user123
How To Remove Window Grills?
I need to put up a casement aircon. My window is push-out type, so it does not have a railing to hold the aircon rack. The only place to use, is to sit on the sliding grill. It's a 2-piece grill, means if I were to put the aircon on one side, then both grill have to move to the other side permanently and I cannot access to the window, which happent to be a place to hang out laundry. So I have to remove both moving grill, leaving the grill frame intact for the aircon to sit on it.
Question is, how to I take out both grills from the frame? I see only rivets but no screw openings. If I need to remove these rivets, how do I remove them?
Thanks for the help.
to remove rivets just get a batt powered hand drill with a 5mm bit the drill till the top of the rivet goes into your bit.
quote name='user123' timestamp='1314327681' post='663628']
