zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Do you have Electrolux microwave ?
Model : EMS 2048 X
Rinnai HOB
Inner Flame from Rinnai
Rinnai Inner Flame
Innovation flame technology Japan with patented aluminium air inlet frame provides steadier heat combustion producing the highest heat efficiency while its concentrated point of flame distributes even heat. The perfect flame control for Asian Cooking.
The appliance-maker Rinnai has turned burner design completely around with its inner-flame burner. The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan. Hence, it requires less gas consumption yet heat up the food faster as compared to the normal ordinary burner.
Rinnai's exclusive "Inner Flame"
Powerful & controllable even heat
Higher heat efficiency as compared to normal burners
Perfect simmer control, superb for making soup
Burner Performance Comparison Boil 2 litre water
Input: Inner Flame - 3.6kW, Normal Burner - 4.5kW
Heat efficiency: Inner Flame - 403 sec, Normal Burner - 442 sec
Keep Warm Performance: Inner Flame - 142g/h, Normal Burner - 181 g/h
Special Promotion
Rinnai Hob *Made in Japan
Model : RB2CG
Price : $7xx * with free 1.8L Ricecooker!
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Hi Jerome,
Could you recommend me what type of hood is good .. Conventional or chimey .. ? Any recommeneded brand ?
We got comment from friend that conventional hood is not very useful. We are looking for a hood that is not so noisy and average extraction.
Any recommend for living room ceiling fan ? we will install L box **** room and we do not need a fan that has light.
Could you quote me for these item ...
Thanks.
can u pm me the price for following items pls ?
Oven HBN331E2J Bosch
Wine chillers KTW18V80 Bosch
Hob EHS935 Elba
Hood EBCH201/90-HM Elba
Fridge RSH5SUSL Samsung (stainless looking)
Hi, pls quote me the price of 707 protek instant water heater, Fujioh Conventional cooker hood FS890 and KDK ceiling fan R48SP and Rinnai Stainless Steel -3 burners RB3SI
Hi All,
All Pmed cleared.
Kindly Email / SMS for fast response.
Thank you.
Regards,
Jerome
92256638
Hi Jerome,
Pls quote me for the following items:
FUJIOH Conventional Cooker Hood FS 890
Fujioh 3773 SVGL Glass Hob
Fujioh FBO-78SS Oven
Thank you.
Rinnai HOB
Rinnai Inner Flame
Special Promotion
Model : RB2CG
Thank you.
Regards,
Jerome
92256638
Model : EMS 2048 X
Rinnai HOB
Rinnai Inner Flame
Special Promotion
Model : RB2CG
Thank you.
Regards,
Jerome
92256638
Exclusive Promotion for March 2014
Hob + Hood + Oven Promotion
Rinnai 2Burner Glass Hob
Model : RB29FV
Powerful Flame
Two Burner Built-in Hob
Black Schott Glass
Dimension (mm): 752(W) x 454(D) x 200(H)
Cut-out (mm): 670-710 x 350-410
Rinnai Conventional Hood
Model : RH90ER
515m3/hr extraction capacity
Light bulb: 1 x 40w
Overall Dimension (mm): 900(W) X 530(D) X 150(H)
Colour: Metallic silver, grey, stainless grey
Rinnai Built In Oven
Model : RBO5CSI *Made in Italy
Size: 594(W) x 535(D) x 594(H)
Capacity: 61 L
Power Consumption: 2.3 Kw/h
Cooking Functions:
- Basic functions
- Light
- Lower element
- Conventional top & lower elements
- Grill element
Colour: Stainless steel
Features:
- Bigger capacity
- Finger print proof
- Removable double glass door
- Buzzer timer
Temperature Setting: 0 - 250C
Package Deal : $999 only
Thank you.
Regards,
Jerome
92256638
Dyson Bladeless Fan AM02
Brand : Dyson
Model :AM02
Price : $568
AM02 Tower Fan
Dyson AM02 White/Silver is a bladeless tower fan that uses Air Multiplier™ technology to generate smooth, uninterrupted airflow wit no unpleasant buffeting.
Thank you.
Regards,
Jerome
92256638
How much the Rinnai RB-29FV(B), RB-29FVSV(B) and RH-90ERi
KDK ceiling fan v60 and r60. Can advice which better for hdb.
Thank you
Edited by smiley73
Samsung Vacuum Cleaner
Model : VC21F50
Price : $289 * Free delivery islandwide
Extreme power for perfect cleaning
• 2,100W Power, 450W Suction Power
• 2.0L Dust Capacity
• Twin Chamber System™
• Noise Level 79dBA
http://www.samsung.com/sg/consumer/home-appliances/vacuum-cleaner/bagless-type/VC21F50VNAR/SP
Thank you.
Regards,
Jerome
92256638
Brand new! Hitachi R-S700P2MS Side by Side Fridge ($1999) + Hitachi RZ-VM18Y Rice Cooker (Worth $219) + Direct delivery from Audio House (delivery can hold until April/May).
Letting go at $1600.
I purchase a fridge from audio house few months back and im forfeiting my flat. Anyone interested?
My contact no 83689820
Description:
Net Capacity 605Litres
4 NEA Ticks
Inverter Control : Inverter Compressor
Dual-Fan Cooling
Eco-Thermo Sensor
Touch Screen Control Panel
LED Light
Nano Titanium
Tempered Glass
Glass Black / Silver
920(W) x 1,775(H) x 765(D),mm (With Handle)
920(W) x 1,775(H) x 720(D),mm (Without Handle)
Edited by el081260
Clearance Price!
Brand : Electrolux
Model : EGT9437
Price : $489 * free delivery.
FEATURES
90cm Extra Spacious Hobs
TECHNICAL
Cook-Top: Safety Glass in Digital Black
No. of Gas Burners/ Zones: 3
Variety of Burner Sizes: Yes
Wok, 4.3kW: Yes
Mid, 1.6W : Yes
Spacious Burner Layout: Yes
Easy Clean Sealed Burner: Yes
Stable Cast Iron Trivet: Yes
Dual Valve Precise Control: Yes
Safety Flame Device: Yes
One-Step Ignition: Yes
Product [W x D] (mm): 894 x 500
Built-In [W x H x D] (mm): 832 x 65 x 470
Thank you.
Regards,
Jerome
92256638
Edited by zero
