Rover
Project Car Reno - Dress Up Car Enthusiatic
Guest Goobii
Here's mine....
The concept of making the car a better looking & performance vehicle for our daily usage...
Doned/Installed:
1) Bassen Smoke LED Tail light.
2) Bassen Smoke LED 3rd brake light.
3) Smoke black LED side marker.
4) Plastic transparent black floor mat x3 (easy wash)
5) Viper 5902 + Tilt Sensor + Blink decal + OPEN/CLOSE Sunroof + Motion Sensor + LED scrolling wording light
6) Addon Mirror FOLD module
7) Addon Window UP module
8) Addon Bypass for AUTO start for immobilzer chip
9) Carlife curtain for front & mid window
10) White LED O-Ring for ignition key
11) Bottomline side rear + Yaris rear centre piece
12) Crave spoiler
13) Mugen Front Grill
14) 18":BE by Breyton GTS-AV Black/Titinum + TOYO T1R 225/45/R18
15) Rays wheels nuts - Mat Black + Black pressure cap
16) V-lips - Front bumper protector
17) Bottomline sideskirt
18) Special made NUMBER plate front & back
19) Purple LEGROOM
20) CF foot panels
21) Purple/Black eyelids
22) White LED map & cabin lights, reverse light & number plate.
23) Mugen replica door visor
24) RainAWAY 1yr warrenty (Permanent solution against rain spots on windscreen)
25) SHARP ION Plasmacluster air filter
26) White HID 6000k headlight / 6000k foglamp
27) Super LED Daytime Running Lamp (Tinted for the hidden effect) *Changing Soon*
28) Ikea car-mat for boot (Covering the boot space when 3rd seats are down)
29) Glossy black sticker covering 3rd window rear panel (For hidden effect)
30) Mat black sticker sunshade for front window
31) Wide blue mirror with LED signal indicator
32) White LED pole light
33) (Purple/Black) rear around HONDA ... removed logo
34) (Purple/Black) top front grill
35) Groomed by REVOL - www.revol.com.sg
34) Front DVR camera with motion sensor
35) Rolled Rear Fender (Prepare for coilover)
Engine + Performance MODs:
01) Drop-IN Mugen or K&N air filter
02) Pulstar Plug - http://www.pulstar.com/index.htm or DENSO IK20L
03) Permacool ATF coolant (Cool down the AutoGear Transmission Fluid)
04) UTR Power Charger (In Oct)
05) Throttle Bypass + Throttle Spacer
06) Heat shields for aircon (DIY)
07) Heat shields for air filter box (By Whitesnail)
08) Mugen Eel Air Catch Scoop + C.A.I (By Whitesnail)
09) 7 points grounding (By Whitesnail)
10) Cusco Front Strut Bar
11) 4pt ultra racing underbrace *FRONT & REAR* + Undercarriage Sidebar
12) Apexi N1 from: front pipe to mid pipe to muffler (3piece)
13) Racing Lower Temp 68degree thermostate
14) Alignment & High-speed on wheel balancing @ Stamford Tyre
15) Apexi Radiator Cap
16) Engine Cover 1st GEN"
17) Alutec Crank Pulley
18) Transparent silicone white suspension stiffener
19) D1spec - Stainless Steel Braided Brake Hose
20) Nashin 4pot BBK + 330mm cross drilled holes rotor + Sport high temp brake pad (Purple/Black)
21) UnchipQ + Extension into cabin + Bore Throttle (163.3bhp / 197nm)
22) ScanGauge II - http://www.scangauge.com
23) Power Mesh - Testing for fun...
24) BiG 3 to 5 grounding 4g cable upgraded
25) Blitz engine oil cover cap
26) Charcoal aircon filter
27) DIY increase height bonnet. (2&3 ring washer used)
28) ECU reflash + Gear Tuned
29) Front Camber kit & Hardrace Rear Camber Kit
30) Rigid Collar Stiffener (Front)
Edited by Goobii
