andrew
Simple Question - Alignment Of Tap
Hopefully this is a simple question. I always have problem screwing on a wall tap (e.g. For water hose or washing machines) and when fully tightened, it does not face down, instead it's off-angle.
I tried putting more rubber washer or increasing the thickness of the white tape but to no avail.
Any tips from fellow DIYers ?
Thanks
You've got it right...
That's all you need to do....
rubber washer normally put in 2...
White teflon tape use ALOT!!!
you'll get the alignment in a few tries...
Thanks
