Outcast
Creation Air-con
Hi everyone,
I believe everyone is concern when coming to choose their air-con unit for home. My opinion here is not about selecting the brands, but on the supplier/company that you're purchasing from.
I bought mine from Creation, price is comparable to Best Tech. My comments on their workmanship is bad (perhaps my expectation is higher), 1st installation on the piping after drilling the walls didn't touch-up exposing the holes. Piping wasn't laid nicely resulted the trunking popped out. Called them up to mend it, but after 2nd and 3rd time, they still done a lousy job covering the holes with white cement. In the end, I got my ID to do it. 2nd installation of the FCU, not installed properly upon request they did some adjustment here and there. After the technicians left, realised there is a crack on the FCU (Might be damage during installation). Too late to call back their office, as it's after office hours. But the office responsded nicely to give me an answer, they did. Waiting to get the cover changed.
Maybe they send the lousiest team to install my unit...sighz
But Mitsubushi Heavy Industries Inverter is really silent.
They used non-standard aluminum piping. That's our concern. Other vendors told us that this is 2-3x cheaper than copper. Will cost us a bomb if we need maintenance in the future. Think this statement might be true. Only heard this vendor is using Al piping so far. Have to come back to them whenever we have problem on piping huh?
Aluminum pipe is cheap but will surely cause problem in a short period of time after the installation. Even a G24 copper pipe is much better than aluminium pipe. I strongly advise members to go for copper pipe when it's come to air-con installation.
Please refer to below for the changing trend for air con installation. Aluminum alloy is now a better material because the grades are better now and fully tested by PSB!
Characteristic & Advantages over copper
Flaring
Requires lesser strength
Using the same set of tools as flaring copper
Higher thickness on pipe enables a more strengthen & even flare
Bending
More flexibility than copper
Do not kink easily compared to copper
Using the same set of bending tools as copper
Brazing
No argon gas, wire spool, gloves, shield or electricity required
1 Armourbraze rod allows up to 50 joints
Fast, easy & secured joints in 10 seconds
No turning of torches or rounding up gaps
4 times faster than brazing copper.
No additional flux required
Using the same torch and mapp gas
More saving on gas, time and brazing rod due to lower melting
point of aluminium
Estimated USD 0.05 per joint
Joints are stronger than main material
Swaging or Expanding
30% expansion from original OD
Using the same set of swaging tools as copper
Longer Length
Coils comes in 100m or 50m (bigger size) minimising joints
Lesser joints would mean lesser tendency of leakeage
Using lesser time, map gas & brazing rod
Longer length, lesser wastage
Pressure
Quatest (Vietnam) tested to meet ASTM B280-02 (9.4Mpa),
ASTM E 1251-99, TCVN 1832:2008 (18Mpa)
PSB TUV (Singapore) tested to meet ASTM B75 @ 1000PSI
Corrosion
48 hours salt water test before shipment
Corrosion rate is very much lesser than copper
Oxidisation rate is also lower making pipes clean and bright when exposed
Thermal Conductivity
Lower than copper by almost 50% which means lesser rate of condensation
Examples of aluminium tube being used
Air-conditioning in all automobiles
Refrigerator
Fan Coils of Air-conditioners
