patsy_sg
Third In Three Years
Haha think I'll let him off this time since he was here till 10+ last night!
Thanks may dream and sleek, doing landed Reno is very much like doing others except there are less rules, and more things to think about!
Have to give him props.... Very dedicated. Spent 3 hrs plus this arvo. All my sanitary ware and loose lightings settled.
can anyone suggest how we can incorporate a shower screen in the existing toilet to prevent the whole place getting wet when someone showers in the guest bath? the only option i can think of without totally shifting the sewer pipes would be bring forward the sink, put a shower in between the sink and the bowl and add two doors to close up the space when someone is showering.. but that'll look so odd!!
Looks complicated unfortunately.
My suggestion is that the 1st floor toiletbe converted to a powder room with shower facilities. If there is space could possible build a separate shower cube?
am planning for the 1st floor toilet to be for the helpers use only, so she has some privacy, so would really want to do up the 2nd floor one especially since the guest room is to be in the 3rd floor! bit of a trek for guests to go all the way down to the 1st floor?
wahh.. indeed challenging le.
One way is ... shift the shower to the opposite side and do a small shower kerb.
but will appear cramp too, i guess.
The quick and cheap alternative is w/o moving the WC plumbing points is to build a small shower tray between the sink and WC and then use a shower curtain.
This way the water will be contained and place won't get very wet. However ifyoudo have guests visiting I would imagine that they will use the toilet on level 1 instead of trekking to L2 or L3?
Todo this though, you will need to redo the floor as they will need to run an outlet from shower tray to the drain.
We're ok with moving the bathroom door slightly forward towards the stairs, to give more space into the bathroom. That will give some space for a shower, just wondering how to do a screen..... Marcus actually suggested 2 glass half doors - like panes that can be swung back and forth as required and lower the floor of the shower area to demarcate it. May work?
Do you plan to replace door? All my toilet doors are this type and I have replaced all with Besglas bi-fold doors. Space saver.
will definitely redo the floors anyway since I cannot live with the colour combination! :)
