lazybum9
Our 1st Home...
my first time seeing a dbss photos...heeee... really looks like can bring luggage and move in le... :)
the toilet bay window idea is very "condo", i like!
nothing much to renovate ba...?
yes u can move in straight which a number of folks have done so...but i wouldn't do tt cos i want all defects to be rectified 1st before moving in...probably those folks are renting place now so got to move in fast...
going to do some carpentry work...
I have bay window in the toilet too. Solution: roller blinds, about 80-90% opacity. So it's still bright in the daytime w/o lights and nobody can see you.
i'm thinking of roller blind too but not sure of its blocking effect at night...will a curtain maker be able to advise???i intended to asked mr chew to work on my curtain...do u have pictures and your contact to share???
mine is low floor so opp is the carpark...what's privacy film???where can i find???
I think reglxl had it... You check her blog again. 3M brand if I am not wrong.
sorry my privacy film only works during the day
but at night, can see everything when you turn on the light :P
lol
i don't wanna be tt kind of movie star... :~
dont worry everything can be sorted out :)
maybe you can use perforated blind?
confirm cannot see anything from the outside during day and night.. also wont block out the sunlight completely
example
http://www.directwindowblindsandshades.com...cal-Blinds.html
Edited by reglxt
if you got alot of money to spare maybe can consider this
Smart Glass..
to do up your hall's window prolly can cost up to 10K but its way too cool...
i think they use this for LRT that is very near to HDB in some areas
Smart Glass..
wah really very cool man...sure cost a bomb man...
i am planning to place my tv infront of my bed on the baywindow...u will notice tt the tv point is below the baywindow (see 1st picture)...once i plugged in the stiff cable, will cable be protuding out alot as shown in 2nd picture??? think i have around 500mm or less walk clearance between bed edge and baywindow...seems like will hit the protuding cable every time walking past it... anyone knows something like a L connector tt will not let the cable protude too much out??? :o
Is it good idea to place tv at bay window? Tv will get sunshine which will reduce the life of tv.
daytime will close off curtains so sunshine will not come in...
washer in the bathing area is a good idea but got to seriously consider carefully future usage of shower area...
i don't think u can put a fridge at the intended washer area...i think the washer area length is around 700+mm, even if u can squeeze a fridge there, it got to be those low height ones below 1600mm...cos the clothes hanging device pulled down to the lowest level is around 1600mm...if u have a fridge of height 1700mm, u will not be able to use the hanging device le...unless u wanna remove it totally...
yah.. still thinking about it.. another idea is still moving the washer to the common toilet bathing area and use that area to build cabinet or put a table for oven/microwave. I can't find anywhere to place oven in the kitchen.
don't really have a choice.. after the bed is in, the only place for tv is really the bay window. Unless ceiling mounted tv?
Even if you shut the curtains the heat will still get unto the tv. Really can't put elsewhere?? A waste of your nice baywindow too.
