ramunc
Parquet Flooring
Hi
Can anyone tell if I can buy the Genuine Burmese Teak Parquet for rooms in Singapore.
If yes may I know the contact details.Will they provide a certificate of Genuine or Certificate of Burmese origin?
Ramu
Burmese teak are the best. My previous home which is using this burmese teaks are still in good condition n zero dollar maintainence. My buyer tells me it is still NO PROBLEM at all.
But it is not eco-friendly rite?? you have to cut down trees in Burma tropic forest, manufactured and send to Singapore. There are many other options of wood products that can perform similar (or better) than Burmese teak, have you considered of strand woven bamboo flooring? it is more compact, scratch resistant, low maintenance, and absorb very low moisture (no pore) so it performs much better than any wood products. The finishing also similar with wood products, you can check through of these links if you want;
http://www.articleculture.com/Art/1412/221/Bamboo-Flooring-Review-Pros-And-Cons-Of-Bamboo-Floor.html
http://homeimprovement.webfiy.eu/2011/03/26/bamboo-flooring-in-your-front-room/
Some of the finishings ;
Cheers,
