ghostrider201
Is Our Reno Expensive?
Hi...
Please read the below mentioned & comment if you think our contractor is ripping us off???
$280 -->acid washing of floor (3room flat)
$2650--> 2 x wardrobes
$700--> semi-hollow door
$1800--> rewiring of electrical points
cheers...
Hi...
$280 -->acid washing of floor (3room flat) Yes
$2650--> 2 x wardrobes depends on length and internal structure, laminates used etc...
$700--> semi-hollow door very expensive, assuming its normal bedroom door
$1800--> rewiring of electrical points depends on number of points, complexity and whether its designer switches
cheers...
hi gimz63251073...
thanks for the heads up but can i ask what price shd the the acid washing of the floor be???
cheers...
:) mine is about $200 or $180...can't remember le.
Doors u can try Yontat. If i remember correctly, they quote me is $260-$280 for semi hollow bedroom door.
Electrical pricing u may have to try to dig out info from the renovation works category.
Carpentry is the most tricky...u probably have to get another contractor to quote u for it for comparisons.
Cheers!
If it's for 1 door, $700 should be a 100% solid timber door.
For HDB type of door, if u r not going for a veneer door, or a designer type of timber door, then nyatoh, semi-solid door is good enough. That one will allow u to paint over or when there r scratches, u could touch up by using sandpaper & varnishing it again.
If it's veneer, any scratches or damages are not reversible.
acid wash is purely a labour cost. my contractor charged me about 250 i think, for my 4rm hdb.
$700 for semi hollow door seems ex... i paid about 320. usually is 280, but the door guy say cos we choose the more expensive key/lock set, had to pay more.
indeed, carpentry work for wardrobe u need to compare with a few quotes. depending on size. i was quoted abt 220/ft.
I have one contractor quoted me $200 for acid washing for 5-room flat.
As for cabinet, I have also a quotation for 200/ft for casement door wardrobe, or $220/ft for sliding door wardrobe.
For doors, classic door is only $130-145, whereas solid wood door will be $250-280 per pc.
