zero
Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Hi Jerome,
Seeing all the fantastic reviews and prices here, can I get quotes for the following please. Thank you :P
Fridge: Samsung RF62TBPN
Hob: Fujioh FX792
Hood: Fujioh FX900
Washer: Fisher&Paykel WH70F60W3
Dryer: Fisher&Paykel DE50F56A
Heater: Joven 25L
TV: Panasonic VIERA TH-P50ST50
Would not mind if you can recommend bundled package for washer and dryer and any other good deals on popular products!
:yamseng:
Edited by lucass
pls quote the following
1) hood hob stainless still 2 burner with normal hood strong flame ( your recommendation needed) mum like strong flame very strong :)
2) large lcd led or plasma tv 50" and above.. cheapest no need any internet or 3d or whatsoever..
3) big fridge those conventional 2 door type freezer at top atleast 580L nett with or without dispenser
4) big washing machine atleast 10kg
5) 2 piece 32" in lcd
give a good quote ..regards
Rinnai Promo Package till 31July2012!
Book Now before Promo End !
Hob, Hood, Oven !
Rinnai 2 Burner Hob
Powerful Flame
Designed for flexibility and elegance
Colour and Material: Black Tempered Glass
Cut out size(mm): (W)650-735 (D)350-421
Product Dimensions(mm): (W)780 (D)465
Rinnai Chimney Hood
The Quintessential Companion to All of Your Cooking Needs
• Ducted / Recirculation Air Operation
• Stainless Steel Finishing
• 1,000m3/hr Air Flow with 4 Speeds
• Charcoal Filters
• Stainless Steel Buffer Filters
• 4 Speeds LED Sensor Touch Control with Timer
• 2 x 20W Adjustable Halogen Lamps
• Product Dimensions: 900(W) x 480(D) x 1,075(H) mm
Rinnai Oven - Made In Italy
Size: 594(W) x 535(D) x 594(H)
Capacity: 61 L
Power Consumption: 2.3 Kw/h
Cooking Functions:
- Basic functions
- Light
- Lower element
- Conventional top & lower elements
- Grill element
Colour: Stainless steel
Features:
- Bigger capacity
- Finger print proof
- Removable double glass door
- Buzzer timer
Temperature Setting: 0 - 250C
Retail package : $1573
Special package(25% off) : $1155
Thankyou.
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Edited by zero
I wanted to provide my compliments to Jerome for being responsive and his team for being reliable. These are the stuff I ordered from him and all got delivered in 3 separate trips. Although there were some misunderstanding in prices due to agent sudden price change, everything else was smooth and convenient.
1. Dyson Tower Fan AMO2 White
2. Dyson DC35 animal vacuum cleaner
3. Rinnai RB-2CG (Hob)
4. Rinnai RH997CT (Hood)
5. Ariston Inox AA-25
6. Samsung TV UA46ES7500M 46 Series 7 Slim LED
7. Samsung TV UA40EH5006M
8. Panasonic NN-CD997S
9. Toshiba rice cooker model RC-10NMF
10. Samsung 3D DVD player BD-ES6000
11. Philips Garment Steamer GC525/05
Jerome, if you continue to be prompt in replying requests and improve your communications with the agents, I'm sure everyone here will benefit.
I may have some more orders to come after I have settled down for a few months.
Thanks and great job!
Hi Ding,
Thankyou for the wonderful comment and support.
I will take note and improve myself to serve the rest better.
Let me know again if you need other items in future. :)
Thankyou.
Regards,
Jerome
92256638
Edited by zero
Some Sharing Regarding Rinnai RB2CG
Rinnai gas cooktop (see PIC 1) incorporates recessed, inner-flame burners into a Schott Ceran glass-ceramic panel to create an appliance that provides high-performance cooking capabilities with convenience and an easy-to-clean surface. A vortex of flame (See PIC 2) is created by angling the burner ports on the horizontal plane. The swirling flame aids combustion by helping to draw air. The unique flame also assists in distributing heat evenly across the bottom of the pan.
Inner-flame burner improves heat transfer efficiency.
Cutaway view of Rinnais inner-flame burner shows how the individual flames coalesce and rise toward the center. When the cone of flame hits the bottom of a pan, it flows outward across the bottom to ensure even heat distribution and efficient heat transfer.
o o o
Appliance-maker Rinnai Corp., Nagoya, Japan, has turned burner design completely around with its inner-flame burner. Instead of shooting flames outward from the burner perimeter, as with a conventional burner, Rinnais inner-flame burner is ported so that flames shoot inward toward the center.
The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan.
In addition to aiming the ports inward, two other design factors assist in shaping the flame. One is that the burner sits slightly below the surface of the cooktop, helping the individual flames to coalesce toward the center as they rise through a hole in the cooktop surface. Secondly, and more importantly, the burner ports are angled slightly on the horizontal plane. (See top view in lower photo.)
The effect of the flames shooting out an angle is to create a fiery vortex. The swirling flame is meant to accomplish two things. One, it assists in driving the flame outward across the bottom of the pan, helping to evenly bathe the pan bottom with flame. Two, the vortex creates a pressure drop that assists in drawing air in for combustion.
The large version of the inner-flame burner has 24 ports and delivers a maximum output of 15,872 BTUs/hr. The burners are lit by direct-spark ignition.
Rinnai originally intended the inner-flame burner to be installed into a metal panel cooktop. Instead, Rinnai began working with Schott Corp. to find a way to implement the novel burner into a Ceran surface panel.
Schotts technical support staff worked closely with Rinnai to address a number of issues. One of the biggest was concern over how to protect the burner and other
components from spills going down the hole. Another big concern was protecting the Ceran from direct exposure to excessive heat. Schotts engineers devised a special burner sleeve to solve these potential problems. Schott also assisted with the design of the cooktops framing and a ventilation grid in the cooktop which serves two purposes: one, to provide primary air supply for the burners and, two, to vent exhaust from a fish griller beneath the cooktop.
Rinnai incorporated many of Schotts design ideas in the final production model of the appliance.
The result was a unique appliance that successfully combines a novel, high-performance burner design and a convenient, easy-to-clean cooktop surface.
Schott says that the popularity of Ceran is growing in the Japanese market because the materials cleanability is a big advantage in a region where cooking methods involve a lot of frying.
Rinnai says the cooktop with the inner-flame burners has been adopted by many Japanese cooking schools because the burner system is amenable to cooking different regional styles of meals, including Japanese, Chinese and French.
PIC 1
Uploaded with ImageShack.us
PIC 2
6. Samsung TV UA46ES7500M 46” Series 7 Slim LED
hi, can you kindly quote for the following:
1. LC60LE630M Sharp 60" LED TV
2. RB6200S-XK Hitachi Fridge
3. SKS60E02EU Bosch Compact Dishwasher
4. PRA326B90E Bosch 1 Burner Ceramic Glass Hob
5. PID675N24E Bosch Induction Hob
6. WVH28420EU Bosch Washer/Dryer
Hi Jerome,
What's the price & warranty?
Tks.
Jay
Hi Jay,
Warranty is standard 1yr from agent.
For price, Pls call to ask for it.
Thankyou.
Regards,
Jerome
92256638
Hi bro. Pls help me quote Joven Instant Heater i70P with shower head.
Samsung Fridge RSH5SUSL.
Have pmed you.
Thankyou.
Regards,
Jerome
92256638
Hi Bro
Can quote me again for
Fujioh FX900
Rinnai RB-2CG
Rinnai RBO-7MSO
Bosch HBA23B550J
Thanks!
Have pmed you.
Thankyou.
Regards,
Jerome
92256638
Hi Jerome,
Can i have the quote for
1.Hitachi RZ481EMSX-STAINLESS
2.EF-(CK STILE)1200m3/hr
3.EF-EFH 3763 TN VSB (3 burners)
4.LG WFT8061DD 8KG
5.LG WFT9561DD 9.5KG
Thank you!
Have pmed you.
Thankyou.
Regards,
Jerome
92256638
Hi Zero, please quote for these
Rinnai Hob RB-2CG
Rinnai Hob RB-3CG
Rinnai Hood RH- 991CT
Rinnai Hood RH- 992CT
Rinnai Hood RH- 995CT
Fujioh FX-900
Fujioh FX-900V
EF hood CH AG30 A
Bosch oven HBG43S450A(soft closing?- pls confirm)
Bosch oven HBG23B250E
Hitachi Fridge
RSF57BMS
RSF48BMS
RSF42BMS
Haiku Fan Composite (black)
Haiku Fan Composite (white)
KDK M11SU (white)
Are there other KDK fans for HDB that are shortlisted by other buyers?
Thanks!
