Outcast 0 Report post Posted April 10, 2011 Hi everyone, I believe everyone is concern when coming to choose their air-con unit for home. My opinion here is not about selecting the brands, but on the supplier/company that you're purchasing from. I bought mine from Creation, price is comparable to Best Tech. My comments on their workmanship is bad (perhaps my expectation is higher), 1st installation on the piping after drilling the walls didn't touch-up exposing the holes. Piping wasn't laid nicely resulted the trunking popped out. Called them up to mend it, but after 2nd and 3rd time, they still done a lousy job covering the holes with white cement. In the end, I got my ID to do it. 2nd installation of the FCU, not installed properly upon request they did some adjustment here and there. After the technicians left, realised there is a crack on the FCU (Might be damage during installation). Too late to call back their office, as it's after office hours. But the office responsded nicely to give me an answer, they did. Waiting to get the cover changed. Maybe they send the lousiest team to install my unit...sighz But Mitsubushi Heavy Industries Inverter is really silent. Share this post Link to post Share on other sites
danard 0 Report post Posted May 1, 2011 They used non-standard aluminum piping. That's our concern. Other vendors told us that this is 2-3x cheaper than copper. Will cost us a bomb if we need maintenance in the future. Think this statement might be true. Only heard this vendor is using Al piping so far. Have to come back to them whenever we have problem on piping huh? Share this post Link to post Share on other sites
kevinliow 0 Report post Posted December 18, 2012 Aluminum pipe is cheap but will surely cause problem in a short period of time after the installation. Even a G24 copper pipe is much better than aluminium pipe. I strongly advise members to go for copper pipe when it's come to air-con installation.Please refer to below for the changing trend for air con installation. Aluminum alloy is now a better material because the grades are better now and fully tested by PSB!Characteristic & Advantages over copperFlaringRequires lesser strengthUsing the same set of tools as flaring copperHigher thickness on pipe enables a more strengthen & even flareBendingRequires lesser strengthMore flexibility than copperDo not kink easily compared to copperUsing the same set of bending tools as copperBrazingNo argon gas, wire spool, gloves, shield or electricity required1 Armourbraze rod allows up to 50 jointsFast, easy & secured joints in 10 secondsNo turning of torches or rounding up gaps4 times faster than brazing copper.No additional flux requiredUsing the same torch and mapp gasMore saving on gas, time and brazing rod due to lower meltingpoint of aluminiumEstimated USD 0.05 per jointJoints are stronger than main materialSwaging or Expanding30% expansion from original ODUsing the same set of swaging tools as copperLonger LengthCoils comes in 100m or 50m (bigger size) minimising jointsLesser joints would mean lesser tendency of leakeageUsing lesser time, map gas & brazing rodLonger length, lesser wastagePressureQuatest (Vietnam) tested to meet ASTM B280-02 (9.4Mpa),ASTM E 1251-99, TCVN 1832:2008 (18Mpa)PSB TUV (Singapore) tested to meet ASTM B75 @ 1000PSICorrosion48 hours salt water test before shipmentCorrosion rate is very much lesser than copperOxidisation rate is also lower making pipes clean and bright when exposedThermal ConductivityLower than copper by almost 50% which means lesser rate of condensationExamples of aluminium tube being usedAir-conditioning in all automobilesRefrigeratorFan Coils of Air-conditioners Share this post Link to post Share on other sites
