zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Guest Fadzil Hassan
Hie guys. I plan to get EF hob and hood with oven package. U guys know she to get ard below 1k?
For Special Price, Email now !
17688_909406055786960_897567055626815021
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
KDK 1st DC Fan, T60AW : $450 * FREE DELIVERY! Limited sets only!
  • Ceiling Fan with DC motor, 150cm w/remote control
  • For HDB Apartment/Apartment with Low Ceiling (2.6 metres to 3 metres)
    • Direct current (DC) motor adopted
    • Auto mode with Eco Mode function by temperature sensor
    • 1/f Yuragi function
    • 3D blade delivers smooth and strong air flow
    • PPG blade material for durability
    • LCD wireless remote control
    • 9-speed control
    • Sleep mode with On timer and Off timer
    • Equipped with safety device
    • Blade safety plate and safety wire attached
Thank you.
Regards,
Jerome
92256638
Dear Jerome,
Kindly quote for following
Fridge - Mitsubishi MRF47EG-SLW
Washer - LG WFT1061DD
KDK Fan - V56VK, V60WK, R60VW
Fujioh FX900 Hood and Fujioh / Rinnai 3 burner hod
Thanks in advance,
Edited by eruzaxy
Automatic Laundry System @@ $799 ** FREE Standard Installation -- > 2years warranty
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hi Zero,
I'm new here and I'm keen to know more. Do you have a site where I can view all the items you sell?
In the meantime, can I enquire on the prices of:
1. Fujioh FX900
2. Rinnai hob - do you have any glass top hob with only 1 burner?
3. Brandt built-in oven FC1042XS
Thanks much!
Hi !
can i have your quote for the following item :
Hitachi : R-VG560P3MS
Hitachi : BD-W75TAE
Bosch : HBN331E2J
Beko : DSFN6839
Thank you !
Hi Jerome (zero)
Unable to PM you.
Please can you quote for the following?
1. Fujioh hood: SLM-900R
2. Rinnai hob: RB-3Si
3. Bosch oven: HBG23B550J
Thanks!
Hi Jerome
Can you please provide quotation for following microwave ovens:
Samsung MW5200J (Grill type)
Samsung MC28H5135CK (Convection type)
Thanks
Lim
Bennington Instant Multi Point Heater Z620M @ $2XX
**SPECIALLY DESIGNED FOR BTO!
Q1: What is BENNINGTON IEMWH?
A1: BENNINGTON IEMWH functions like conventional Instant Electric Water Heater. But unlike conventional Instant Electric Water Heater which serves only one point and needs to be installed at the point of use, IEMWH can be installed away from the point of use and capable of connecting to numerous outlets. It is an ideal domestic central water heater that works well with modern houses which come with concealed cold and hot water piping and mixer taps.
Q2: May I know more about the company Bennington Technologies Pte Ltd that manufactures the BENNINGTON Multipoint models?
A2: Bennington Technologies Pte Ltd (herein known as “BT”) was established in 2002 in Singapore and specialized in the manufacturing of Instant Electric Water Heaters, especially IEMWH models which it has been exported worldwide since 2003. Our heaters are sold in more then 10 major countries worldwide. All heaters are manufactured in Singapore using German Technologies and our heaters comply with leading international safety standards such as TÜV, IEC, PSB, CE, CCC and others. As we are a local-based manufacturer, after-sales services support are provided directly by us.
Q3: What are the advantages of BENNINGTON IEMWH compared to other heaters like storage or gas heaters?
A3: Advantages compared to storage heater
1) IEMWH saves up to 30% in electricity as you consume electricity only when you use it. There is no wastage in heating unused water, unlike storage heaters;
2) Instant hot water with no preheating required;
3) You will never run out of hot water, which is a common problem with small capacity storage heaters;
4) Compact and elegant as compared to storage heaters, which are bulky and obstructive in confined bathroom installations;
5) Low maintenance cost as parts can be replaced easily.
About BENNINGTON Z620M
·Z620M is a pressurized electric water heater similar to storage heater and can be used with mixer tape;
· It can be connected to more than one outlet point. For best result, minimum outlets should be used at any one time;
· Its compact size makes it easy to be installed in many different location: above ceiling, wall mounted or below the sink. Most ideal for new BTO HDB flat;
· Economical and no wasting time waiting for hot water. Hot water on demand;
· Z620M is PSB approved and sold worldwide ;
· It requires a 20A heater switch and 2.5mm² copper cable or its equivalent.
Edited by zero
  On 6/18/2015 at 1:43 AM, zero said:
Samsung 60" LED TV 60H6203 @ $1770 *FREE DELIVERY !
Specifications:
  • Resolution: 1;920 x 1;080 (FHD LED TV)
  • Broadcasting: DVB-T2
  • Stay Connected with basic Smart TV
  • More Vibrant Colours
  • AV I/O: HDMI x 2
  • Connectivity: USB Port x 2 / Wi-Fi Built-in
  • Access Movies from External HDD
Thank you.
Regards,
Jerome
92256638
Last 3sets only, PRICE while stock last.
Designer Ceiling Fan 52" comes with original LED Tri Color 18W light + Remote Control @ $409 * FREE $50 CHOICE VOUCHER WHILE STOCKS LAST!
Motor Super 188
Blade Acrylic (ABS)
Housing Metal RPM 140-260 (52”)
Wind Power 3.2m/s
Voltage 220-240V 50Hz
Watt 100W
Remote AC-F6
Thank you.
Regards,
Jerome
92256638
