Drexter
Laminated Flooring
I think much better to just spend some extra money on parquet...laminated def not worth it esp if spill occurs .... damage too easily... :sport-smiley-004:
If you do laminate flooring, it's better to choose a slightly more expensive one like Kronotex, Vohringer, Berry Floor, Pergo, Supreme. Those are better resistant to water and have better gaps. Really check the base material when you see the samples.
Cheap, cheap laminate flooring spoils more easily due to inferior base material and top layer...
Remember that laminated flooring is only water resistant not water proof. So try to wipe away any liquid form immediately if possible and dry the area which is being affected. Without proper maintenance no matter how good is the quality the effects will still be out.
I don't think this is correct. In term of durability, laminate can take the torture much better than parquet. Try using a key and scratch a parquet flooring and you will know what I mean. Laminate is tough to scratch. One thing good about parquet is that, once scratched, you can still sand off the surface by the professionals but you can only do it a few times. Laminate, once it's damaged, it's damaged. To replace that damaged area, you must replace from area that is nearest to the wall to the actual damage area due to the interlocking design of each piece.
All in all, biggest enemy of laminate should be water. Not sure if there are better or poorer water resisting compare to parquet. I believe, parquet should win in this area. I'm currently contemplating or laminating my whole house with the SC3 series Supreme laminate. Current flooring is marble and we don't really like the pattern. Also, we need to reposition some of the room's door which will damage the marble flooring when we do. Don't like homogenous tiling too as we don't like grouts. So, seems laminating is the best option.
All in all, biggest enemy of laminate should be water. Not sure if there are better or poorer water resisting compare to parquet. I believe, parquet should win in this area. I'm currently contemplating or laminating my whole house with the SC3 series Supreme laminate. Current flooring is marble and we don't really like the pattern. .............
Try not to overlay the laminate on marble.
Reason being? No grip?
marble flooring will absorb cold and hot. so when marble generate heat there will be some water vapour therefore in long time runs guess u know what will happen.
Will take note of that... Thanks for the advice....
Parquet will warp too after repeated water contact! The base material of laminate is actually very compressed so it will not absorb water easily. But water can cause the top layer of the laminate to "bubble". This will break after some time...
BTW Berryfloor has a collection of water-resistant laminate called HydroPlus:
http://www.berryfloor.com/collection/riviera
Woodculture carries Berryfloor in Singapore:
http://www.woodculture.com.sg/
Overlay on stone/marble/ceramic floors is not a problem if you don't have direct sunlight shining on your floor (i.e. small windows like in old HDB). They will put a thin layer of absorbing foam. The only area that needs some hacking is the skirting but that is relatively cheap.
Edited by designez
My cousin just moved into a resale 4 room HDB in woodlands and he is using laminated flooring over the existing ceramic tiles. It looks nice and elegant with the woody look. Beside cost-saving factor, He has a toddler who always around- given that there is no grouting compared to other stones tiles and hence evenness across the whole house, this becomes a safer option for his kid.
However,on a personal note, whenever i walk, i could hear the hollow sound coming from underneath it. If you were to run/walk with a heavier step, you could feel the "trembling" sound hovering, especially when your house windows are closed (air con room). I would still prefer natural stone tiles :)
I heard those from Germany ones are better....anyway, my id proposed Supreme Executive ...are they good quality? We are changing our laminate flooring for 3 bedrooms. REally want to choose the BEST quality to safe all the trouble after that....anyone can advice? :P
I've a floor laminates package to let go.
From Evorich, country of origin germany.
Anyone interested, please pm me for details :)
I strongly recommend Berry Alloc. super good service n I have confidence in their product.
You are right, i notice this with my friend's house as well, antural is the way to go for me as well
Have you completed your flooring works? I am planning to do flooring renovation as soon as possible. I have selected Polyaspartic Coatings for my garage flooring but am still confused on the interior part . I heard that laminated flooring won't last long. Is that true? please share your opinions.
Laminates from Germany has the best look & durable grooves. But ALL laminates are not water proof. they will warp with moisture/water. I go expo & see supreme (i think) they put the whole piece in water.. was impressed.. than i check with my ID, he say..1 full piece is not a problem cos all the sides are protected/waxed but when you cut any laminate..it's MDF inside.. water touch..sure spoil. He say use laminates if you want to go for the look & yet save money.. but if you need water proof like in kitchen or if you have pets or children who will spill water etc... use vinyl planks.. suggested those that look like wood.
Personally, i went to look at HERF & Galaxy flooring.. they both got 10 - 14 designs i think.. now considering these. Maybe going for galaxy cos the missus like 1 color.:)
