zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Hi Jerome,
Please quote me for below item.
Hob:
  1. EF HBAG390VGB-A
  2. Rinnai RB-3CG
Hood:
  1. EF EFCH9202HMSS
  2. Fujioh FX900R (HDB)
Besides that, I'm still struggling on choosing the right cloth washing machine. Can you please advice which brand/model washing machine is good in term of reliability, durability, and efficiency. I'm open for top-load or front-load washing machine. The brand that I've been took a look is Samsung, Bosch, Fisher and Paykel. I've heard the sales talk from the promoters. However, I would like to hear from you too.
thanks in advance.... :D
Edited by DreamerX
Hi Jerome,
Would like have quotes for the following :
1. Samsung WD8804 - Washer/Dryer
2. Panasonic NRBW552 Fridge
3. Panasonic NRBW465 Fridge
4. Rinnai RB2CG or any package current?
5. Fujioh FX900 - Any other recommendation for similar performance as depth is deep for FX900
6. Oven recommendation if any?
7. Haiku Kotuku Fan
Regards,
Simon
Hi zero, can quote Samsung 8692 washer? How long is the warranty? From Samsung Singapore directly?
How about delivery? Can help to dispose old washer?
Thanks.
Edited by lwm99
Hi, can u quote me for Bosch fridge model kgn36s51?
Tks
Hi Ris,
Have pmed you.
Hope to hear from you soon.
Regards,
Jerome
92256638
Can quote on fridge NRBW415xSSG Panasonic
And washer NAFS80X1WRQ panasonic
Thanks
Hi Nimzo,
Have pmed you.
Thank you.
Regards,
Jerome
92256638
Hi: Need to buy a island cooker hood and ceramic hob prefer European make. Cook at least once a day any recomandation?
Also leaning towards:
Bosch 60 cm induction ceramic hob PID675N24E
Bosch 90 cm island hood DIB09E850
Any good or bad points?
Can quote price for the Bosch as well
Thanks
BYS
Thanks
BYS
Hi BYS,
Have pmed you.
Regards,
Jerome
92256638
Thanks
BYS
Thanks
BYS
Grab it before its gone!
Buy,
Chimney Hood
Model : RH997CT
The Quintessential Companion to All of Your Cooking Needs
• Ducted / Recirculation Air Operation
• Stainless Steel Finishing with Black Tempered Glass
• 1,000m3/hr Air Flow with 4 Speeds
• Charcoal Filters
• Stainless Steel Buffer Filters
• 4 Speeds LED Sensor Touch Control with Timer
• 2 x 1W LED Lamps
• Product Dimensions: 900(W) x 400(D) x 1,332(H) mm
FREE HOB (Worth $400),
Rinnai
Model : RB3SS(GB)
Powerful Flame
Three Burner Built-in Hob
Black Tempered Scott Glass
Dimension (mm): 870(W) x 510(D)
Cut-out (mm): 725-830 x 435-470 x R110
Price : $950
Worth stock last!
Thank you.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Cheapest 6.5Kg Washer
Samsung WA85V3 $218 ONLY!
Features
- Diamond Drum
- Powerful water flow effect
- Air Turbo Drying System
- Magic Filter
Price : $218
______________________________________________________________________________________
Cheapest 7kg Washer!
Samsung WF8692NEC
ceramic heater
Double Coating, Triple Durability SAMSUNG washing machines have incorporated a double ceramic coating, unlike conventional heaters, providing heaters that are less porous and susceptible to hard water scale build-up. As a result of this innovation, not only are heaters protected from the build-up of water scale deposit, but the durability of your washing machine is tripled!
Diamond Drum
There will be no more fabric damage with SAMSUNG washing machine. For most conventional washing machines, it is quite common for fabrics to protrude from these holes and be damaged in the process. But with the unique embossed design of the Diamond Drum, the holes are both 43% smaller and located deep within each diamond-shaped depression to prevent fabrics from sticking out and consequently being damaged.
Samsung Side by Side fridge
Model : RSH5SUSL
CAPACITY
-551 Liters Total Net
-206 Liters Net Freezer
-345 Liters Net Fridge
FREEZER FEATURE
-Twist Ice Maker
-Drawer x 2ea
-Shelf x 5ea
-Tempered Glass Shelf x 4ea
-Door Pocket x 4ea
-LED
-Long Bar Handle
-Stainless Looking
CATEGORY
-Side By Side Refrigerator Type
COOLING FEATURE
-Twin Cooling System
-No Frost available
-Multi Flow available
PERFORMANCE
-4ticks Energy Grade
Samsung 2 Door Fridge with Water Dispenser
Model : RT72KASE
CoolSelect Turbo
The world's first freezer in a fridge, the CoolSelect Turbo lets you convert this space to meet your specific storage needs. With three distinct settings - Freeze (-12˚C), Soft Freeze (-5˚C), Fresh (3˚C) - this space transforms at the touch of a button. With a space you can customise, you'll always have premium freshness all the time
Coolever Zone - perfect fit
SAMSUNG's Coolever Zone with gapless design creates a sealed cooling zone that maintains consistent temperatures and humidity. Other crispers with its direct air shower causes frostbite and damages sensitive vegetables
Thank you.
Regards,
Jerome
92256638
Edited by zero
Hi zero,
Can quote me the price with installation for:
1. Fujioh FX900 hood
2. Power slim 90SS hood
3. Rinnai RH-90ER hood
I cook everyday, which is better?
Thanks
Have pmed you.
Regards,
Jerome
92256638
Hi Roger,
Unable to pmed you,due to your full inbox
Pls email/sms me instead.
Thankyou.
Regards,
Jerome
92256638
Hi can resend quote? Tks
