Edlyn 0 Report post Posted September 7, 2011 Good technical info arowana. I understand a reasonable brightness is about 500-600 lumen if you are working in office. I suppose LED light can work as a support light/secondary light... when watching TV or relaxing. Btw, I chance upon a E27 LED that is 5W but pretty powerful compare to those energy saving CFL type. I have asked my friend to get ma 1 and will try it out on exisitng home chandaliar to share with you guys my findings... definitely much cheaper than those philips one and it comes with UL/CE approval..... lets see if this works.... if it does...my new home will be using all these LED downlight as well as LED strip......Thank you guys for sharing the info.....hope to hear more soon. Share this post Link to post Share on other sites
boefje 0 Report post Posted September 14, 2011 On 12/20/2010 at 1:40 AM, user123 said: For the benefit of those who want to see how using LED strips instead of normal T5 as cove lighting. Previously I have been searching all over the forum but none can give any help. Just go ahead with the trial and error and it turns out to be too good! Not as bright as T5 but bright enough.The color here is warm white (3000K), LED size: 3528 90LEDs per meter. Uses 2x 12V 2.5A and 2x 12V 5A adaptor.<img src="http://i75.photobucket.com/albums/i289/Ezekiel76/88ed41c0.jpg" border="0" class="linked-image" /><img src="http://i75.photobucket.com/albums/i289/Ezekiel76/689d9169.jpg" border="0" class="linked-image" /><img src="http://i75.photobucket.com/albums/i289/Ezekiel76/2df05f51.jpg" border="0" class="linked-image" />Hi, sorry to dig up this post, but i am actually considering a similar design as yours wit cove light in ceiling fan.Wouldnt it cast ur ceiling fan shadow beneath? or some flickering? Share this post Link to post Share on other sites
Jaschar83 0 Report post Posted September 27, 2011 Hi I am searching for LED lights too. I searched Ebay and found 10m LED strip for $104 including postage. Plus it comes with 2 year warranty and IR remote control which can change color about 15 different colours based on RGB.. Seems pretty awesome and the pics look great. Says that application is for cove lighting, concealed lighting etc.. Was thinking of using for cove lighting and my platform at the edge.. My question is can you cut the LED strip if you do not require the full length? Share this post Link to post Share on other sites
arowana 2 Report post Posted September 28, 2011 yes you can cut the LED if you do not require the full length. You should go to www.dealextreme.com it's cheaper. If you want to use it more for cove lighting, get those that are single color only. The RGB - changing color kind is cute and nice but more for decorative effect, because the color is not truly representative of the actual color. There are also 2 main kinds of LED diodes being sold in the market outside there - 3528smd and 5050smd. 3528smd is a dimmer version and only consumes 0.08W of energy whilst the 5050smd consumes 0.24W/LED.of course more energy consumed, the brighter it would be. Good luck.. Share this post Link to post Share on other sites
centrino2 0 Report post Posted October 2, 2011 Recently I have just bought 15m of waterproof, 60 led/m 5050 LED strip @ ~S$230 online. As I need them at 5 different locations of various length, the supplier helps to cut them into the specific length that I provided from the original roll (note that each roll is 5m). Then they matched the 5 strips each with a remote control (changing of colors and mood) and power supply. Can't wait to have them install by the electrician.... Share this post Link to post Share on other sites
centrino2 0 Report post Posted October 2, 2011 On 9/27/2011 at 4:36 PM, Jaschar83 said: Hi I am searching for LED lights too. I searched Ebay and found 10m LED strip for $104 including postage. Plus it comes with 2 year warranty and IR remote control which can change color about 15 different colours based on RGB.. Seems pretty awesome and the pics look great. Says that application is for cove lighting, concealed lighting etc.. Was thinking of using for cove lighting and my platform at the edge.. My question is can you cut the LED strip if you do not require the full length?The strip that I bought has a cut line every 3 leds apart. The question will be if you know how to re-connect the cut portion for other usage. I don't so I requested the on-line vendor to do for me and they gladly obliged with my request. And I just have to give them all the measurements and they cut the strips and re-connect for me. Share this post Link to post Share on other sites
arowana 2 Report post Posted October 10, 2011 this is how mine looks like..lights are supposed to be ware white color (doesn't show in picture). SMD5050 higher grade (brighter) LED than conventional SMD5050. Each LED is producing about 16Lm/LED, compared to normal 12Lm. I dun have any apparatus to measure but I put both typs of leds side by side and light it up. There's a difference for sure.Total length of the light strips are 30-35m. Share this post Link to post Share on other sites
evo5555 0 Report post Posted October 18, 2011 On 10/2/2011 at 9:11 AM, centrino2 said: The strip that I bought has a cut line every 3 leds apart. The question will be if you know how to re-connect the cut portion for other usage. I don't so I requested the on-line vendor to do for me and they gladly obliged with my request. And I just have to give them all the measurements and they cut the strips and re-connect for me.care to share who do u order the LEDs from? Share this post Link to post Share on other sites
Fastforward 0 Report post Posted November 6, 2011 (edited) On 10/2/2011 at 9:11 AM, centrino2 said: The strip that I bought has a cut line every 3 leds apart. The question will be if you know how to re-connect the cut portion for other usage. I don't so I requested the on-line vendor to do for me and they gladly obliged with my request. And I just have to give them all the measurements and they cut the strips and re-connect for me.Dont mind , can share who u get it from . Thanks Edited November 6, 2011 by Fastforward Share this post Link to post Share on other sites
vynny 0 Report post Posted November 21, 2011 On 10/2/2011 at 12:44 AM, centrino2 said: Recently I have just bought 15m of waterproof, 60 led/m 5050 LED strip @ ~S$230 online. As I need them at 5 different locations of various length, the supplier helps to cut them into the specific length that I provided from the original roll (note that each roll is 5m). Then they matched the 5 strips each with a remote control (changing of colors and mood) and power supply. Can't wait to have them install by the electrician....Hi I am intending to do cove lighting too. was thinking of getting the LED strips too. able to share your online contact? Thanks. Share this post Link to post Share on other sites
terrygerrard 1 Report post Posted November 30, 2011 60 led /m for 5050 is very bright. but is using constant voltage of 12v or 24vdc?the waterproof type is eproxy? sleeve or tube type? Share this post Link to post Share on other sites
danielg 0 Report post Posted December 2, 2011 This is a really relevant topic for what I'm trying to do, and I need some expertise help.I'm planning to run 2 length of 10m LED stips for my living room cove lights. 1 will be for cool white controlled by 1 switch and another for warm white with 2nd switch. However I see most vendors are selling 5m each roll on ebay. I need 10m continuous strips but bend 90 degrees. Can bros who have done this advise whats the best way to join them up? Also I cannot determine the rating of the transformers to get. I understand I need to get a separate transformer for each length. Can someone share what should I get?This is the ebay link for the LED I'm planning to use. This one says 1.2A per meter, so should I get 12A transformer to support 10m?Basically this is what I plan to do:10m warm white 5050SMD 300LED, 1 switch, 1 transformer (rating?)10m cool white 5050SMD 300LED, 1 switch, 1 transformer (rating?)A simple diagram of my design__________| 5m||| 5m| Share this post Link to post Share on other sites
terrygerrard 1 Report post Posted December 5, 2011 On 12/2/2011 at 5:41 PM, danielg said: This is a really relevant topic for what I'm trying to do, and I need some expertise help.I'm planning to run 2 length of 10m LED stips for my living room cove lights. 1 will be for cool white controlled by 1 switch and another for warm white with 2nd switch. However I see most vendors are selling 5m each roll on ebay. I need 10m continuous strips but bend 90 degrees. Can bros who have done this advise whats the best way to join them up? Also I cannot determine the rating of the transformers to get. I understand I need to get a separate transformer for each length. Can someone share what should I get?This is the ebay link for the LED I'm planning to use. This one says 1.2A per meter, so should I get 12A transformer to support 10m?Basically this is what I plan to do:10m warm white 5050SMD 300LED, 1 switch, 1 transformer (rating?)10m cool white 5050SMD 300LED, 1 switch, 1 transformer (rating?)A simple diagram of my design__________| 5m||| 5m|Dear bro,Base from specification this LED ribbon is common found in the market.Led ribbon is running on constant voltage and not constant current.Yr LED ribbon is eproxy?Imagine, per metre is 1.2A and voltage is 12vdc.Back to techincal: Power = Voltage x Currenttherefore Power = 12vdc x 1.2A = 14.4WYr LED height(surface) is 1cm, is not recommend. For better one is 1.2cm.Yr current is very high per metre.for 5 metre is 6A. Yr LED ribbon will get hot faster and surface unable to dissipate heat fast.In the long run, LED will spoil easily.Per metre = 14.4 W5 M = 14.4W x 5m = 72W10M = 144WTo buy power supply, please give some allowance of 20% on top of 144W.Should buy 200W – 12vdc power supply.How to do connection?Method 1:5M---- PS(power supply) ----5M (Dun need to do loop back)Mehod 2:PS(power supply) ----5M ----5M (After which do a loop back to power supply)If u use 24vdc is different story.Power = Voltage x Current14.4W = 24Vdc X CurrentCurrent = 0.6ACurrent is less by half and LED won’t heat up so fast.IMHO: Since you have bought it, just use it. Share this post Link to post Share on other sites
hugobossy 0 Report post Posted December 9, 2011 On 9/1/2011 at 8:04 PM, Edlyn said: Your cove light is nice, why is it that not many consider using LED for downlights tooLooking into LED lights too for my new flat...and really hoping to make my home an environmental friendly one...went sim lim and price there is ok/reasonable at about $20 per meter..and according to shop attendent, it does not generate any heat as it it DC operated..quite impressed and almost going to confirm with them but luckily I did not. Just attended a housewarming ... and saw the LED strip lights used in my friend's place too, they place it below kitchen cabinet and in their master bedroom.... very impressive.......managed to get the contact of the supplier(hurray)...... Spoke to the contractor and understand they have the different types of waterproofing IP code depending on where I am going to place it. Every LED strip needs a power adapter/transformer... and some has RGB type like mood lights. Confused with so many different types.... anyway ask for a quotation and this is what he quoted me and please share if this is reasonable price. 5M LED strip light warm white c/w power supply/ transformer & 3M double side tape but not water proof type $60 5M LED strip RGB c/w power supply, remote controller & 3M double side tape but not waterproof type $90 Not inclusive of installation... cos he said the electrical contractor just need to link the power cable and it will work already... just need to lay the LED strip to where I want and take out the double side tape... sounds easy ya. the LED all running at 12vdc. The warm white ones are 3528 model running 60 LED per meter. He highlighted that there are cheaper ones that run at 30 LED per meter. The led type/size is 3528The rgb ones using 5050 led and c/w 12vdc transformer, IR transmitter for 12 channel(12 different colours) and wireless receiver. It has 60 LED per meter too which means 300LED for 5 meters.DO u think the price is reasonable for the specifications stated? Any advice will be greatly appreciated.Can PM me the LED vendor contact number or email.Thanks Share this post Link to post Share on other sites
rachwen 0 Report post Posted March 25, 2012 Hi,Anybody don mind sharing their contacts with me for the LED strip deal? im intending to DIY my new nest too.Huiwen87@yhaoo.com.sgThanks in advance. Share this post Link to post Share on other sites
