zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Panasonic Inverter Fridge (New Model)
Model : NRBW465XSG
Advanced Inverter Technology
Flexible 6 Level Power for Optimal Cooling
Energy Saving: Reduces energy consumption by 40%*.
Quick Freezing: Freezes food quickly and makes ice 88 minutes faster.
50%* Quieter operation.
Ag Clean: 99.9% of Bacteria Inactivation
Ag ions inactivate 99.9% of bacteria and mould and also a stronger deodorizing effect. As a result, stored food items retain their flavour longer.
The Vegerator
Easy-to-use center position for convenient storage of heavy, space consuming vegetables. This makes items easy to see and take out.
Large vegetable storage capacity (30L Vegetable case)
_____________________________________________________________________________________________________
Panasonic Inverter Washing Machine - Energy saving
Model : NAFS90X1 (9kg Washer)
Eco Drive Inverter
Saves Water A newly developed water flow mechanism assures amazing water saving and outstanding cleaning power.Doing the laundry everyday lets you enjoy huge savings. Saves Energy Advanced Inverter control enables efficient operation without using unnecessary power. And zero power is used during standby. Super Quiet So you can wash clothes at night without disturbing anyone, and when your child&s having a nap.
Jet Water Circulation
The inverter&s powerful drive force is used to rotate the tub itself at high speed and move water up by centrifugal force. Water from two outlets then showers clothes to push detergent deep into fibers. In this way, a little water is used effectively and strongly circulated to powerfully remove dirt and thoroughly clean clothes.
Dancing Pulsator
Thanks to the inverter&s precise power control, quick reverse rotation of the pulsator is possible. Even with just a little water, this generates waves that uniformly agitate clothes.
Premium Hand Wash
While clothes are pressed against the side of the tub by centrifugal force, detergent passes through fabrics to thoroughly remove dirt. And the pulsator doesn&t rotate, so clothes are washed gently with minimal tangling and damage. That&s why you can now clean clothes you couldn&t wash at home before.
Panasonic Microwave oven
Model : NN-CS599S
Information:
4-in-1 Combination (Microwave, Convection, Grill & Steam)
High power 300oC convection results in a crispy surface while high temperature steam heats thoroughly all the way through, removing excess fat without scorching.
Built-in IR (Infrared) Sensor
IR sensor detects the temperature in every part of the food itself and food is cooked evenly to the right temperature.
Flat and Wide Non-turntable
Easy cleaning
Wide interior
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
Samsung Fridge
Model : RT45GEIS
Specification
.Capacity
•Gross Total Capacity: 450 L
•Gross Freezer Capacity: 121 L
•Gross Refrigerator Capacity: 329 L
•Net Total Capacity: 362 L
•Net Freezer Capacity: 98 L
•Net Refrigerator Capacity: 264 L
Loading Quantity
•Loading Quantity (20/40/40Hft): 24 / 48 / 66
Freezer Features
•Twist Icemaker
•1 Freezer Shelf
•Plastic Shelves
•Frosted Door Pocket
Dimension
•Net Width Dimension: 670mm
•Net Case Height Dimension (with hinge): 1,770mm
•Net Case Height Dimension (without hinge): 1,745mm
•Net Depth Dimension (with door handle): 688mm
•Net Depth Dimension (without door handle): 650mm
•Net Depth Dimension (without door): 581mm
•Net Depth Dimension (with refrigerator door open 90°): 1,247mm
•Gross Width Dimension: 717mm
•Gross Height Dimension: 1,872mm
•Gross Depth Dimension: 728mm
Cooling Features
•No frost
Exterior Features
•External Colour: Inox Silver
Weight
•Net Weight: 70kg
•Gross Weight: 79kg
Refrigerator Features
•CoolSelect Zone
•Chill Compartment
•1 Fruit and Vegetable Drawer
•Humidity Controls available
•Glass Cover
•2 Shelves
•Glass Shelves
•5 Door Pockets
•Egg Containers
•Deodorizer
•30Watts x 1 Interior Lighting
Others
•Silver Nano Deodorizer
•R-134a Refrigerant
•Cyclopentane Insulation
Price : $645 * Free delivery
Thank you.
Regards,
Jerome
92256638
  On 4/3/2012 at 9:24 AM, Justgetit said:
Can give me the quote for
1)fujioh FX900
2) fujioh FG 792GL
3) fujioh FG 772 SVGL
4) Samsung RT54QBSL
5) Panasonic Plasma TV 42ST30
Thanks
Have pmed you.
Hope to hear from you soon.
Thank you.
Regards,
Jerome
92256638
  On 4/3/2012 at 6:38 AM, whoogie said:
Hi
Hi Jerome,
Please quote for the following items:
Rinnai RB2CG
Rinnai RB-11G-C
Rinnai RB-11N-C
Rinnai RB-11S-C
Rinnai RH-9020A
Rinnai RH-993CT
if any bundle out of these please do let me know too...
BOSCH Oven HBA43B450A << since they received quite a bit of flak for after sales services, do you have other recommended brand of Oven with similar specs?
thanks.
Have smsed you on the pricing already.
Thank you.
Regards,
Jerome
92256638
Hi
Hi Jerome,
Rinnai RB2CG
Rinnai RB-11G-C
Rinnai RB-11N-C
Rinnai RB-11S-C
Rinnai RH-9020A
Rinnai RH-993CT
thanks.
  On 3/30/2012 at 12:41 PM, zero said:
Hi NeoBY,
Thank you for the purchase, but sorry for the delay today. Delivery was very packed today. Hope for your kind understanding.
Thank you.
Regards,
Jerome
92256638
No problem. I msg you they came already. Now I eyeing your air fryer. heee
Rinnai Chimney Hood - Made in Italy
BUY Rinnai Hood , FREE Rinnai Hob
BUY
Model : RH Cube *Only model Made in Italy
Technical Specification:
OVERALL DIMENSIONS : W: 900mm D: 470mm H: 788+356mm
COLOUR OPTION : Stainless Steel
EXHAUST CAPACITY : 700m3 / hr
EXHAUST DIAMETER : 6 Inches
ADDITIONAL FEATURE
* Low Noise 64dB
* 3 Step Speed Setting
* Stainless Steel Professional Baffle Filter
* Push button switch
* Light bulbs : 20Watts x 2
Free Hob
Model : RB712N(G)
Price : $950
Thank you.
Regards,
Jerome
92256638
Edited by zero
VERY SPECIAL PRICE!
Rinnai Hob - Inner Flame, Made in Japan
Model : RB2CG
Fujioh Hood - 3years warranty
Model : FX900
Bundled Pricing : $1100
Promotion starts now!
Book now to avoid disappointment!
Thank you.
Regards,
Jerome
92256638
Homeappliances@hotmail.sg
Stylish Ceiling Fans!
Back to Popular Demands !
Brand : Haiku
Price : $660
Thank you.
Regards,
Jerome
92256638
  On 4/1/2012 at 1:16 PM, alicia_yong said:
Hi Jerome, can quote me on following:
Rinnai RB-3Si hob & RH-90 ER (MS, G,S) hood.
Thanks!
Hi Alicia,
Have pmed you.
Thank you.
Regards,
Jerome
92256638
  On 3/31/2012 at 4:23 PM, jonatan1312 said:
Hi Jerome,
Can you please Quote the price of below items?
Washer:
PANASONIC
NA140VG3WSG (10kg)
WHIRPOOL
WFE1210CD (10kg)
A91410 (9kg)
SAMSUNG
WF1104XAC (10kg)
WF9904CWE (9kg)
ARISTON
AQXGL109* (9kg)
BOSCH
WAS28448ME (8kg)
Refrigerator:
MITSUBISHI MR-E62S
Any recommendation for 9-10kg washer other than above mentioned are welcomed.
Thanks,
Jonatan
Hi Jonatan,
Have pmed you.
Thank you.
Regards,
Jerome
92256638
  On 3/31/2012 at 12:02 PM, Aside said:
Hi Jerome,
Can quote me the following:
Samsung fridge
Rs21hnepn,Rsa1wtts
Rinnai
RH-998C,RB-713N(G),RB-3SS(GB)
Electrolux washing m/c
EWF14821,EWN14991W
Bosch Washing m/c
WAS28448ME
Thks
Have pmed you.
Thank you.
Regards,
Jerome
92256638
Hi Jerome,
Washer:
PANASONIC
NA140VG3WSG (10kg)
WHIRPOOL
WFE1210CD (10kg)
A91410 (9kg)
SAMSUNG
WF1104XAC (10kg)
WF9904CWE (9kg)
ARISTON
AQXGL109* (9kg)
BOSCH
WAS28448ME (8kg)
Refrigerator:
MITSUBISHI MR-E62S
Thanks,
Jonatan
Edited by jonatan1312
