user123
Is There A Way To Cut Thru Tempered Glass?
I have a tempered glass as partition between hall and kitchen.
Now, I need re route some electrical switches from the kitchen to the kitchen entrance. However, the glass was fix to the wall/ceiling. Is it possible to drill the tempered glass so that trunking can be use to run through it?
Thanks
No. Any stress on it, it will shatter. TRy to penertrate through the silicon?
Oh ok... there isn't any gap between the glass and the wall/ceiling....but luckily that time I did request a small hole at the bottom of the glass, it's just that the wiring and trunking need to be route donw adn then up... longer and uglier sight... :(
