stardust205 0 Report post Posted June 7, 2011 (edited) Hihi,Anyone tried on your own, to run a cable from the SCV pt in living hall.. to another room?If I connect the cable directly from the port without using a splitter at the SCV box, does that mean the data transfer rate won't be compromised?I also intend to use the 'Belden rigid coaxial cables (black color)' which Starhub contractor uses.Cuz it would costs $130 to engage Starhub appointed contractor for the installation. Wanna save some $..Any advice? Thanks! Edited June 7, 2011 by stardust205 Share this post Link to post Share on other sites
wwz 0 Report post Posted July 1, 2011 Hihi,Anyone tried on your own, to run a cable from the SCV pt in living hall.. to another room?If I connect the cable directly from the port without using a splitter at the SCV box, does that mean the data transfer rate won't be compromised?I also intend to use the 'Belden rigid coaxial cables (black color)' which Starhub contractor uses.Cuz it would costs $130 to engage Starhub appointed contractor for the installation. Wanna save some $..Any advice? Thanks!My regular electrician only does that at $100. anyway you can just connect the cable directly to the port at one end unless the point is no longer in use. it should works just fine as for data transfer. Share this post Link to post Share on other sites
stardust205 0 Report post Posted July 1, 2011 Thanks wwz. I'll do just that. My regular electrician only does that at $100. anyway you can just connect the cable directly to the port at one end unless the point is no longer in use. it should works just fine as for data transfer. Share this post Link to post Share on other sites
