airconlin
How Many Btu Is Reasonable For Hdb Master Room And Common Room?
I checked here,
http://www.eyair.com/BTU's%20CALCULATOR.htm
It looks like for a 10 sqm common room, 5000 BTU is more than enough, however, in the Singapore air conditioner market, some major brands like Mitsubishi, Panasonic, the minimum indoor unit is 8000 to 9000BTU, I only find LG has smaller model of 6500BTU, but not sure is it wise to choose the low BTU one, it definitely save a lot of electricity, however if the cooling power is not enough later, it become a big issue, need professional advise, thanks!
For HDB rooms, 9k btu should be enough.
Thanks for help! My question is, for a 10 sqm common room, is 9K BTU/hr a waste? It only need 5K to 6K is enough, am I right?
By the way, I just found that Mitsubishi also has 5K to 6K small indoor units, like MSY-GE10VA
Edited by airconlin
