a4tech24 0 Report post Posted June 6, 2011 Hi to all, please help me to quote how much this tv wall feature will cost(2100mmX2030mm), it's just a simple box that will be laminated and make a compartment for power point and a round hole for cable to thru run inside and out of the wall feature. If someone can help me please let me know your email and I will email you the drawing that I have designed. Thank you Share this post Link to post Share on other sites
WinnD3sign 0 Report post Posted July 22, 2011 Hi a4tech24,Can you drop me an email with your design at winn.design@yahoo.com . Thank you.Regards,Winnie Share this post Link to post Share on other sites
arowana 2 Report post Posted July 22, 2011 based on that size, about 1-1.5k max. Share this post Link to post Share on other sites
arowana 2 Report post Posted July 22, 2011 actualyl if it's only standard feature wall, it shd definitely be less than 1k. I got that from a quote myself. (so this is from contractor and not negotiated yet.) If you go to direct carpenter you could be saving another 10% more? Share this post Link to post Share on other sites
MsChoong 1 Report post Posted October 13, 2011 actualyl if it's only standard feature wall, it shd definitely be less than 1k. I got that from a quote myself. (so this is from contractor and not negotiated yet.) If you go to direct carpenter you could be saving another 10% more?Is it really safe to go directly to contractor?I say another post stated USE at your own risk. Share this post Link to post Share on other sites
MsChoong 1 Report post Posted October 13, 2011 Hi to all, please help me to quote how much this tv wall feature will cost(2100mmX2030mm), it's just a simple box that will be laminated and make a compartment for power point and a round hole for cable to thru run inside and out of the wall feature. If someone can help me please let me know your email and I will email you the drawing that I have designed. Thank you TV Feature wall is about $170-$190pf. Share this post Link to post Share on other sites
