danard 0 Report post Posted July 5, 2011 Hi all,We accidentally peeled off one small paint area on the wall while moving furniture around. If just applying a new paint a top, might still see this "50cent" paint area chipped off from the wall. Does anyone have some good idea of how to repair this? Can we use sand paper to smooth out the edge? If yes, what type of sand paper to be used? Worried that we might crack the paint further if using the wrong sand paper. The wall has been plastered recently. Please help. Thank you. Share this post Link to post Share on other sites
landoflord 0 Report post Posted July 9, 2011 May i know what paint did u use?If you are using those Mat colour paint eg Odour-less Premium all-in-1 interior wall paint. Its fine to do touch up and most of the time u wont see the paint patch. Share this post Link to post Share on other sites
garywu 0 Report post Posted July 12, 2011 Buy the smallest can of wall putty that you can find @ any hardware shop.This putty usually come in white.Get flat scaper, scape a bit of patty put it into the "50cent" hole. Scape it thinly as in such a way that the new patched up area will be the same as the old existing surface.. ( flush flat)Let it dry. If after dry u see uneven u take apice of sand paper sand a bit. ( a bit mean a few seconds with mild strength!)Paint over it with your colour paint. Share this post Link to post Share on other sites
