zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
  On 3/26/2012 at 4:16 AM, boudicca said:
Hi, Kindly quote me the following fridges:
Hitachi
R-Z481EMS
R-Z451EMS
Samsung
RT59QBSL
Thanks
Have pmed you.
Thank you.
Regards,
Jerome
92256638
  On 3/26/2012 at 6:53 AM, arias48 said:
hi, could you quote me Fujioh FX900 hood? THX U.
Hi Arias,
Have pmed you.
Thank you.
Hope to hear from you soon.
Regards,
Jerome
92256638
  On 3/25/2012 at 1:25 AM, 031212h said:
Hi Zero,
Can you quote me for the package as per the following:
1. Rinnai RB-3CG
2. Rinnai RH-991CT
3. Rinnai RBO-7MSO
Any recommendation for Mitsubishi Refrigerator (Budget at about $1000) and Air-con (Split Unit or System 3) and Price quote too.
Nice promotion too.. Thanks as well.
Regards,
Nian
Hi Nian,
Have pmed you.
Thank you.
Regards,
Jerome
92256638
May I know what's the diff between this model and HBA43B450A? I saw in model in HVN and Im considering. Can you give me your quotation?
  On 3/21/2012 at 5:09 PM, zero said:
Bosch Oven - Made in Germany
Model : HBA23B550J
Product features
Performance
5 Heating method:
- Full width variable grill
- 3D hot air plus
- Top and bottom heat
- Hot air grilling
- Bottom heat
Extra large 67 litre capacity
Energy efficiency class: A-20%
Functions
EcoClean panel rear liner
Features
Rapid heating-up: automatic
Triple glass door
Heating up indicator
Design
Pop-out controls
Electronic clock
Full metal bar handle
Extra large capacity oven with grey enamel
Oven interior light
5 shelf positions
Drop down door
Safety functions
Childproof lock
Maximum window temperature 50° C
Integral cooling fan
Price : ASK NOW
Thank you.
Regards,
Jerome
92256638
Hi Zero,
1. Rinnai RB-3CG
2. Rinnai RH-991CT
3. Rinnai RBO-7MSO
Regards,
Nian
EXTENDED FREE HOB FROM RINNAI!!!
Grab it before its gone!
Buy,
Chimney Hood
Model : RH997CT
The Quintessential Companion to All of Your Cooking Needs
• Ducted / Recirculation Air Operation
• Stainless Steel Finishing with Black Tempered Glass
• 1,000m3/hr Air Flow with 4 Speeds
• Charcoal Filters
• Stainless Steel Buffer Filters
• 4 Speeds LED Sensor Touch Control with Timer
• 2 x 1W LED Lamps
• Product Dimensions: 900(W) x 400(D) x 1,332(H) mm
FREE HOB (Worth $400),
Rinnai
Model : RB3SS(GB)
Powerful Flame
Three Burner Built-in Hob
Black Tempered Scott Glass
Dimension (mm): 870(W) x 510(D)
Cut-out (mm): 725-830 x 435-470 x R110
Price : $950
Pls note this is an exclusive deal.
Worth stock last!
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
Kadeka Wine Chiller
Model : KA39WR
Product Specification:
39 bottles
LCD display control panel
3-layered anti-UV glass door
Stainless steel door frame with handle
Odour filter
Wooden racks
Humidity box
Auto defrost, anti-vibration, lock
Temperature range -7°C to 18°C
Uses R134a Refrigerant in sealed system
220-240 Volts, 50Hz
Dimension: 840H x 490W x 590D mm
Price : $765
Thank you.
Regards,
Jerome
92256638
Stylish Ceiling Fans!
Back to Popular Demands !
Brand : Haiku
Price : $655
Thank you.
Regards,
Jerome
92256638
Homeappliances@hotmail.sg
Edited by zero
For all Induction Lovers!
EF Induction Cooker - Made in Italy
Model : HB BI 580 T ( 15Amp )
Suitable for HDB
Specification:
Induction Hob With Sensor Touch
- 2x1.4KW Induction Zone 160mm Diameter
- 2x2.3KW Induction Zone 200mm Diameter
- 9 Power Setting
- LED Timer And Display For All Zones
- Minute Minder
- Overflow Safety Device
- Child Safety Lock
- Residual Heat Indicator
- Pot Diameter Detector
- Dimension: W580 x D510 mm
- Cut Out Dimension: W560 x D490 mm
Special Price : $1170 * Limited sets
Thank you.
Regards,
Jerome
92256638
  On 3/24/2012 at 8:25 AM, beluga said:
Kudos to Jerome.
Called him today to confirm the delivery as the date is getting close. However, as the model of the hob that I want will only come in early April, it could not meet my carpentry work schedule. So, he will loan me the same model but the LPG type so that I can use it to let the carpenter to cut the hole on the granite top first and at later date, exchange to the correct model again.
He also lowered the price a little for me as it was a little over-quoted by Madam Tan when he was away at the time I ordered.
Hi Beluga,
Thank you for the support.
Will do my best to serve you better. Let me know again if you need any help.
Thankyou
Regards,
Jerome
92256638
  On 3/23/2012 at 5:55 PM, JasmineTan said:
Milliewalker,
I think you are not being fair to Jerome for your harsh comments. How can you comment that he is a cheater when you didnt even lose a single cent? Instead, you appear to me that you specially set up an account to tarnish his reputation (as it could be seen that your account was set up this month and you only posted 4 comments so far and mostly are harsh comments in this thread). If you are a competitor in the same trade, this is so unethical of you.
I have bought afew items from him for my new house and i'm very satisfied with his price and service. Even if I have to pay the same price or a slightly higher price, I will still get it from him due to his good after sales service. Do you think that earning $20 for an item is too much? Doesn't he need to cover fuel and labour cost for delivery? If you were him, will you do it for free? And pls, this is not a discussion thread and you should end your further commments in this thread.
Jerome, don't be too affected. I will recommend my friends to buy from you. There are many customers here who support you and speak up for you. Cheer up :)
Hi Jasmine,
Thank you for the continuous support :)
Appreciate it.
Thank you once again.
Regards,
Jerome
92256638
Kudos to Jerome.
Edited by beluga
