shin365
Need Help With Contractor Quotation
Hi everyone, below are the quote that my contractor send me, wish to find out from all the expert is there anything wrong with the quotation.
Hacking for kitchen wall and floor tiles
Hacking for both bathroom wall and floor tiles
Dismentle and dispose off of existing kitchen cabinet/sink support
Dismantle and dispose of existing both bathroom pedestal pans
Dismantle and dispose of existing both bathroom wash basins
Dismantle and dispose of both bathroom door / door frames
Masonry works
Supply and lay heavy-duty homogenous flooring for kitchen($3.00psf)
( 5 years warranty )
Supply and lay non-slip homogenous flooring for both bathrooms ($3.00 psf)
Supply and lay full height designers' wall tiles for kitchen
only ($2.80 sqft) (<330 sqft) ( 5 years warranty)(No wall tiles replace plaster smooth)
Supply and lay full height designers' wall tiles for both bathrooms
($2.80 sqft)(<380 sqft) ( 5 years warranty)
Applications of waterproofing membrance for kitchen and both bathrooms
Plumbing works
Supply labour and materials to change copper piping for kitchen
and both bathrooms ( cold )
Supply labour & materials to run washing machine inlet/outlet pipe
Supply labour and material to run sink inlet/outlet pipe
Supply labour to install 2 sets pedestal pans and wash basins
Supply labour to install 2 sets instant heater
Supply labour to install 2 sets toilet accessories
Miscellaneous
Supply and install white powdered-coated Aluminium bi-fold door
for both bathrooms
Application of HDB permits
Lay protection sheet for flooring
Chemical washing for whole unit flooring
Total $10988
Kitchen - Supply labour and materials
Supply labour and tiles to construct cement base to recived kitchen cabinet in L-shape. $280.00
Supply labour and tiles to construct cement base for fridge in tiling finish. $100.00
Supply labour and tiles to construct cement base for washing machines in tiling finish. $100.00
Design and fabricate Top and Bottom kitchen cabinet in laminate finish c/w ABS Trimming solid ply doors $1,650.00
include of box-up main sewage pipe. ( 10,600mmL/ 35 ftL ) ( c/w 1 years full warranty ) (Top-up 15Ft length)
Supply and install 2 pcs glass panels FOC
Supply and install stainless steel dish rack FOC
Up-grade of door closer to soft closer.(anti-slam) FOC
Up-grade of drawer runner to heavy-duty "fully retrackable runner track. FOC
Custom made solid surface top for kitchen worktop c/w 50mm fascia include 60mmht backsplash NIL
( 4800mmL/ 16 ftL )
Custom made low-ht wall behind the sink in solid ply wood in laminate finish .
Custom made colour glass wall panelling to kitchen sink cabinet in-between . $520.00
( 3600mmL/ 12 ftL x 700mm ht )
Supply install stainless steel rubbish chute to kitchen $170.00
Supply and paint weathshied paint to kitchen wall. NIL
Supply & install plaster board to box-up main sewage pipe in paint finish . FOC
Supply labour and tool to hack off existing kitchen entrance arch frame mosia tiles and make good the surface . FOC
Up-grade of copper pipe to stainless steel piping. FOC
Supply labour to convert squat to seating bowl type c/w water proofing menbrance . $220.00
Supply labour and emulision painting to whole unit in ICI/nippon paint .(5+1) $1,000.00
Free selection of 3in1 or nippon easy wash paint. FOC
Supply labour and enamel paint all frame,gate and all main sewage pipe. $200.00
Supply labour of haulage for up-loading materail,clearing debris and supply of sand. $450.00
Supply install bronze/silver alum frame 2section sliding window to living hall and bedroom 2 in tinted glass.(40 sqft) $800.00
Supply install bronze/silver alum frame 3panel sliding window to kitchen in tinted glass infill. (32 sqft) $380.00
Supply install bronze/silver alum frame casment window to master bedroom in tinted glass infill. ( 16 sqft) $216.00
Supply install bronze/silver alum grilles to whole unit window.(except bathroom) ( 88 sqft) $620.00
Supply install wrought iron gate to main entrance . $450.00
Supply install solid naytoh timber door to 2 bedroom and store room entrance in lockset and stopper.(3nos) $750.00
Supply & install plaster board to box-up 2 bedroom and store room door above lorver window in paint finish. $100.00
Provisional of supply labour and materail to rewiring of whole unit electrical lighting,power point,tel,scv,water heter and $1,600.00
total damage is 21K
also wanna check out what bank offer the best reno loan?
Edited by shin365
It will be better if you get them to list out item by item price and more details of the item or materials used.
(Exp: Design and fabricate Top and Bottom kitchen cabinet in laminate finish c/w ABS Trimming solid ply doors $110/ftr Total 23ft $2530.)
So that you be clear of how much you are been charge item by item then just giving you the lump sum.
Cheers
Edited by squareroomid
Masonry works
Plumbing works
Miscellaneous
for both bathrooms
( 4800mmL/ 16 ftL )
Miscellaneous - Supply labour and materials
air-con point.
total damage is 21K
Yah, you better ask them list out item by item more clearer picture.
BTW, you no need the contractors to install wardrobe or false ceiling ? How about the flooring for the living and bedrooms ? All no need to do anything ? =/
hi everyone, i have updated the quote with all the pricing.
living room and bed rooms floor tiles not doing.
false ceiling not doing also.
that about all
nippon or Pentalite better?
For me, I prefer to recommend ICI Pentalite, as its good material. Nippon materials seems to be getting bad recently.
Cheers
(These item are included in hacking by hacker. Extra profit for the contractor)
(Too Expensive @ $20 per SQFT ($800 / 40 Sqft = $20)
(Acceptable)
(Acceptable)
(Acceptable)
(Near Cost Price)
(Acceptable)
(Cost Price)
(Normally charge by per point basis, change total how many lighting point, electrical point, etc.)
Hope this helps.
Cheers
squareroomid thanks for the help.
this is 2 section 2 panel per window. meaning there is total 4 panel. 2 top 2 bottom.
Hihi,
will you be able to plss advice me if my quote is okie too ? I find the general works are rather steep....pls assist.......thank u
http://www.flickr.com/photos/57043012@N07/5435740466/
http://www.flickr.com/photos/57043012@N07/...in/photostream/
(Acceptable)
(Acceptable)
(Acceptable)
(Near Cost Price)
(Acceptable)
(Cost Price)
Hope this helps.
Cheers
Can you PM me the contact of your contractor? The one i have apparently quotes me for every single dismentling item ...and charges me every installation......i be broke by the end of the day......
Masonry works
Plumbing works
Miscellaneous
for both bathrooms
Total $10988
( 4800mmL/ 16 ftL )
total damage is 21K
Hi Shin365,
can you share w/ me your contractor's contact?
Actually, what is the difference between contractor or ID? Do they do the same job?
Hi sng28,
do you think Shin365's contractor quotation is more competitive than yours?
Thank you all for your enlightenment!
