zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Sharp Made in Japan Fridge SJFS79V-BK : $25XX
Smart Double French Refrigerators are designed to enhance your kitchen’s interior with its stylish crafted sleek doors. Its “frameless” looks allow it to blend in beautifully with its surroundings, creating a sophisticated look and feel in your entire home. With the shimmering glass exterior finish for the top-end Supreme model, Smart Double French Refrigerators surely complements your lifestyle and makes an elegant addition to your kitchen.
  • Plasmacluster Ion System
    Plasmacluster technology employs positive and negative ions to remove harmful airborne substances (mold spores and bacteria), ensuring the inside of the refrigerator remains sanitized and free of unwanted odours.
  • Hybrid Cooling System
    A cooling fan on top of the unit and an aluminum panel at the rear work in tandem to manage air flow evenly and prevent drying of food due to direct cooling.
  • Ag+ Nano Deodorizer
    Filter with tiny Ag+ deodorizing molecules traps odour molecules carried by the air inside the refrigerator to reduce odours and keep the food fresh.
  • Glass Touch-Control Panel
    A fingertip-operated touch panel provides easy access to the control mode icons such as Plasmacluster function, energy saving, ice making, auto ice tray cleaning, express freezing, child lock, vacation mode, temperature-rise indicator and temperature controls.
  • Automatic Ice-Making System (Clear normal/Clear large/Normal/Large)
    Makes four different styles of ice: Clear normal, Clear large, Normal and Large.
  • Full-Rear Lighting
    48* energy-efficient white LEDs produce a beautiful bright glow, making it easier than ever to find the item you’re looking for.
  • Automatic System Cleaning
  • Energy-Saving Mode
  • Child Lock
  • Door Alarm
  • Vacation Mode
  • Expressing Freezing
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Baron Water Closet W888 @ $2XX ! LIMITED SETS ONLY!
Description
Washdown Water Closet
Slow Moving Seat Cover
Urea Seat Cover - UF05/UF06
SIZE: 150mm, 250mm & 300mm
P-TRAP
Smooth Flushing System
Water-saving
PSB Approval
Geberit Fitting
Thank you.
Regards,
Jerome
92256638
Are you able to quote (Nett) for the following:
1) KDK R60VW Ceiling Fan
2) Bosch Gas Hob Burner PBD7351SG
3) Panasonic Fridge NR-BL347P (Smaller sizes too)
4) Panasonic NA-F90G3 (10kg too)
5) Mitsubishi MXY3A28VA / MSYGE10VA x 3
Thank you
THE DEAL WORTH WAITING FOR!
If the prices are higher from what you seen, we doubled the difference in price!
** Price valid till 30th June 2015 only, Strictly no extension!
Thank you
Regards,
Jerome
92256638
EUROPE MADE SIDE BY SIDE FRIDGE : $1350 * FREE DELIVERY!
** 3years Parts and Labour, 12years Motor.
37071_6043945_7285546391_LO2_20150422_13
Main features
  • Refrigeration Class: Side by Side Fridge Freezer
  • Refrigeration Type: Frost Free
  • Energy Efficiency: Class A+
  • Adjustable front feet: Yes
  • Wheels: Front & Rear
  • Digital Display: Yes
  • Maximum ambient temperature for satisfactory operation: 43°C
  • Door Handles: Thick metal handles
  • Warranty Length: Two year
  • NeoFrost: Yes
  • Minimum ambient temperature required for satisfactory operation: -5°C
Net & Gross Volumes
  • Net Storage fresh food - cu.ft: 13
  • Net Storage fresh food - ltrs: 368
  • Net Storage frozen food - cu.ft: 6.7
  • Net Storage frozen food - ltrs: 190
  • Total Net Volume - cu.ft: 19.7
  • Total Net Volume - ltrs: 558
  • Total Gross Volume - cu.ft 22.4
  • Total Gross Volume - ltrs 635
Dimensions & Weights
  • Product Height (mm): 1790
  • Product width (mm): 910
  • Product depth (mm): 720
  • Carton height (mm): 1897
  • Carton width (mm): 977
  • Carton depth (mm): 776
  • Net Weight (kg): 114
  • Gross Weight (kg): 124
Fridge features
  • No. of Shelves [including salad crisper cover]: 4
  • Active Odour Filter: Yes
  • Active Seal Guard: Yes
  • Interior Light: Yes
  • Chiller Zone Compartment :Yes
  • Chrome wire wine rack: Yes
  • NeoFrost: Yes
  • Quick Cool Option: Yes
  • Shelves Type: Glass
  • Adjustable Shelves: Yes
  • Full Width Bottle Rack: Yes
  • No. of Full Width Commodity Racks: 4
  • Egg Tray: Yes
  • No. of Large Salad crisper: 2
  • Defrosting method: Frost Free
Freezer features
  • Interior light: Yes
  • High temperature warning: Yes
  • No. of Shelves [including drawer cover]: 5
  • Adjustable Thermostat: Yes
  • Double Twist & Serve Ice Cube Tray: Yes
  • Fast Freeze Option: Yes
  • Freezer Drawers: 2
Consumption Values & Other Technical Specification
  • Energy consumption - kWh/Year: 485
  • Freezer Meltdown time (hours): 13
  • Frozen food compartment rating: 4 Star
  • Freezing capacity fresh food (kg /24 hr): 13
  • Operating noise level (dBA): 43
  • Climate class: SN/T
  • Approved to BSEN60335: Yes
Thank You
Regards,
Jerome
92256638
Edited by zero
Beko Made In Europe 8Kg Front Load Inverter Washer WMY 814832 : $780 * FREE DELIVERY
** 3years Parts n Labour, 12years Motor!
37087_6043945_7134142500_LO2_20150220_09
General Features
  • Woolmark Woolmark: Apperal Care (Silver)
  • Water Inlet: Single (cold)
  • Remain Time Display: Yes
  • Product Color: White
  • Ball system: Yes
  • Drum Pattern: AquaWave
  • Side Wall Type: S shape
  • Electronic Type: Digital Display
  • Time Delay: 0-24h
  • Unbalanced Load Control: Yes
  • Durable Heater: Yes
  • Capacity (kg): 8
  • Child Lock: Yes
  • Over Flow Safety: Yes
  • Automatic Water Adjustment System: Yes Bilgi
  • Maximum Spin Speed (rpm): 1400
  • Number of Programs: 16
  • Program-1 Cottons Eco
  • Program-2 Cottons
  • Program-3 Synthetics
  • Program-4 Woollens
  • Program-5 Hand Wash
  • Program-6 BabyProtect+
  • Program-7 Dark Care
  • Program-8 Spin+Drain
  • Program-9 Rinse
  • Program-10 Freshen Up
  • Program-11 Mix 40
  • Program-12 Aqua 40’40˚
  • Program-13 Gentle Care 20
  • Program-14 Hygiene 20°
  • Program-15 Xpress Super Short
  • Program-16 Daily Xpress
  • Auxillary Function -1 Prewash
  • Auxillary Function -2 Quick Wash
  • Auxillary Function -3 Pet Hair Removal
  • Front Door Color Piano: Black
  • Program Knob Ring Color: Gray
  • Electronic Control: Yes
  • Extended motor / Compressor Warranty: 12 Years
  • Program Follower: Yes
  • Variable Spin Selection: Yes
  • Liquid Detergent Drawer: Yes
  • Front Door Decorative Part Color: Gray
  • Drum Volume: 55
  • Drum Material: Stainless Steel
  • Cabinet Depth (cm): 54.0 cm
  • Cabinet Width (cm): 60.0 cm
  • Cabinet Height (cm): 84.0 cm
Thank you.
Regards,
Jerome
92256638
Edited by zero
LG 40" SMART LED TV 40LF630T : $820 * FREE DELIVERY!
11bfe4b5e9005056ae4948.png?_ex=330x330
Key Features
WEBOS 2.0
LG webOS TV is designed is obviously simple, so that it is easier to learn and more fun to use. Now, all you have to do is relax as webOS 2.0 makes the TV experience simpler than before.
FUN SETUP
Let the fun and lovable BeanBird guide you through your setup process. BeanBird delivers stress free personal assistance that's easy and fun. And simply adjust your settings through Quick Setting anytime.
LAUNCHER
You can switch to any app, broadcast, VoD service or connected peripheral without navigated to a dedicated 'home' screen. Instantly find your entertainment right on your Launcher.
LG CONTENT STORE
Your search for new and exciting content is over. Find everything you love about entertainment in LG Content Store, the one-stop-shop for TV programs, VoD, 3D content, apps and more.
INPUT ASSIST
Plug and play on with a helpful pop-up screen that instantly appears when you connect a new device. External devices can also be accessible through the Input Picker found on the right top of Home screen.
SMART SHARE
Instantly access and comfortably navigate your favorite content with Smart Share's all-in-one entertainment hub. Find loads of new ways to share content stored on your smart devices up on the big screen for your friends and family to enjoy.
MAGIC REMOTE
Take control of your entertaiment with a new level of remote control convenience. Controlling your TV is now as easy as using a computer mouse. Now, spend less time searching and more time enjoying.
Thank you.
Regards,
Jerome
92256638
Edited by zero
LG UHD Smart LED TV 55UF770T : $2690 * FREE BLU RAY PLAYER!
111fe4b67a005056ae3fd5.jpg?_ex=330x330
4K RESOLUTION
ULTRA HD resolution is four times that of Full HD for brilliant clarity and deep details that amaze, even when viewed up close.
4K UPSCALER
You can now enjoy 4K in more ways than ever. The 4K Upscaler enhances the details of broadcasts, movies and sports to near 4K quality, giving you picture perfection in new and exciting ways.
ULTRA SLIM
You can now enjoy a bigger 4K screen in a slimmer size. Finally, stunning 4K picture is packed in slim to seamlessly blend in with your home's decor.
ULTRA SURROUND
ULTRA Surround delivers high quality listening that seems to surround you from every direction in rich sound. Now, maximize your 4K viewing experience.
WEBOS 2.0
LG webOS TV is designed to be obviously simple, so that it is easier to learn and more fun to use. Now, all you have to do is relax as webOS 2.0 makes the TV experience simpler than before.
LAUNCHER
You can switch to any app, broadcast, VoD service or connected peripheral without navigating to a dedicated 'home' screen. Instantly, find your entertainment right on your Launcher.
SMARTSHARE
Instantly access and comfortably navigate your favorite content with Smart Share's all-in-one entertainment hub. Find loads of new ways to share content stored on your smart devices up on the big screen for friends and family to enjoy.
MAGIC REMOTE
Take control of your entertainment with a new level of remote control convenience. Controlling your TV is now as easy as using a computer mouse. Now, spend less time searching and more time enjoying.
4K 60P HEVC
HEVC supports 4K video with 60 frames per second delivering clear and blur-free motions. Now you can enjoy 4K quality content via Internet streaming or USB without requiring support from any extra device.
DUAL METAL
Dual Metal is designed to give a modern look to your interior with metallic frame on the top and bottom of the TV.
Thank you.
Regards,
Jerome
92256638
Dear All,
Please Email for faster response.
Thank you.
Regards,
Jerome
92256638
Replied.
Sorry and thank you
Regards,
Jerome
92256638
I had PMed you twice on 15th and 19th may. Still hasn't got your reply yet.
Hi Jerome
Can i have quotes for the following items:
Fujioh FG-2792SV hob
Fujioh SLM-700
Ariston FH51IX
Crestar I-Col ceiling fan
Ariston 30L heater, italian made
Thanks in advance
Samsung 50" UHD LED TV @ $1799
FEATURES
  • A more detailed picture made for UHD resolution
  • UHD upscaling enhances the quality of all of your viewing
  • 4 times the Full HD resolution
  • Future Ready
SPECIFICATIONS:
Display
Screen Size
50"
Resolution
3840 x 2160
Ultra Clear Panel
Yes
Video
Picture Engine
Quadmatic
Clear Motion Rate
200
Dynamic Contrast Ratio
Mega Contrast
Micro Dimming
Micro Dimming Pro
Wide Colour Enhancer (Plus)
Yes
Film Mode
Yes
Natural Mode Support
Yes
Design
Design
T-shape
Bezel Type
NNB
Slim Type
Full Slim 47mm
Front Colour
Black
Stand Type
T-shape
Swivel (Left/Right)
No
Power
Power Supply
AC220-240V 50/60Hz
Power Consumption (Max)
N/A
Power Consumption (Stand-by)
0.5 W
