tklim
Quotation For Hdb 3 Room
Is the quotation resonable?
A Hacking Works
Provide labour and tools to do the following:
1 Hack off existing floor tiles and skirting **** and Dining $ 450.00
2 Hack off existing skirting at Master, Common Bedrooms and store $ 300.00
3 Hack off existing floor and wall tiles at Master Bathroom $ 550.00
4 Dismantle existing bathroom fitting at Master Bathroom $ 100.00
5 Hack off existing floor tiles at Kitchen $ 450.00
6 Hack off existing cabinet base $ -
7 Hack off existing sink and stove support $ 80.00
8 Dismantle existing kitchen cabinet $ 200.00
9 Demolition of wall L900mm x H2100mm between Living and Common Bedroom
to create a entrance for new balcony $ 180.00
10 Demolition of Store room walls L1950mm by L1200mm by L1950mm $ 350.00
11 Demolition of Master Bathroom entracne wall $ 200.00
12 Demolition of L1800mm full height wall between Master Bedroom and Kitchen $ 300.00
13 Demolition of existing kitchen entrance wall $ 180.00
B Masonary Works
14 Provide building materials for Living, Kitchen and Master Bathroom $ 850.00
Living / Dining
15 Supply 600mm x 600mm homogeneous floor tiles @ $3.00 psf x 340sqft $ 1,020.00
16 Provide labour to lay floor tiles and skirting (280sqft) $ 1,150.00
Kitchen
17 Supply 300mm x 600mm homogeneous floor tiles @ $3.00 psf x 200sqft $ 600.00
18 Provide labour to lay floor tiles (182sqft) includes waterproofing $ 750.00
19 Provide labour to construct cabinet base $ 180.00
20 Provide labour to construct fride base $ 60.00
21 Provide labour to construct washing machine base $ 60.00
Master Bathroom
22 Supply ceramic / homogeneous wall tiles @ $3.00 psf x 250sqft $ 750.00
23 Supply anti-slip homogeneous floor tiles @ $3.00 psf x 55sqft $ 165.00
24 Provide labour to lay floor and wall tiles including waterproofing $ 1,350.00
25 Provide labour to construct kerb $ 40.00
Others
26 Provide labour to patch up the affected area after demolition of walls $ 420.00
C Plastering Works
27 Plaster smooth over kitchen wall tiles $ 650.00
28 Plaster smooth to affected walls after hacking $ 400.00
D Laminate Floor Board
29 Supply and install laminated floor board c/w matching skirting for Master and
Common Bedrooms using France Clip 300 sound with underlay $ 1,860.00
E Partition Works
30 Construct L1800mm by L1200mm x full height partition wall using waterproofing
board to extend Master Bathroom $ 380.00
31 Construct L2100mm x H1050mm partition wall using 12mm thick gypsum board
to create a new Balcony area at Common Bedroom $ 250.00
F Door / Window Works
32 Supply and install 1 no. of veener door frames ($260 each) $ 260.00
33 Supply and install 1 set of veener door with lever lockset ($240 each) $ 240.00
34 Supply and install 2 sets of aluminium bi-fold doors for both Bathrooms $ 300.00
35 Supply and install 1 set of aluminium lourve windows for Master Bathroom $ 240.00
36 Supply and install 1 set of veener sliding door with frame $ 650.00
G Glass Works
37 Supply and install 1 set of L-shape (2 fixed + 1 sliding door) shower screen using
10mm thick clear tempered glass for Master Bathroom $ 650.00
38 Supply and install 1 fixed panel L2100mm x H1000mm of 10mm thick tempered
glass above Balcony / Common Bedroom partition $ 450.00
39 Supply and install 1 set of swing door using 10mm thick tempered glass at Balcony $ 380.00
H Ceiling Works
40 Supply and install false ceiling **** area $ 850.00
41 Supply and install false ceiling at Master entrance $ 280.00
42 Supply and install false ceiling at Common Bedroom $ 550.00
43 Supply and install false ceiling at Master Bedroom $ 460.00
I Painting Works
44 Painting whole unit's internal walls and ceiling using ICI / Nippon paint
includes underocate oil sealer to affected area $ 950.00
J Plumbing Works
45 Supply and install hot+cold water piping for Master Bathroom and Kitchen $ 650.00
46 Supply and install inlet / outlet piping for whole unit $ 250.00
47 Provide labour to install 1 set of kitchen sink and tap $ 70.00
48 Provide labour to install 2 sets of wash basin and taps ($45 each) $ 90.00
49 Provide labour to install 2 sets of toilet bowl ($80 each) $ 160.00
50 Provide labour to install 2 sets of handspray ($10 each) $ 20.00
51 Provide labour to install 1 set of bath mixer and shower sets ($50 each) $ 50.00
52 Provide labour to install 2 sets of bathroom accessories ($20 each) $ 40.00
53 Provide labour to install 1 set of storage heater ($100 each) $ 100.00
K Cleaning Works
54 Acid / Chemical wash the whole unit upon completion of renovation $ 180.00
L Others
55 Supply and install 1 set of flat design rubbish chute $ 180.00
56 Provide corrugated cardboard during renovation $ -
57 Haulage Service (Upload building materials and clearing all debris) $ 300.00
M Carpentry Works
Living / Foyer Area
58 Design, fabricate and install L2000mm x H500mm x D500mm shoe cabinet
in laminate finish with 4 nos. of ABS trimming doors $ 1,050.00
59 Design, fabricate and install L2000mm x H1000mm x D100mm divider / feature
wall in laminate finish to divide shoe cabinet and TV console $ 550.00
60 Design, fabricate and install L2000mm x H250mm x D500mm TV console
in laminate finish with 3 nos. of ABS trimming drawers $ 1,050.00
Kitchen
61 Design, fabricate and install L1900mm x D600mm by L3100mm x D800mm
L-shape kitchen cabinet in laminate finish $ 3,300.00
62 Fabricate and install full height cabinet to box up existing sewage pipings $ 300.00
63 Design, fabricate and install L1600mm full height cabinet in laminate finish
with 4 nos. of ABS trimming doors $ 1,500.00
64 Fabricate and install L1900mm x D600mm by L3100mm x D800mm solid surface
worktop for kitchen cabinet $ 1,485.00
Master and Common Bedrooms
65 Design, fabricate and install L2600mm full height wardrobe in laminate finish
with 6 nos. of ABS trimming doors $ 2,250.00
66 Design, fabricate and install L500mm full height wardrobe in laminate finish
with 1 no. of ABS trimming door $ 500.00
67 Design, fabricate and install L2000mm x H760mm Study table in laminate finish
with 4 nos. of ABS trimming drawers $ 1,050.00
Master Bathroom
68 Design, fabricate and install L1100mm x H800mm vanity cabinet in laminate finish
with 2 nos. of ABS trimming doors $ 400.00
69 Fabricate and install 1 set of L1100mm solid surface vainty top $ 280.00
70 Fabricate and install 1 set of clear mirror for vainty $ 200.00
Total Cost $36,540.00 for HDB 3 Room corner
A Hacking Works
B Masonary Works
Living / Dining
Kitchen
Master Bathroom
Others
C Plastering Works
E Partition Works
G Glass Works
H Ceiling Works
I Painting Works
J Plumbing Works
K Cleaning Works
L Others
M Carpentry Works
Living / Foyer Area
Kitchen
Master Bathroom
seems like your quotation is really on the high side.
im oso doin my 3room flat, extending bathroom into master bedroom and add a doorway.
same style!
Pm me if you want to compare quotes. can pass you my contact. :)
