west 1 Report post Posted September 4, 2011 Hi neighbourhandover already?? Share this post Link to post Share on other sites
xtac 0 Report post Posted September 5, 2011 Can i check with you, for your LED lights, are they actually brig enough to light up your rooms? I went to a couple of lighting shops and they all said that LED lights are not as bright as T5 lighting when it comes to lighting up a room hence the place will look dimmer when using LED lights unless you are using a lot of LED lights to light up a room. Is that true? Share this post Link to post Share on other sites
Phintastic 0 Report post Posted September 7, 2011 On 9/4/2011 at 3:42 AM, west said: Hi neighbourhandover already?? Hi neighbor, sorry for the late reply, handed over my keys to buyer last Friday nite.......moving was done from Friday afternoon, so whole weekend till now bz packing and unpacking.......... My Reno still incomplete, MBR no bed yet.... When I moved in tvconsole 70% done... Toilet also incomplete.... Basically on the whole Reno only completed 70% as of last Friday..... Will update with photos next week, my broadband is not up yet,difficult to load photos with iPad Share this post Link to post Share on other sites
Phintastic 0 Report post Posted September 7, 2011 On 9/5/2011 at 1:23 AM, xtac said: Can i check with you, for your LED lights, are they actually brig enough to light up your rooms? I went to a couple of lighting shops and they all said that LED lights are not as bright as T5 lighting when it comes to lighting up a room hence the place will look dimmer when using LED lights unless you are using a lot of LED lights to light up a room. Is that true?The LED square ceiling lights on my photos are bright enough to light up my bedrooms, no issue at all. But you mention about T5, are you looking at having cove lights in your bedroom or bed head? If you compare T5 led and plc, plc seems brighter, reason is projection angle if light of led is narrower. Then again, need to see how big a room we are looking at too. Share this post Link to post Share on other sites
Emulsionpaint 0 Report post Posted May 17, 2012 (edited) On 9/7/2011 at 3:28 AM, Phintastic said: The LED square ceiling lights on my photos are bright enough to light up my bedrooms, no issue at all. But you mention about T5, are you looking at having cove lights in your bedroom or bed head? If you compare T5 led and plc, plc seems brighter, reason is projection angle if light of led is narrower. Then again, need to see how big a room we are looking at too. Hi, Where can I buy your LED square ceiling lights on your photos ? how much do they cost? Edited May 17, 2012 by Emulsionpaint Share this post Link to post Share on other sites
