LOL.. than she must keep an eye on the run liao... . ; p
each page fixed number of post one. so can count. :dribble: :dribble:
lazy to count lah
<!--quoteo(post=611350:date=Feb 15 2011, 11:13 PM:name=insane)--><div class='quotetop'>QUOTE (insane @ Feb 15 2011, 11:13 PM) <a href="index.php?act=findpost&pid=611350"><{POST_SNAPBACK}></a></div><div class='quotemain'><!--quotec-->bo bian la... look forward~~ <img src="http://www.renotalk.com/forum/public/style_emoticons/<#EMO_DIR#>/smile.gif" style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />
don make the same mistake again lo..<!--QuoteEnd--></div><!--QuoteEEnd-->
Ya so I will go buy by myself hansgrohe items without my contractor.
Hi May,
I am trying to read and learn from your blog.
If we go without our contractor to the lighting or other shop.
The so call retail price show is it already include for contractor comm in, even we go without contractor?
Hi May,
whatever price is shown on the tag, if you go without contractor, you can bargain much lower. but if you go with contractor, maybe they will discount 10% or so.
understand now, thanks.
Btw, you have install city gas heater right. Can let me know how u feel about it so far?
Read from the thread that someone have experience lots of water condense from the hot heater and then will have water droplets or pool of water on the floor.
beluga is the one that have a lot of water condensation. That is because, his common/master toilet windows faces the service yard. So the hot water was flowing out from the windows to the service yard then condensed around that area. it was not due to the gas heater that was installed at service yard.
it also means that the gas heater can have very hot water and so much steam that it can flow out from the windows to the service yard.
for me, i like the easy usage of gas heater. every time you on your tap, hot water will flow out in less than 10 secs. if you use electric storage heater, you might need to wait around 10 mins. if you use instant heater, the hot water will not be hot enough.
But the only problem is adjusting to the heat you like. its more difficult to adjust.... need trial and error but once you get it, try not to adjust the heater temp anymore.
I still cannot get it right for the mbr. It seems good for common bathroom. I suspect it may be the pipe distance.
then make it hotter so that the Master toilet have the right temp loh cos most of the time you use it there mah....
but pipe distance shouldn't be so far apart leh. hhmmm..... what abt the shower head?
May, i still could not ready digest the part on - [his common/master toilet windows faces the service yard. So the hot water was flowing out from the windows to the service yard then condensed around that area. it was not due to the gas heater that was installed at service yard.]
Cannot really understand, is he install the heater at the wrong place or no way to adjust as its the layout of the toilet and service yard problem?
the gas heater definitely have to be at service yard or kitchen. depending on the layout of your flat. if you have service yard, then will be there. if not, will be in kitchen.
i am not sure his common room or master room that have windows flowing to the service yard. Assume its the common toilet. ignore where the gas heater is. The problem is the windows. When we shower with hot water, sure will have vapour, right? The vapour will go out through windows. then when the vapour flow out of windows, then its not outside the flat but into service yard where there is another set of windows, the vapour will hit the service yard windows and condensation will happen. Cos the air outside is cooler than the hot vapour.
he can actually adjust the hot water not to be so hot so less vapour will flow out but he says he like hot hot super hot water.
but the pipe laying no short cut leh. contractor said something like cant drill another hole through the beam and have to use original. anyway....
if i put the mixer to only hot, it is extremely hot. then i slowly turn to let in cold water. it becomes ok....then suddenly cold. give up. dont know where's the cut off point.
then adjust the temp on the gas heater to lowest loh...
got hot and cold water pipe mah.then later got less water cos if only hot water comes in.but i will try adjusting to lower temp see how.
LOL... I have huge problem with mixer. Never get it right :bangwall: :bangwall:
I can never understand the logic of the right side or left side (hot / cold). I will always have to turn to 1 side, wait to see if hot or cold, than adjust accordingly.
That's why I still stick to instant heater, easier for me to control temperature while showering. :sport-smiley-004: :sport-smiley-004:
left is hot lah... hehehe.... instant heater not hot enough leh.. and doesn't look nice in toilet. hahaa....
