kopitayjr
Is My Quote Ex?
hi all sorry im a newbie, my quote a little messy,
just wanna check is my quote ex?any gurus here can help?
im closing up my existing open concept kitchen, this quote is only for kitchen renovation works.did not include lightings, basins and tap.
NO DESCRIPTION UNIT AMOUNT
1 Hacking & Demolition
a Supply labour to hack ext'g kitchen cabinet @ kitchen area Lump sum $550.00
b Supply labour to hack ext'g Island kitchen cabinet
c Supply labour to hack ext'g floor tiles @ kitchen area
f Haulage of sand & tiles + Removal of Debris ( Disposal of debris ) Lump sum $200.00
g Application of HDB renovation permit
2 Masonry Works/ Tiling Works ( tiles provided @ $2.40 )
a Supply labour & materials to lay 2' by 2' homogeneous floor tiles @ living area appro 40sqft $480.00
(inclu' of replacement of damage floor tiles during hacking process)
b Supply labour & materials to lay 2' by 1' homogenous floor tiles @ kitchen area Lump sum $1,450.00
inclusive of waterproofing
c Supply labour & materials to lay L-shape ceramic wall tiles (fridge area to door area)appro166sqft $1,129.00
d Supply labour & materials to lay kitchen ceramic wall tiles @ low wall area appro 60sqft $408.00
e Supply labour & materials to construct kitchen & fridge base Lump sum $300.00
f Supply labour & materials to construct L- shape hollow block wall c.w Lump sum $1,700.00
lido beam support + cement screed finish
j Supply labour & materials to plaster smooth jaggard areas after hacking Lump sum $200.00
3 Carpentry Works
a Supply labour & materials to construct low ht kitchen cabine c.w laminate doors appro 21ft $2,520.00
b Supply labour & materials to construct top hung kitchen cabinet c.w frosted glass appro 18ft $2,340.00
doors
c Supply labour & materials to construct tall ht cabinet c.w storage for oven area Lump sum $750.00
d Supply labour & materials to install solid top c.w backplash @ worktop area 21ft $1,575.00
e Supply labour & materials to construct full ht shoe cabinet c.w laminate finish Lump sum $980.00
f Supply labour & materials to construct veneer door c.w door & door frame for kitchen 1sets $680
g Supply labour & materials to install 01 set PD door for service balcany $280.00
4 Glass works
b Supply labour & materials to install 10mm tamperd glass panel @ new wall area 02 sets $760.00
5 Plumbing works
b Supply labour to install 01sink +1tap + bottle trap @ kitchen Lump sum $120.00
c Supply labour & materials to run / extend s.s pipe @ kitchen only PV $400.00
6 Miscellaneous
a Supply labour & materials to lay corrugated paper & plastic sheets @ whole house Lump sum $200.00
b Supply labour & materials to paint whole hse inclu' piping & doorframe Lump sum $1,500.00
c Supply labour to install false ceiling repair works + electrical works @ designated area PV $650.00
TOTAL AMOUNT : $19,172.00
do u guys think can get alot better price outside?
3 Carpentry Works
doors
4 Glass works
5 Plumbing works
6 Miscellaneous
The price is reasonable. Even if you can get a lot better price outside also doesn't mean that the services, workmanship and material are the same. If you click with the ID/contractor and he/she is trustworthy, why not give it a try?
I feel that the painting of whole house is a little bit overcharge. Perhaps you can try to nego with your contractor and bring it down to 1300, which is the market price. The rest of the items look quite reasonable IMO.
