zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
MADE IN JAPAN FRIDGE PROMOTION! BUY 1 GET 3 FREE! YES ONLY Available HERE! RELIABLE SELLER !
Brand : Panasonic
Model : NR-C37BMH-S6
Price : $$$$ + FREE Panasonic Microwave NN-SM332M worth $99 + Free Panasonic Vacuum MC-CG520 worth $199
Body Type Bottom-Freezer (3 door)
Total Capacity 301 L (nett)
Dimensions 590 x 633 x 1798
Energy Consumption 489 kWh/year
Eco-friendly Certification(s) 3 Ticks
Eco-friendly Features ECONAVI
Auto Defrost Quick Freezing
Available Colours Shining Silver
Material(s) Non-CFC
Internal Shelves Tempered Glass
Internal Bins Chilled case
Health Features Ag Clean Filter For Hygiene
Control Panel Advanced Design With Door Control
Interior Lighting Features Maintainenance -Free LED Lighting
Languages Supported (OSD/Menu) English
Packaging Weight 68
Warranty 1) Parts, Labour and Transport Warranty - 1 Year. 2) Motor Warranty Only - 12 Years (1+11)
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Good Deals always here!
PHILIPS GARMENT STEAMERS GC525/05
Model : GC525/05
Price : $139 * FREE delivery
Description
QuickTouch
1500W, 35g/min continuous steam with 2 steam settings, 1L water
tank, heat up in 90 seconds, heat resistant glove, detachable hanger,
compact design
Quick crease removal
• Powerful continuous steam
Safe on all garments
• Safe to use on delicate fabrics, like silks
Easy handling of garments
• Detachable hanging accessory
Easy to use
• Easy to use
• No ironing board needed
Customize steam level for different garments
• Steam output control
Thank you.
Regards,
Jerome
92256638
Hi Jerome,
Would like a quote for the following
1. Fridge - F&P E522BRXFD4
2. Fridge - Mitsubishi Electric MR-F51E
3. TV - Samsung UA48H5500
4. Washer - Electrolux EWF12732
5. Washer - LG WD1275QDT
Thank you!
Hi, wondering if you can provide a quotation for the following items:
1. Sink - Monic SQM 780
2. Fridge - Fisher and Paykel E402BRE4SA (WHITE)
3. Fridge - Fisher and Paykel E402BRE4W (WHITE)
4. Washing Machine - Fisher and Paykel any front load model about 7~7.5KG
Thanks!
Edited by ifatfat
NO STOCK ISLAND WIDE??
DONT WORRY! READY STOCK AVAILABLE HERE!
LG 2door Fridge
Brand : LG
Model : GRM562GSH
Price : $7??
Clean Fresh Air In Your Fridge All Day Long
423L STAINLESS STEEL VCM TOP FREEZER FRIDGE
  • HIGH EFFICIENCY COMPRESSOR (4 TICKS)
  • HYGIENE FRESH
  • DOOR COOLING
  • FRESH O ZONE
Features
1_USP-HIGH%20EFFICIENCY%20COMPRESSOR.jpgLG Refrigerators saves more than 20% energy consumption thanks to LG High Energy Efficiency Compressor. LG High Efficiency compressor is different from conventional compressors, in which the inner operating system has been improved. As a result, LG High Efficiency compressor has high EER & High cooling capacity.
HYGIENE FRESH
Advanced Hygiene Fresh continues to evolve for your convenience. It's now better than ever with an exclusive fan system, a 4-step filtering system coated with natural ingredients, separate airflow channels and a slimmer design. Make your life healthier and fresher with LG Hygiene Fresh.
FRESH O ZONE
4_USP-FRESH%20O%20ZONE_v3.jpgFresh 0 Zone is a specialized zone for the separated food preservation in optimal temperature range. It has a front cover as an isolated space to maintain lower temperature than other shelves in the fridge compartment. Also, LG Fresh 0 Zone has minimal temperature fluctuation to keep your food fresher and longer.
THE BIOSHIELD™ ADVANTAGE 5_USP-BIOSHIELD_v3.jpgBioshield™
The door seals of the refrigerator are treated with anti-microbial agent to prevent the growth of mould which can distort the seal of your refrigerator. The doors can then be tightly closed at all times with no cold air seeping out to maintain coldness, thus saving energy.
The Bioshield™ Advantage
Mould thrives in damp environments, making a refrigerator the perfect home for it to flourish—especially over the course of five, ten, even fifteen years. That’s why all LG refrigerator gaskets are treated with Bioshield™, a proprietary anti-microbial agent that prevents mould growth from causing gasket and seal distortion, thereby prolonging the life of your refrigerator.
PEACE OF MIND
10%20Year%20Warranty_INVERTER%20COMPRESSWhen you buy a refrigerator, you don't want to worry that it won't last. Because the Inverter Compressor motor uses fewer moving parts and operates more efficiently, LG confidently backs the Inverter Compressor with a 10-year limited warranty.
Thank you.
Regards,
Jerome
92256638
Lg 7Kg Front Load Washer
Model : WD1270
Price : $4XX
Description:
Body Type: Front Load Washer
Total Capacity: 7.0kg
Spin Speed: 1200rpm
Stackable: Yes
Dimensions: 600x850x550
Drum and Interior Finish: Stainless-steelÿ
Eco-friendly Certification(s): 3 Ticks WM-2013/012989
Eco-friendly Feature(s): 8.60 litres/kg CottonEco60+int
Available Colours: White
Screen Technology: LED display
Wash Cycle Modes: Cotton, Cotton Eco, Easy Care, Duvet
: Baby Care, Delicate, Wool
: Quick30, Rinse+Spin
Height with Lid Open: NA
Control Panel: LED
Automatic Temperature Control: Yes
Timers: Available
Dispensers: Detergent, Bleach, Softener
Health Features: Medic Rinse
Water Efficiency: 8.60 litres/kg
Noise Reduction: Inverter Direct Drive
Vibration Reduction: Inverter Direct Drive
Safety Features: Child lock
Indicators: Door Indicator, Inlet, Outlet, Water, Load
Languages Supported (OSD/Menu): NA
Quick Menu Options: NA
Power Supply: 220-240V/50Hz
Weight: 66kg
Included Accessories: NA
: NA
Optional Accessories: NA
Thank you.
Regards,
Jerome
92256638
Hi, can you please quote me the following Fisher and Paykel dishwasher? DD60SCX7
Do you provide installation service for this?
Thanks
Teo
Designer Ceiling Fan
**Comes with LED Light, Remote
Features:
  • 3 ABS Blade
  • Ultra Silent Motor
  • Remote Control
  • Day / Warm / Cool White
  • 100% Wind Assured
  • Energy Saving
  • Life-Time Warranty (Motor Only)
Specifications:
  • Motor: Super 188
  • Speed: High / Med / Low
  • LED Watt: 18W
LG Washer deals!! * Limited Sets only!
Brand : LG
Model : WD1480TDT
Price : $730
COMMON SPEC
  • Washing Machine Type
  • Detail W/M Type
  • Front Loader
  • Inverter Direct Drive 6 Motion Washer
GENERAL FEATURES
  • Color : Blue White
  • Variable Spin Speed : 1400/800/400/No Spin
  • Variable temperature : Cold/30/40/60/95
  • Voltage[V]
  • Tub material : Stainless Steel
SPECIAL FEATURES
  • Inverter Direct Drive™ Motor
  • Standby power zero
  • Intelligent Washing System
  • Auto Balancing System
  • Foam sensor & removal
  • Load detect
PERFORMANCE
  • Energy efficiency class: A+++
  • Water Efficiency: 6.6 litres/kg CottonEco60+Int; 3 Ticks
PROGRAMS
  • Baby Care
  • Cotton
  • Bio Care
  • Cotton Quick
  • Synthetic
  • Delicate
  • Hand Wash/Wool
  • Quick30
  • Bulky
  • Boiling Care
  • Spin
ADDITIONAL PROGRAMS
  • Prewash
  • Rinse Hold
  • Rinse+Spin
  • Medic rinse
  • Intensive
  • Crease Care
  • Tub Clean
  • Favourite
  • Aqua Lock
  • Beeper On/Off
DIMENSION ( WIDTH X DEPTH X HEIGHT, MM )
  • 600 x 550 x 850
Thank you.
Regards,
Jerome
92256638
Edited by zero
DARE TO COMPARE ! SPECIAL PRICE !
Brand : Mitsubishi
Model : MRZ65 * Made in Japan!
Price : $??? * Call / SMS NOW to enquire
Features
REFRIGERATOR
  • Surround Multi Air Flow System
  • Moisturizing Cooling
  • Sliding Chillded Case
    Large Bottle Storage
  • Side Take-out Pocket
  • Change Pocket
  • LED Compartment Light
VEGETABLE ROOM
  • Case Storage
FREEZER / ICE MAKING ROOM
  • Quick Freezing
  • Case Storage
  • Built-in Water Tank
  • UV Automatic Ice Maker
  • Complete Washability
  • Lead-Reduction Filter
VERSA ROOM
  • Soft Freezing
  • Aluminium Tray
  • Supercool Freezing
  • Hot Freezing
  • Frost Guard
  • I-See Sensor
OTHERS
  • 7 Temperture Sensors
  • Individual Temperature Control
  • Inverter
  • Neuro Fuzzy
  • ECO Guide
  • Non-Freon Cooling System
  • Door Alarm
  • Low Noise 14dB
  • Active Vio Deodorizer
Thank you.
Regards,
Jerome
92256638
Samsung Microwave Oven
Model : MC455
Price : $???
Product Features
Easy to use and easier to clean
Ceramic enamel serves up an easy-to-clean, hygienic, and durable interior. The exceptionally smooth inside surface makes it effortless to wipe off grease and oil, and the benefits of the ceramic enamel have been certified by the Hohenstein Institute in Germany, because it inhibits bacteria*. Ceramic enamel is scratch- and rust- resistant and unlike plastic, it doesn’t discolour due to high-cooking temperatures or excessive cleaning.
* Antimicrobial properties are built-in or applied as a coating to inhibit the growth of bacteria that may affect this product. The antimicrobial properties do not protect users or others against bacteria, viruses, germs or other disease organisms. Clean this product thoroughly before and after each use. Read the user manual carefully before cleaning this product.
* Independent 3rd party test was conducted on the antimicrobial enamel in microwave model GS 89F-S. The test was conducted based on the ISO 22196:2007-10 standard.
Sensors help cook your recipes to perfection
Food freshness and oven type — microwave, convection, grill, or a combination — are two factors that can affect a recipe’s cooking time, often leading to guesswork. Samsung’s SmartSensor technology automatically detects the humidity level of your food, and then sets the optimal cooking time and power. So whether you’re roasting a chicken, heating a frozen dinner, or cooking fresh vegetables, dishes come out perfectly, every time.
Open the oven door to more cooking possibilities
Six different modes — Microwave, Grill, Convection, Microwave + Grill, Microwave + Convection, and Grill + Convection — help you get dinner on the table faster without sacrificing flavor or texture. For example, use the Microwave + Convection mode to cook a chicken in less time than a conventional oven, while crisping the skin. The diverse and convenient cooking modes help reduce energy usage too.
Specifications
General Information
  • CMO
  • 1.6 cu.ft (45L capacity)
  • Convection
  • 900 Watts Output Power (Max)
  • 1,550W Power consumption
  • 230V / 50Hz Power Source
  • LED Display Type
  • Tact+2Dials Control Method
  • Handle open type
  • Microwave Turntable
  • 6 Power Level
  • Ceramic Enamel Cavity Interior
General Features
  • Various Cooking Mode available
  • Sheath Grill Heater
  • 99 minutes Cooking Time (Max)
  • 1 Cooking Stages
Regards,
Jerome
92256638
Edited by zero
Hi Zero,
Thanks for your previous quotations. In addition, I would like to check with you the following:
Samsung Side-by-Side Refrigerator RS552NRUA
Zojirushi MICOM IH Rice Cooker NP-HBQ10
Zojirushi MICOM IH Rice Cooker NP-HBQ18
Mistral Tower Fan - MFD-400R (White) - 65W
Tefal Oven Delice OF2731 (White)
Thank you.
Edited by vchen
