lazybum9
Our 1st Home...
MBR toilet baywindow
can sit there and scrub feet now...but got a problem, super exposed to public man, no privacy :bath: ...any suggestions??? i'm thinking of those roller blinds but not sure if at night switch on lights outside still can see silhouette??? i hope not to do frosted windows cos still wanna have daylights coming in...HELP!!! :~
:bangwall:
y they built a bay window at the toilet? Give free show for yr neighbors to see when u're bathing? :notti:
Yr hse still need to do reno? looks like all done, anytime can move in after defects rectified.
MBR toilet have baywindow?? wow!! like Ritz Carlton leh... hahahaha.... what you have outside of MBR toilet? hhmm.... what abt those privacy flim??
I plan to get fridge depth 725mm one...side by side doors...will be out by 125-150mm and can open doors without hitting walls...
Toilet got space to put washer??? Unless u plan to remove a basin???isn't the washer area enough for 1 dryer L600xD600xH850???Unless u wanna get dryer to stack on top too then not enough height clearance at washer area...
washer put at the bathing area so bath only in MBR toilet since it is only me and wife who need to bath now. Common toilet keep it dry lo.. just an idea.
then either i put the fridge to the washer area and build a cabinet at the fridge area or build/extend the cabinet at the washer area to put microwave or oven. So far all these area ideas. Not sure if it can be done or will i go ahead with it or not..
I would think main con got to hack away the tiles and re-do cos the gradient was not done properly first time...Ya kitchen is small and I suspect 4 & 5 rm kitchens are this size too except they got a service balcony...
i went to a 4 room and 5 room unit too.. 4 room is the same.. 5 room i tihnk depends on which stack. those facing kallang river have a bigger kitchen. more like a square.
how about plants? if not privacy film lor.. no choice
but at night when u turn on the light .. can see everything heee..later become movie star huh heee
check out how your neighbours are doing it? might be a gd conversational topic to engage your new neighbours... :P
my first time seeing a dbss photos...heeee... really looks like can bring luggage and move in le... :)
the toilet bay window idea is very "condo", i like!
nothing much to renovate ba...?
its the car park so not neighbours only you can have conversations with.... anyone that park at higher multi storey carpark can all have fun together... hahaha.... :D
I have bay window in the toilet too. Solution: roller blinds, about 80-90% opacity. So it's still bright in the daytime w/o lights and nobody can see you.
:bangwall:
doing some carpentry work then all set to move in le...hopefully the defects rectification won't take too long...
mine is low floor so opp is the carpark...what's privacy film???where can i find???
washer in the bathing area is a good idea but got to seriously consider carefully future usage of shower area...
i don't think u can put a fridge at the intended washer area...i think the washer area length is around 700+mm, even if u can squeeze a fridge there, it got to be those low height ones below 1600mm...cos the clothes hanging device pulled down to the lowest level is around 1600mm...if u have a fridge of height 1700mm, u will not be able to use the hanging device le...unless u wanna remove it totally...
i don't wanna be tt kind of movie star... :~
