ArchAngelz
Engineered Wood - Pine Or Hevea Core
I've done some research which suggests that for Singapore, if we want to use engineered wood floor, we should get one which uses hevea as the core. Yet others suggests that it makes no difference.
My question is, does it really make a difference? The shop says that humid weather like Singapore use hevea better; but of course they could be just getting business for themselves! :) Then there's another shop in SG that sells engineered wood using pine core; won't run into problems?
Any insight would be appreciated.
i wouldnt claim to be an expert in this. a quick check on wiki shows that hevea is the botanical name of rubber tree.
rubber wood is very unstable, prone to warping and rots easily when soaked in water.
if hevea = rubber wood (you got to check out with the shop), then what the shop claimed about hevea being more suitable for singapore's weather is incorrect.
rubber wood and pine as the core should have the same problems.
