Nellynutt
Full Home Renovation, Budget 10K To 17K For 107Sqm, Can Acheive Or Not?
Hi all,
Need some recommendationon resale 4rm 107sqm renovation, budget strapped , would like to work within 10k to 17k, simple full renovation
Looking forward to any response.
:help:
Thank you
:D
shouldnt be a problem is it is a simple design .
4room flat $14000
A. CARPENTRY WORKS IN KITCHEN
1 Design & install 10ft top kitchen cabinet (laminated) + ABS
2 Design & install 10ft Bottom kitchen cabinet (laminated) +ABS
3 Supply & install new 2-Tier Stainless Steel Dish drainer-1 set
4 Supply labour to install cooker hob & hood into Kitchen cabinet
5 Supply & install with 2 nos Frosted Glass Panel
B. WET WORKS IN KITCHEN
6 Supply & construct base for cabinet, with tiles
7 Supply & construct base for washing machine, with tiles
8 Supply & construct base for Refrigerator, with tiles
9 Supply & construct 1 no shower kerb,with tiles
C. CEILING WORKS
10 Supply & construct L-Box light holders in living area
11 Supply & construct L-Box light holders in dining area
12 Supply & construct false ceiling at foyer entrance
13 Supply & construct false ceiling at bedroom's entrance
D. PLUMBING WORKS
14 Supply & install water inlet pipe for sink in kitchen
15 Supply & install water outlet pipe for sink in kitchen
16 Supply & install water inlet pipe for washing machine in kitchen
17 Supply & install outlet pipe for washing machine in kitchen
18 Supply labour to install 2 sets toilets accessories in 2 toilets.
19 Supply labour to install 2 nos Mirrors in 2 toilets
20 Supply labour to connect water pipe for 2 sets instant heaters
21 Supply labour to install 1 no washing machine tap
E. ELECTRICAL WORKS
22 Supply labour to install 10 ceiling lights
23 Supply labour to connect 2 instant heater
24 Supply labour to connect hob in kitchen cabinet
25 Supply labour to connect hood into kitchen cabinet
26 Supply labour to connect door bell at existing Points
F. PAINTING WORKS
27 To paint whole house, using ICI Walls & Ceiling
28 To paint whole house copper/pvc pipes
29 To paint or varnish for whole house doors, main door included
30 To paint or varnish for whole house door frame
G. MISCELLANEOUS ITEMS
31 Supply labour with acid washing whole house
32 Supply labour to clean up whole house windows & grills
33 Supply Corrugated board to protect whole house existing flooring
34 Supply labour to summit HDB application, for all renovation Works
H. SHOWER SCREEN
35 Supply & install 10mm tempered glass shower screen in main toilet
I. FLOOR WORKS (600mm X 600mm)
36 Supply & lay Polished Homogenous Floor Tiles for Living Area
37 Supply & lay Polished Homogenous Floor Tiles for Dining Area
38 Supply & lay Polished Homogenous Floor Tiles for all Bedrooms.
39 Supply & lay Homogenous skirting for Living/Dining &bedrooms
40 Supply & lay Polished Homogenous Floor Tiles for Household shelter
Edited by ManfredTeo
Hi all,
:help:
Thank you
:D
"Simple" and "full" reno are contradicting each other.
haha i also do agree with you... therefore is full renovation with simple design
new flat? standard or BTO? already come with flooring?
resale flat? empty? touch up needed only or need to dismantle/hack?
maybe its easier if you tell us what you expect to be done...
the floor area is not a good indication of what needs to be done unless you need to do flooring...i know of people who spent $60K doing a 80+ sqm flat and another who spent $16K doing a 120sqm flat..
the definition of full renovation means different things to different people too..
Edited by archenemy
Resale, old old flat..
kitchen, toilet x 2 = A must = hack hack wall floor, change new bowl, sink , pipe, door
Living area & bed rooms = Flooring only
Pondering with ideas to hack the kitchen wall, and storeroom = depends on budget
Electricity wiring all rooms and Plumbing works
no need L shaped light or down light..
may need to change 3 x bedroom door with locks
Carpentry = depends on my budget
wah ... headache...
by the way, any goodfengshui master to recommend?
Please do share if you can get quote of around $10k.
So far the quotes i have for renovating an old 3rm is between $15k to $29k..
And I have indicated my budget of $10K.
Guess due to the different works done.. the price varies so much.
wow..quite a lot of hacking and flooring to be done i see...
i guess the flooring will pretty much be depended on what kind of tiles you want..no experience in that..so sorry i cant comment..
L shaped light? L-box or light box you mean? actually doing light box not really that expensive...and its very versatile in letting you place lights where you want it to be...
my feng shui master is quite ok...very responsive to my queries and questions even after collecting money...but as to how effective his advice is...i can only tell you 10 yrs later..haha..
if you interested can drop me a PM...
You will need to set about 5K to revamp your both toilets only. This of cox includes the bowls, sinks, accessories. The charges for carpentary work depends on your ID seriously, as the prices between the firms varies maybe about $10 to $20 per foor run. Well, you could still do up your home between 10K to 17K if your reno is really that simple and nothing spectacular. :)
