Stanley Ng
Question To Ask
Under the HDB general Specs:
Services
Gas services and concealed water supply pipes.
Concealed electrical wiring to lighting and power points (including water heater and air-conditioning points).
->*Concealed electrical wiring to lighting and power points (including water heater and air-conditioning points*
Meaning that all my air con piping will not be expose with those huge casing?
Anyone know on this?
Thanks.......
bro...
generally all cabling and aircon must NOT be consealed within any HDB flat... (unless originally done by HDB)
so yes you will see the hugh ungly casings...
but you can get the false ceiling guy to do a box up so it looks more like a wall then the ugly casing.
The general specs are referring to the "electrical wiring" to the aircon compressor.
Not referring to the aircon gas piping.
