Is 10K enough to do up my request for 3NG flat?
Works Request for this reno:-
1. Laminating of Hall & 2 Bedrms
2. 2 toilets
3. Full electrical works
4. Change of all wooden doors and main gate
5. Knock down wall btw living and kitchen and build partition in btw
6. Painting of whole hse
7. simple kitchen cabinet but only ground
... etc
2. 2 toilets
... etc
Ans: NO :paint:
Is 10K enough to do up my request for 3NG flat? NO! see estimate below
1. Laminating of Hall & 2 Bedrms - estimate about $2500, assuming you hve 500 sqf for living + 2 bedrooms and using relatively ok laminate
2. 2 toilets - toilet tiles are not cheap as the wall is quite a big area. usually 2 toilets costing $10k but if you on budget, you can try to do it for $7k
3. Full electrical works - usually abt 1.5k -2k depending on how many points and how old is your flat.
4. Change of all wooden doors and main gate - main door $1k if fire rated, grille is $500 or so and bedroom doors are $300 for both.
5. Knock down wall btw living and kitchen and build partition in btw - knocking down a wall abt $1k lah.
6. Painting of whole hse - 3 room flat abt $800-$1000.
7. simple kitchen cabinet but only ground - Average of kitchen cabinet + solid surface $200 per sq ft.
All these haven't incl sanitary ware like toilet bowls and basin and taps... and lightings. these can costs up to a lot... mine is nearly $7k.
Edited by May_dream1
