zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Hi Zero, pls quote me the following:
Rinnai RB2CG (does it include delivery?)
Bosch WAS28448ME washer
Mitsubishi MRF55C fridge (not sure if the model is correct) btw is 4 stars really worth the premium?
Hi Alyssababy,
I have pmed you.
Thanks
Hear from you soon.
Regards,
Jerome
92256638
Back to Popular Demand!!
Rinnai RB2CG
Uploaded with ImageShack.us
CALL / SMS me now to confirm your orders!
LIMITED PERIOD ONLY!
Regards,
Jerome
92256638
Some Sharing Regarding Rinnai RB2CG
Rinnai gas cooktop (see PIC 1) incorporates recessed, inner-flame burners into a Schott Ceran glass-ceramic panel to create an appliance that provides high-performance cooking capabilities with convenience and an easy-to-clean surface. A vortex of flame (See PIC 2) is created by angling the burner ports on the horizontal plane. The swirling flame aids combustion by helping to draw air. The unique flame also assists in distributing heat evenly across the bottom of the pan.
Inner-flame burner improves heat transfer efficiency.
Cutaway view of Rinnai’s inner-flame burner shows how the individual flames coalesce and rise toward the center. When the cone of flame hits the bottom of a pan, it flows outward across the bottom to ensure even heat distribution and efficient heat transfer.
o o o
Appliance-maker Rinnai Corp., Nagoya, Japan, has turned burner design completely around with its inner-flame burner. Instead of shooting flames outward from the burner perimeter, as with a conventional burner, Rinnai’s inner-flame burner is ported so that flames shoot inward toward the center.
The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan.
In addition to aiming the ports inward, two other design factors assist in shaping the flame. One is that the burner sits slightly below the surface of the cooktop, helping the individual flames to coalesce toward the center as they rise through a hole in the cooktop surface. Secondly, and more importantly, the burner ports are angled slightly on the horizontal plane. (See top view in lower photo.)
The effect of the flames shooting out an angle is to create a fiery vortex. The swirling flame is meant to accomplish two things. One, it assists in driving the flame outward across the bottom of the pan, helping to evenly bathe the pan bottom with flame. Two, the vortex creates a pressure drop that assists in drawing air in for combustion.
The large version of the inner-flame burner has 24 ports and delivers a maximum output of 15,872 BTUs/hr. The burners are lit by direct-spark ignition.
Rinnai originally intended the inner-flame burner to be installed into a metal panel cooktop. Instead, Rinnai began working with Schott Corp. to find a way to implement the novel burner into a Ceran surface panel.
Schott’s technical support staff worked closely with Rinnai to address a number of issues. One of the biggest was concern over how to protect the burner and other
components from spills going down the hole. Another big concern was protecting the Ceran from direct exposure to excessive heat. Schott’s engineers devised a special burner sleeve to solve these potential problems. Schott also assisted with the design of the cooktop’s framing and a ventilation grid in the cooktop which serves two purposes: one, to provide primary air supply for the burners and, two, to vent exhaust from a fish griller beneath the cooktop.
Rinnai incorporated many of Schott’s design ideas in the final production model of the appliance.
The result was a unique appliance that successfully combines a novel, high-performance burner design and a convenient, easy-to-clean cooktop surface.
Schott says that the popularity of Ceran is growing in the Japanese market because the material’s cleanability is a big advantage in a region where cooking methods involve a lot of frying.
Rinnai says the cooktop with the inner-flame burners has been adopted by many Japanese cooking schools because the burner system is amenable to cooking different regional styles of meals, including Japanese, Chinese and French.
PIC 1
PIC 2
Rinnai RB2CG
SPECIAL PRICE FOR ALL CONFIRMED SET!!!
Regards,
Jerome
92256638
Edited by zero
Hi
Can you please quote me the following items:
Panasonic Fridge NRBW414NSG
Panasonic Washer NAFS80X1
Thanks
Pmed you.
Thanks
Regards,
Jerome
Hi Zero,
Recommended here by my neighbor, can you quote me on Rinnai RB-3Si bundle with RH-90CD/RH-998C ?
Actually i will def get RB-3Si, but i need a chimney hood with glass to fit my theme. I am light cooker, and don't want to spent too much on hood. If you can recommend, i'll be grateful.
Thanks!
Hi Ps.Hipster,
Ok. Sure. Pmed you
Hope to hear from you soon.
Thanks
Regards,
Jerome
92256638
Hi Zero
Could you quote me for the following items:
- Brandt Induction Hob TI607BU1
- Bosch Induction Hob PIE375N14E
- Bosch Dishwaters SM69T22EU(White)
- Thomson Washer TXSD9813 (Not sure if you carry this)
Thank you
Hi Rosalind,
Pmed you.! Thanks
Regards,
Jerome
92256638
hi jerome,
i would like to check with u wads the individual best price u can offer for...
1) turbo 752vtsc 2burner glass hob
2) turbo ta9688sg chimney hood
3) hobz hg782 2burner glass hob
4) hobz hh6310 ss chimney hood
would like to double cfm if the above 2 hob got inner flame anot? and which would u recommend more n why?
Hi Ashley,
Both brands doesnt come with Inner flame, only Rinnai has inner flame, they have copyright for it. So no other brands has it.
As im unable to pm you, would you drop me a sms or pm me instead? thanks!
Regards,
Jerome
92256638
Hi Zero,
Thanks!
Hi Zero
Thank you
hi jerome,
