edenstrauss
Demolition Of Walls & Erection Of Walls (In-Between Bedrooms)
Hi Sis,
Really appreciate your good effort in continuously updating us on your reno.
If you dont mind, could you pass me the contact of the contractor.
Hi u r most welcome! :)
Yes I will PM u the contacts of this contractor right away.
But if u need ID services, i.e. interior designing, I also can recommend you one really good one, which I dare to guarantee in terms of service & workmanship - becox they've been tried & tested by those in our social circle. jux let me know.
:D
Hi Edenstrauss.
Mind pm me your contractor contact too.
If you don't mind, care to share your cost to erect the wall back to me too?
Thanks - Nobel
Edited by nobelleng
Hi Edenstrauss.
Thanks - Nobel
Hi nobel,
I've responded via PM. Please check.
best wishes!
HI,
I am also in some of sort of situation like this. The flat which we purchased also have the MBR and common room combined together to form a big MBR. so i would want to separate them as the MBR and common room.
Can you please pass the contractor details so that i can contact him to do the work. We only need to separate the 2 rooms. no hacking is needed as far as i know.
please give the contact details
Hi Edenstrauss,
Kindly share Ah Cheong's contacts with me?
Carpentry Works contractor/ Electrical Works contractor.
I am still looking contractor to start renovation work next month.
Hi Edenstrauss,
Hi peter2K,
ah cheong doesn't deal with carpentry & electrical becox he specialises only in cement related works.
Hi edenstrauss,
Would you kindly share Ah Cheong's contact? I just bought a unit and would like to kick start my reno.
Regards,
Randolph
Hi edenstrauss,
Can you please give me the contact number of ah cheong????
Hi thomman,
I believed that I have dropped u a PM in response to your earlier request which had also been posted under this thread.
However, I didn't hear from u subsequently.
what's your budget for such an assignment?
Even though Ah Cheong is a specialist in cement-related works but his fees do not come cheap. The reason being that he uses premium raw materials and have a professional team who delivers premium workmanship.
So if you have a tight budget, then, ah cheong would not be suitable for your restoration works.
If this information is relevant to you, I would like to share that I had the following done by ah cheong based on our site measurements:
- hack wall to create new door entrance
- supply & installation of door frame
- install new wall (10 ft by 7 ft)
And it cost us $2,000 and this pricing does not include a door for the new bedroom.
It is relatively expensive if u compare his pricing to main contractors who do everything from tiling, plumbing to carpentry.
However, we are ok with paying premiums for excellent workmanship & great service. We want all our reno works in our home to last for a long time.
Kindly PM me directly if u r still interested in getting ah cheong to take up your restoration works.
Good luck!
Edited by edenstrauss
Hi thomman,
Good luck!
