zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Chest Freezer @ $290 FREE DELIVERY!
  • 130 litres
  • Thermostat control at the front for easy access
  • Temperature dial control
  • Complete with lock and key
  • Low energy consumption
  • Recesses door handle
  • Power on light indicator
  • Embossed aluminium inner body
  • Square edge body
  • Accessory - 1 pc basket
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Hi Zero,
Please quote me these products.
LG 55" UB83 4K 3D Smart Led TV
Fujioh FG773SVGL or RB-3SS (GB) or RB-3CG
2DR Samsung Fridge RT38FEAKDSL/SS
Thanks,
Jerome
As for the hob, i am going to replace the old one. Its a Fujioh 3 burner hob.
Sharp 32" LED TV 32LE155 @ $249 * FREE DELIVERY!
WXGA (1366 x 768) Aquos LED Panel
  • Easy Color Adjustment
  • Super Eco Mode
  • HDMI terminal for simpel connection with AV equipment
  • Antenna Booster
Thank you.
Regards,
Jerome
92256638
Any ceiling fan recommend ?
2 x 36"-40" for my bedroom
1 x 40"- 46 for my living room
any hobs and instant heater recommend?
Please pm me?
Thank you
Alfons
LG Fridge GRM562GSH @ VERY SPECIAL PRICE !
HIGH EFFICIENCY COMPRESSOR
LG Refrigerators saves more than 20% energy consumption thanks to LG High Energy Efficiency Compressor. LG High Efficiency compressor is different from conventional compressors, in which the inner operating system has been improved. As a result, LG High Efficiency compressor has high EER & High cooling capacity.
HYGIENE FRESH
Advanced Hygiene Fresh continues to evolve for your convenience. It's now better than ever with an exclusive fan system, a 4-step filtering system coated with natural ingredients, separate airflow channels and a slimmer design. Make your life healthier and fresher with LG Hygiene Fresh.
DOOR COOLING
Door Cooling enables even temperature anywhere inside fridge compartment.
Door Cooling with 3 Way Cooling System makes fridge-temperature even.
FRESH O ZONE
Fresh 0 Zone is a specialized zone for the separated food preservation in optimal temperature range. It has a front cover as an isolated space to maintain lower temperature than other shelves in the fridge compartment. Also, LG Fresh 0 Zone has minimal temperature fluctuation to keep your food fresher and longer.
THE BIOSHIELD™ ADVANTAGE
Bioshield™
The door seals of the refrigerator are treated with anti-microbial agent to prevent the growth of mould which can distort the seal of your refrigerator. The doors can then be tightly closed at all times with no cold air seeping out to maintain coldness, thus saving energy.
The Bioshield™ Advantage
Mould thrives in damp environments, making a refrigerator the perfect home for it to flourish—especially over the course of five, ten, even fifteen years. That’s why all LG refrigerator gaskets are treated with Bioshield™, a proprietary anti-microbial agent that prevents mould growth from causing gasket and seal distortion, thereby prolonging the life of your refrigerator.
10 YEARS WARRANTY ON MOTOR
When you buy a refrigerator, you don't want to worry that it won't last. Because the Inverter Compressor motor uses fewer moving parts and operates more efficiently, LG confidently backs the Inverter Compressor with a 10-year limited warranty.
Thank you.
Regards,
Jerome
92256638
Thank you.
ALL SPECIAL PRICE SOLD. EMAIL / WHATAPPS FOR LASTEST PRICE!
Regards,
Jerome
92256638
Hi please quote for the following
-Joven storage heater 25l and 35l
-LG GNB519PSAZ
-Samsung RL4013
-Panasonic NR-BW465XSSG
-Samsung WA10F5S5QWA 10.5KG
-lg WFT1061DD
-elmark 58" DMD 31, 50" DMD 33
-amasco aeratron 43" and 50" E503 48"
-Artemis fan
Thanks!
Can I get a quotation for the following items:
1) Electrolux induction hob EEH353C
2) LG front load washing machine 7.5KG WD1275QDT
3) Samsung fridge 396L RT38FEAKDSL
4) Bosch built in oven 67L HBN331E2J
5) Fujioh hood SLM-600R and SLM-600V
6) Relite Column Black 52'' fan
7) Crestar idol 40'' fan
8) LG 49 inch TV 49UB850T.ATC
Thank you!
Edited by mydestiny
Panasonic EzyClean Bidet DL-AF15 @ $188
Thank you.
Regards,
Jerome
92256638
Edited by zero
Samsung 8Kg Front Load Washer WW80H5200 @ $799 * FREE DELIVERY!!
Number of Wash Cycles13
Spin Speed1400rpm
Eco-friendly Feature(s) Eco Bubble / Digital Inverter Motor
Screen Technology Metal Skin (G. LED)
Wash Cycle Modes Baby Care, Bedding, Cotton, Daily Wash, Delicates, Eco Drum Clean, Outdoor Care, Quick Wash, Rinse+Spin, Stain Away, Super Eco Wash, Synthetics, Wool
Water Efficiency 3 Ticks, 6.40 litres/kg eCotton 60, WM-2014/014255
Warranty 2 yrs (Parts and labour) / 11yrs (Motor)
Thank you.
Regards,
Jerome
92256638
Edited by zero
9Kg Steam Washer From LG !
PRICE : SPECIAL PRICE!$$
Delicate To Your Clothes, Gentle To Your Hands. 9KG 6 MOTION INVERTER DIRECT DRIVE STEAM WASHER
WD-14A8FDS5
  • 6 MOTION INVERTER DIRECT DRIVE
  • DIRECT DRIVE MOTOR, 10 YEAR WARRANTY
  • TRUE STEAM
  • A+++ ENERGY EFFICIENCY
Thank you.
Regards,
Jerome
92256638
Edited by zero
Your PM is full.
Please quote for
Tecno SR328SV
Tecno TIH280D
Tecno TH968T
Electrolux EEH353C
Electrolux EGG3412CK
Ariston FH511X
Prices with gst?
Specially Designed for ALL BTO FLATS!
BTO Family only!
Rinnai Instant Rainshower Heater REIA330NP @ SPECIAL PRICE ! ** FREE $50 Shopping Vouchers while stocks last!
Electric Instant Water Heater
Rinnai Ore Series Shower Heater, the first illuminating shower heater engineered with 'ore-like' precision, where raw stones are transformed to reveal its true worth, both sleek in design and priceless in look.
The Ore Series
The name of this product range stems from the word Ore, which is the precious mineral harvested for its invaluable worth. While ordinary in its raw form, the right use will harness its true, priceless appearance.
Simple and Elegant
This minimalist design water heater is extremely easy to operate, with only 1 knob to power up the stepless temperature control throughout its entire use. It is encased in a stunningly-designed sleek chassis and decked up in the refined, timeless colours of Moonlight White, Metallic Silver or Piano Black, with a super high-gloss finishing.
LED Illuminated Water Heater
Rinnai is always looking out for you to fulfill all your household needs, in the kitchen and, now, even in your bathroom. The Ore Series water heater is not only truly functional, the beautiful glowing indicators and logo make it easy to understand while further enhancing its elegant design.
Thank you.
Regards,
Jerome
92256638
