zer0sg
Another 3I Hdb Unit Revamperation
Yeah i agree. Space planning is bloody important. Oh yar.. i was quoted 4250 to change all my windows as well. (casement) in total 10k for air con and windows for a 3 room flat... pengz.
Contractor Selection Process
This wasnt an easy decision as there are so many pros and cons, opinions and factors involved. It took us months to eventually come to a decision. We were quoted from so little as 34k to as much as 62k. The variance in price definitely did not help our cause.
Here are some of the IDs weve been liasing with.
1) NoffWess (can't type full name in this forum)
2) Dizthing Eyedentity (can't type full name in this forum)
3) Sky Creations
4) White Space Living
5) Calaido Interior Designs (can't type full name in this forum)
6) The famous Alan of the renotalk forum
7) Good term contractors
8) Classik Eyedears (can't type full name in this forum)
9) Summit Interior Design
10) AX Interior Design
11) Rest & Relax
12) Metamorph Design
13) Chew Interior Design
14) Lourve Interior Pte Limited
15) Wood and Metal General Contractor
16) Ish Interior design
And this is as far as I can remember…. Gawd.
Ironically, I came up with my floorplan myself entirely.. perhaps maybe I am too picky and particular. Anyway it brought about a new set of problems who do I choose to do up MINE design… I bet many out there would go with a contractor… that is not always the best alternative.
Was intending to do a writeup on each company but believe that would take me a couple of hours…and it wouldnt be fair to them.
Will instead write experiences and common expressions / traits displayed seen during our interactions :
*There are very few proper designers most layouts which were recommended to us were uninspiring and impractical ( not taking into account details such as the beams, height and theme) Most people we met with the exception of one… had similar proposals. The exception however gave us a quote of 51k… although his idea was radical and exciting, I did not think I could afford it…
*Salesmen vs layout staff vs quotation staff sometimes the people who you speak to passes on the job of doing up your layout to another dept and yet another dept to do the quotations. Leaving the original sales guy in a state of confusion and not in the know. Perhaps this is why their sentences contradict or things in the quotes arent particularly clear.
lines which I am sick of hearing
- Dont worry ......
- Then I will play with the lights… (seriously what does this mean?)
- here is my quote… that is before my discount to you lah.. too expensive issit? Then I reduce the price loh…
(why do we play these games)
- Got money can already loh, all your problems are be solved
- so can we sign today? (its as though we will change our minds after we go back renovation still needs be done!)
- I normally do condos and bungalows one… (ok bye)
- I can throw in this one for you lah… (Coloured PVC for one wardrobe or some low cost item) PS this is usually after they have marked up 20 30% on the larger items
- Mine better quality mah. I use blahblah, others use blahblah. (honestly, how am I expected to know these things unless its my bread and butter)
*the words minimalist, modern, contemporary has lost the all meaning…
* 5 different quotes from 5 different companies = 5 different way of quoting and different dimensions (same layout!) Eg. Kitchen cabinets was estimated between 12ft 34ft. My wardrobe was calculated from 18 ft to 28 ft.
*Some quotes are extremely detailed settee in solid plywood 6mm thick with laminate finishing (up to $50 per pc) under the window of approximately 3-4ft with blahblah hinges and custom made cushion top with blahbblah material PLUS can flip upwards and thereby doubling up as storage space for items such as your books, clothes or past quotations from other IDs ;)
Whereas some just state 1 pc sitte in MBR.
*All IDs say other IDs are dishonest.
*Carpentry work is surprisingly difficult. Most companies quality varies. Some feel very light and flimsy, some are alittle shoddy. Things like creating a rounded edge cant be done by some of ID companies sub con would need additional monies if you want such designs.
*Suspended TV consoles…. Swivelling TV feature wall… Cushioned wall backing on bedhead. Box up , L Box, downlights, china made homogenous, laminated floorign… HOW BORING!! Why does everyone do the same thing?
* Price of tiles / laminates etc dubious dubious and more dubious. Some allow up to 3.20, some dont even put that in but verbally say up to 4.80 per tile. Argh. Frustration.
* Minimalist theme = as cheap and as little materials as possible for the highest price.
* everyone is patient before you sign the contract.
Ok enough griping.
In the end, here are some of the things which I like (may not be a good gauge)
- prompt response, responsibility and takes note of little details during discussions (sort of an indicator of the renovation process itself aint it?)
- arranges appts, drives you to various locations to see tiles, current projects, completed projects and to meet you at your place of convenience.
- understand your quotation and needs well. (I had to repeat my requirements 2-3 times before some of the IDs eventually added into the quote) People often 4get I had pets to cater for even after I reminded constantly. Works within your budget
- nice shoes.
- follow up with emails, phone calls and presentations during meetings. (drawings, contingency plan.. etc)
- tries his/her best to provide a better pricing.
- communicates well.
- able to provide before and after pictures of previous projects.
- site visits (takes measurements, pictures, spends time noticing the layout and restrictions)
- Organised (able to find his files, pictures and notes readily) Better yet, remembers your details.
Edited by zer0sg
Seems so.. why are these companies censored in the first place? :dunno:
yeah finally decided on one who is reasonably priced, service orientated, has helpful suggestions and a head for design. Also in this line for some time and has the branding of a big company to back him.
so which ID is it? :dunno:
