df78 0 Report post Posted June 18, 2011 Anyone knows?I was told that the piping can be hidden within the lbox or false ceiling and it will look nice.however, some others also told me that if the piping leaks, then i would need to redo the l box or false ceiling so it's better to do the lbox and false ceiling after the air con is installed.What's the best way to do so as I intend to install a system 4 and place lbox/false ceiling in all my rooms. thanks! Share this post Link to post Share on other sites
archenemy 0 Report post Posted June 21, 2011 as you already mentioned the pros & cons...which is more important to you? ease of maintenance? or asthetics? i got a water pump to help reduce the chances of my water discharge pipe being clogged..the pump will help to give pressure needed to clear the water discharge from the aircon... some parts of my air con piping is concealed by false ceiling.. Share this post Link to post Share on other sites
