matrix0405
How2 Reduce Aircon For Living Room?
Let say you want to a/c your living room; which is a huge square shape. Do you guy have some suggestions on how to partition a small room out of the living room when the a/c in turned on. Prefer the partition is movable and can be kept when a/c is not in use?
I've seen mainly in offices these movable partitions to section off meeting/training rooms. You can try to google movable walls or partitions and see what you can find. However, bear in mind that you will need to give up a section of your room for these panels to collapse into when they are kept.
The easiest, though may not look as nice, would be to have heavy curtains.
Your decision might be influenced by how often you need to use the a/c within the smaller space. If very often, then the movable panels might be a better solution. If occasional use only, then the curtain could work.
