programs that you’ve recently opened through the Recent History feature.
Filtering noise for added TV viewing pleaser
Experience crystal-clear programming from your TV with Samsung’s Clean View. By applying Clean View’s auto noise-removal technology, it removes digital and analog noise that is seen on the screen. The Analog Noise Filter enhances the picture quality by deleting visual noise from both air and cable sources. Sit back, relax and watch TV with the best clarity.
Watch Sports in the best way there is
With the Samsung TV, you can watch sports not only at your convenience but also in the best way there is. The Sports Mode allows you to incorporate fantastic features and a shortcut to activate them all at once. Enhance picture and sound for your benefit, replay the game whenever you miss a shot and share the excitement of sports with your friends and family via Social TV.
Thank you.
Regards,
Jerome
92256638
EF HOB - EFH3763
Brand : EF - www.ef.com.sg
Model : EFH3763
Price : $260 * Free 1.8l panasonic rice cooker worth $79 while stock last
- 3 Burners
- * 2 x 3.5KW (Triple Ring)
- * 1 x 1.75KWl
- Cast iron pan support and with safety devices
- Battery Ignition
- Stainless Steel
- Flexible Cut Out Size
- Product Dimension: W780 x D450 mm
- Cut-Out-Dimension: W660-750 x D360-420 mm
Thank you.
Regards,
Jerome
92256638
Edited by zero
Panasonic 2 door Fridge NRBY602XSG : $1150
Brand : Panasonic
Model : NRBY602XSG
Price : $1150 * free delivery & $150 Voucher
NR-BY602
Maximum Savings, Effortlessly.
● Capacity:
● ECONAVI - Intelligent Eco Sensors
● Intelligent Inverter - Energy savings up to 40% (MELS rating: 4 ticks)
● Vitaminsafe & Moisture vegetable case
● Anti-bacterial deodorizing Ag clean
● Surround cooling airflow
Thank you.
Regards,
Jerome
92256638
Edited by zero
Panasonic 7,5kg Top Load Washer NAF75B3
Brand : Panasonic
Model : NAF75B3
Price : $2**I
Eco + Powerful = SMART Washing
• Capacity: 7.5kg
• Industry top level water savings by new Aqua Spin Rinse & Wate Save Course
• Higher Washing Performance with SAZANAMI Drum & Dancing Water Flow
• New convenient washing programme Baby Care course & Fragrance course
• Auto restart function
Thank you.
Regards,
Jerome
92256638
Edited by zero
New model in CAST IRON PAN SUPPORT !
Only available for RENOTALK MEMBERS ONLY!
SMS / Whatsapp / Email now!
Rinnai Inner Flame RB3SI * New!! *In cast iron pan support
Brand : Rinnai
Model : RB3SI
Price : $4XX
Thank you.
Regards,
Jerome
92256638
