Ledtalk
Changing Home Lighting To Led Lighting
hi there, i would like to know how much it will cost to change every light in my 5 room flat.
Its not a new flat ( 13 years old) with flourescent lighting ( circular Tubes) which is plug and remove type.
I also like to know if the existing housing fixture which is circular can be used fit LED lighting.
i cant really seem find the equivalent LED circular tube ( on the internet)
does anyone know if they sell Led circular tube that is the same as the 30w circular flourescent tube which everyone is using?
check out this website www.lightings.com.sg , make a trip down to one of their outlets
the guy I spoke to at jln besar was very helpful. If I can recall correctly one led light cost around $45-60 depending on the wattage
not forgetting that u need a driver for every led light. one driver is around $25 i think.
Ok can we jus get the round tubes?
<!--quoteo(post=612739:date=Feb 22 2011, 03:53 AM:name=as2011)--><div class='quotetop'>QUOTE (as2011 @ Feb 22 2011, 03:53 AM) <a href="index.php?act=findpost&pid=612739"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->check out this website www.lightings.com.sg , make a trip down to one of their outlets
not forgetting that u need a driver for every led light. one driver is around $25 i think.<!--QuoteEnd--></div><!--QuoteEEnd-->
For circular try not to get LED. It's not standardize yet. You can try on T6 Circular or normal T9 Circular tube with Electronic Ballast.
