Rover
Wall Mount Fish Tank
aQuatic Style Pte Ltd
30 Kaki Bukit Road 3 #07-16 Empire Technocentre Singapore 417819
6848 2057
Anyone knows where could I get wall mount fish tank?
TIA ;)
Thks. Heard of aquatic. Pretty exp though. Am sourcing for more options ;)
DIY :sport-smiley-018:
Quite simple really if you understand the basics of fish-keeping.
DIY? The water-proofing part not easy right?
That's not the issue. The challenge is how to support the tank in an aesthetic manner.
For the tank, you can custom it to your dimension with 6mm or 8mm glass.
The bigger the tank, the heavier it is; 1 litre of water is @1 kg.
Also before you decides on the dimension, go to a well-stocked aquarium shop to check on the available equipments; internal filter, lights.
You may want to visit the local aquatic forums for more ideas. ;)
Hmmmm.... Worth considering. Thks for the fruit for thought ;) Cheers!
Yes, diy is a better option n much cheaper option, but make sure u understand the basics of water management first (eg. Filtration)
Dun go to those decor fish shop (espucalkt those in imm), I suggest you get those custom fish tank builder and get him to work with your Id/contractor. In wall tank is a long term commitment, if you don't get it right, 3/4 years down the road, you are going to wake up in a Swiming pool. :)
I was into the reef keeping hobby and lots of newbie regretted getting these people to do their fish tank....go look at sgreefclub.com to look for info...
Edited by folwer
