zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
LG FRIDGE GRB312SLCL : $538 * FREE DELIVERY! * 5pc only!
NET CAPACITY (ℓ)
Total
254
Freezer
56
Refrigerator
198
DIMENSION (MM)
Product (Width x Height x Depth)
555 x 1665 x 620
GENERAL FEATURES
Internal Micron
Yes
Inverter Compressor
Yes
Bioshield™
Yes
REFRIGERATOR COMPARTMENT
Tall Door Bin
Yes
Big Veggie Box
Yes
LED Light
Yes
Tempered Glass Shelves
Yes
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
LG FRIDGE GTB4801PZ : SPECIAL PRICE
GENERAL FEATURES
Inverter Compressor
Yes
Refrigerant
R600A
Cooling function
Yes
Temperature Control
Yes (Electronic Sensor)
Door Alarm
Yes
Detachable twist icemaket
Yes
Moving Ice Tray
Yes
NET CAPACITY (ℓ)
Total
481
Freezer
129
Refrigerator
352
DIMENSION (MM)
780 X 1720 X 730
GENERAL INTERIOR FEATURE
BioShield™
Yes
FREEZER COMPARTMENT
Tempered Glass
Yes
Door basket (Transparent)
Yes
Refrigerator Shelves
Tempered Glass
Door Basket (Transparent)
Yes
LED Light
Yes
Fruit & Vegetable Box
Yes
Egg Bank
Yes
Humidity Controller
Yes
Tempered Glass
Yes
Edited by zero
LG Washer Cum Dryer WD14A9 @ $1155 *FREE DELIVERY AND STANDARD INSTALLATION!
escription:
  • 9/6KG INVERTER DIRECT DRIVE WASHER DRYER
  • 6 MOTION INVERTER DIRECT DRIVE
  • DIRECT DRIVE MOTOR, 10 YEAR WARRANTY
  • A+++ ENERGY EFFICIENCY
  • LED TOUCH
CAPACITY
Wash Capacity (kg): 9
Dry Capacity (kg): 6
GENERAL FEATURES
Color: Blue White
The material of Wash Tub: STS
Voltage[V]: 220~240V/50Hz
DISPLAY
Display Type: Touch-LED
Time Delay (hour): Up to 19 hours
Error Message Indication/Alarm: Yes
SPECIAL FEATURES
Inverter Direct Drive™ Motor: Yes
Child lock: Yes
PROGRAMS
Dry Only: Yes
Wool: Yes
Mix: Yes
Easy Care: Yes
Skin Care: Yes
Baby Care: Yes
Cotton: Yes
Rinse+Spin: Yes
Hand Wash/Wool: Yes
Quick30: Yes
Duvet (Bulky): Yes
Cotton Eco: Yes
Mix Load: Yes
Sports Wear: Yes
Silent Wash: Yes
Wash+Dry(6kg/6kg): Yes
ADDITIONAL PROGRAMS
Child Lock: Yes
Features
  • LED TOUCH
Just Like Hand Wash
When doing laundry, you might have experienced to see the inner drum always tumbles with monotonous motion through the fabric type is different. Don't you think that washing machine should adopt different movement for each fabric type instead of one single tumble motion for different fabrics? LG's new 6 Motion Technology introduces a new way to care for clothes, similar to hand wash. The Direct Drive Motor precisely controls the action of tub, allowing for up to 6 motions in which the washer combines different combinations of wash motions to selected cycle to ensure perfect clean. It's suitable or all fabric types and cares for your delicate clothes.
10 YEAR WARRANTY - DD MOTOR
LG guarantees 10 years warranty on Inverter Direct Drive Motor due to greater durability and reliability. Terms & condition apply.
ENERGY SAVING
Sensor detects the loading capacity and calculates the exact rpm and braking time for each operation. The accuracy can ensure optimum washing performance. This not only saves your time, but also water and energy.
INVERTER DIRECT DRIVE SYSTEM
By eliminating the belt and pulley in conventional washer motors, LG's Direct Drive System increases the motor's stability and lessens vibrations. This gives Direct Drive increased durability, which translates to lower maintenance costs. The motor is more energy efficient too, so you'll have lighter energy bills.
Thank you.
Regards,
Jerome
92256638
let me try here instead of Email, have not heard from you for a week.
Fisher and Paykel:
DE50F56E (Dryer)
E402BRE4 (Fridge)
HOB:
CG733LWFCTB1 (fisher)
PBD7331SG (Bosch)
hood:
Fujioh FJS-900V
DEE918PSG (bosch)
HC90DCXB1 (fisher)
Can you help to quote for the below:
1. Ellane Hood and Hob set : EH2680 + WG2SV
2. Ellane Hob only : WG2SV
3. Ellane Hood only : EH2680
4. Rinnai Hob only : RB712N (G)
Instant water heater:
1. 707 Compact
2. 707 Protek
3. Aerogaz
Thank you.
Hello Jerome,
Please quote me for:
Panasonic Fridge:
NRBY602XSSG - Stainless Look
LG TV:
LG CURVED OLED TV 55''EC930T
Bosch Hood:
1) DWW09W851B
2) DWB097E50"
LG Washer cum Dryer:
1) WD-14A9RD
2) WD-1628RDS
Thank you!!!
Brand new Electrolux hob and dryer to let go.
Comes w full warranty. I received as gifts.
Dryer EDP2074PDW retailing $900 going for $650
Hob EGG3412/22 retailing $1099 going for $750
Happy to let go at 30% off lowest retail prices you can find.
Can you pls send me quote for the following models:
1. rinnai built in glass hob RB39V(B)
2. Rinnai built in glass hob RB713N(G)
3. rinnai slimline cooker hood RH-S239-SSR
4.fujioh FG3793SVGL
5.Fujioh 3773SVGL
6.Fujioh hood SLM600/700/900
Thanks!
Samsung 2 Door Fridge RT22FAR @ $465 FREE DELIVERY!
Enjoy energy savings, less noise and a 10-year warranty
Unlike conventional compressors, which have just two patterns of start and stop, Samsung’s Digital Inverter Compressor makes 5 different moving cycle based on humidity levels and usage patterns. This helps maintain a more consistent temperature, reduces wear and tear on the compressor for greater durability, and keeps noise to a minimum.
Optimal humidity for longer-lasting freshness
Samsung’s MoistFresh Zone: The smartly designed drawer provides an ideal environment for apples and zucchini alike, so they stay fresher longer. A tight seal prevents moisture from escaping when humidity levels are low, and a vent releases excess moisture when humidity levels are too high.
Conveniently maximise your storage space
The Easy Slide shelf is built on rolling hinges, and pulls out so you can efficiently organise and easily access your food items—and readily see just what you have store in the back.Capacity
  • 234 Total Net
  • 53 Net Freezer
  • 181 Net Refrigerator
  • 243 Total Gross Capacity
  • 60 Freezer Gross Capacity
  • 183 Refrigerator Gross Capacity
Cooling Feature
  • No Frost
  • Physical Specifications
    • 555 x 1,545 x 637mm Net (W x H x D)
    • 1,545mm Net Case Height with Hinge
    • 637mm Net Depth with Door Handle
    • 637mm Net Depth without Door Handle
    • 545mm Net Depth without Door
    • 582 x 1,610 x 683mm Gross Dimension
    • 40 Hft 97 Loading Quantity
    • 48.3kg Net Weight
    • 53kg Gross Weight
Thank you.
Regards,
Jerome
92256638
Homeappliances@hotmail.sg
Made in Japan 6Doors Fridge NRF510GTX6 @ Special Price
Body Type
Multidoor 6 Door
Total Capacity
410 NETT/530 GROSS
Dimensions (W x H x D)
685 x 683 x 1828
Energy Consumption
2 Ticks 464kWh/Year
Eco-friendly Features
ECONAVI INVERTER
Capacity: Freezer
162/85
Capacity: Fresh-Food
368/325
Auto Defrost
YES
Available Colours
Onxy Mirror
Material(s)
tempered glass
Internal Shelves
3 x tempered glass
Health Features
hygieneactive
Ag Clean
Compressor Type
INVERTER
Interior Lighting Features
LED Lights
Temperature Range
minus 3 to 8
Weight
101
Warranty
1 year parts + 11 years compressor
Edited by zero
Hi
Can provide quotation for model below?
1. Samsung 2 dr fridge c/w water dispenser RT38FEAKDSL/SS
2. Samsung top load washer 7.5kg WA75H4400SS
Thanks
