rajini
Is This A Reasonable Quotation?
S/N DESCRIPTION AMOUNT($)
Kitchen & 2 Toilets:-
1 Supply hack and lay kitchen floor tiles c/w water proofing. $1,300.00
2 Supply and lay kitchen wall tiles up to ceiling height. ( expose area only ) $3,000.00
3 Supply and construct L-shape cabinet, fridge and washing machine base. $350.00
4 Supply and install L-shape top/bottom kitchen cabinet of 22ft. $3,850.00
5 Supply and install L-shape solid surface kitchen work-top of 22ft. $1,650.00
6 Supply and over-lay bath 2 floor tiles. $500.00
7 Supply and over-lay bath 2 wall tiles up to ceiling height. $1,300.00
8 Supply and construct hollow block lintol for bath 2 c/w tiles finishing. $200.00
9 Supply and re-located new entrance for bath 1. $200.00
10 Supply and seal-up existing door entrance using 63mm hollow block at bath 1. $250.00
11 Supply hack and lay bath 1 floor tiles c/w water proofing. $800.00
12 Supply and over-lay bath 1 wall tiles up to ceiling height. $1,300.00
13 Supply and install tempered glass shower screen at bath 1. $338.00
14 Supply and install aliminium bi-fold door at bath 1 and bath 2. $360.00
15 Supply and re-run whole house stainless steel pipe. $550.00
16 Supply and re-run sink, wash basin and washing machine inlet/outlet pipe. $180.00
17 Provide labour to install toilet bowl, wash basin heater and toilet accessories. $350.00
18 Supply and install stainless steel bin chute. $168.00
Miscellaneous Works:-
1 Supply hack and lay 600mm x 600mm homogeneous fllor tiles c/w skirting ****, 3 bedroom and store room. $6,200.00
7 Supply and construct false ceiling **** room. $360.00
8 Supply and construct 2 sets L-box **** and dining room. $910.00
9 Supply and plaster whole house wall and ceiling. $1,500.00
10 Supply and paint whole house wall/ceiling, bedroom doors/frames and all expose pipe. $1,050.00
11 Supply and do chemical washing after renovation works. $250.00
Electrical Works (Total rewiring) $2k+
I hope that people here in this forum can give me some much-needed advice on whether this is a reasonable quote, cos my gut feeling says other wise.
Appreciate all comments.
Do check with them per foot run charging at how much. Mine was quoted ard 100-110 per foot run for 11ft top cabinet
10 Supply and seal-up existing door entrance using 63mm hollow block at bath 1. Reasonable $250.00
14 Supply and install aliminium bi-fold door at bath 1 and bath 2. Cheap $360.00
1 Supply hack and lay 600mm x 600mm homogeneous fllor tiles c/w skirting ****, 3 bedroom and store room. Cost of tile selected? Up to how much? MIne was quoted up to S$3.60 per square foot $6,200.00
10 Supply and paint whole house wall/ceiling, bedroom doors/frames and all expose pipe. HOw many colour selection? $1,050.00
Edited by stinker808
It seems to mi tat the quote is slightly high lo...which id u went to?
Maybe you can try to get a second quote to compare. you can try Homeworkz at turf city, i had my place done up by them their price is quite reasonable. My ID was garfield moblie is 96800136.
hi.. maybe ur flooring is abit expensive... must see whether wat's e pricing to select e living room floor tiles like >$3 or < than $3.. i find others quite reasonable eg e overlay of both toilets walls n floors without hacking cost around 2k rite???
what's the floor area of the different areas of your house?
Price is only 1 part of the equation, you need to know on a per foot basis whether issit cheap or not? You didn' provide enough details. Your quote can actually be very good if the space size you are refering to is large, so how to compare?
Calculate the quote on a per foot basis for better clarity. Then come back and compare with the market rate.
There are certain market rates for most items. If the price differs substantially from the market rates, check with your ID/contractor, what is he offering for such a higher price?
