whitefantasy 0 Report post Posted December 2, 2010 (edited) kimsim said: Haha sound like Fan grille have some place is lose out have to use double side tape to fixed the noise. It is same like my current 2hp system 1 outdoor units. Because my compressor rubber a bit lose so the vibration will Very strong to impact the metal body with the fixed fan speed very hot and heat to blow out the fan and make the fan grills become very noisy. Fan grille? Do you mean inside the condenser unit? So need to open up to check up the unit to check? How about the 2 videos on the sound which was generating everyday? Could it be manufacturer defects so that's why more noisy? Edited December 2, 2010 by whitefantasy Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 2, 2010 whitefantasy said: Fan grille? Do you mean inside the condenser unit? So need to open up to check up the unit to check? How about the 2 videos on the sound which was generating everyday? Could it be manufacturer defects so that's why more noisy? Ya is manufacturer defects. Nope I mean you looks at in front compressor for fan blow out the grilles, It used pastic frame cover grilles, looks like net type that once make noise. Pastic cover gap to metal body frame and runing vibration will become noisy, Only can solve is use double side tape to paste at metal and pastic frame grills to be more fixed. It is will be no big gap and reduce the noise. Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 2, 2010 kimsim said: Ya is manufacturer defects. Nope I mean you looks at in front compressor for fan blow out the grilles, It used pastic frame cover grilles, looks like net type that once make noise. Pastic cover gap to metal body frame and runing vibration will become noisy, Only can solve is use double side tape to paste at metal and pastic frame grills to be more fixed. It is will be no big gap and reduce the noise. Sorry it is very dangerous work better ask panasonic service man to do. If the outdoor unit is install face outside the window. Some have Aircon leg maybe you still do by you own. Keep becareful. Share this post Link to post Share on other sites
whitefantasy 0 Report post Posted December 2, 2010 kimsim said: Sorry it is very dangerous work better ask panasonic service man to do. If the outdoor unit is install face outside the window. Some have Aircon leg maybe you still do by you own. Keep becareful. Yah ours was hanging bracket type not those with a small balcony. But i a bit confused of what you are trying to say. The compressor is like the link attached. http://www.coolserve.com.sg/htmdocs/produc...ils.asp?id=3051 Do you mean the grille got manufacturer defects that's why causing the unit to be noisy everyday while in operation? Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 2, 2010 whitefantasy said: Yah ours was hanging bracket type not those with a small balcony. But i a bit confused of what you are trying to say. The compressor is like the link attached. http://www.coolserve.com.sg/htmdocs/produc...ils.asp?id=3051 Do you mean the grille got manufacturer defects that's why causing the unit to be noisy everyday while in operation? Yes it is grille will be defects the noise when compressors before 15min to stop running it is have a very strong vibrations, Because just only the plastic frame it Is very lightweight is not the previous national model all are using metal grille. To compared metal frame more solid without noisy when the fan motors are running and getting heat to blow out fan. Share this post Link to post Share on other sites
whitefantasy 0 Report post Posted December 3, 2010 kimsim said: Yes it is grille will be defects the noise when compressors before 15min to stop running it is have a very strong vibrations, Because just only the plastic frame it Is very lightweight is not the previous national model all are using metal grille. To compared metal frame more solid without noisy when the fan motors are running and getting heat to blow out fan. Ok i will feedback to Panasonic & see what they say. Thank you. Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 3, 2010 whitefantasy said: Ok i will feedback to Panasonic & see what they say. Thank you. Maybe can request to replace whole out door units. It is quite new the sound like using 5-8 years for compressor runing. Share this post Link to post Share on other sites
whitefantasy 0 Report post Posted December 3, 2010 kimsim said: Maybe can request to replace whole out door units. It is quite new the sound like using 5-8 years for compressor runing. When they come that day they say it is not compressor faulty lor? Maybe i got to keep complaining? So you think new condenser unit operating does not sound that way? Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 3, 2010 whitefantasy said: When they come that day they say it is not compressor faulty lor? Maybe i got to keep complaining? So you think new condenser unit operating does not sound that way? Yap should be keep complain, Your main point for compressor strong vibration to make you can't sleep as well please change for new one unit. End out They should do for you. Share this post Link to post Share on other sites
whitefantasy 0 Report post Posted December 3, 2010 Is there no other user who got the same complains like me? Pls try to feedback if any panasonic technicians manage to solve the problems? Or i really suay & get a manufacturer defect unit? Share this post Link to post Share on other sites
whitefantasy 0 Report post Posted December 3, 2010 kimsim said: Yap should be keep complain, Your main point for compressor strong vibration to make you can't sleep as well please change for new one unit. End out They should do for you. Actually not so easy & if they keep insisting there is nothing wrong with unit, they will not change new for us. Really don't know how to explain to them the stressed i am facing with the irritating sound & they don't seem to undestand. Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 3, 2010 whitefantasy said: Actually not so easy & if they keep insisting there is nothing wrong with unit, they will not change new for us. Really don't know how to explain to them the stressed i am facing with the irritating sound & they don't seem to undestand. Ya loh, since it install n used for 3 months already. But it is new wow for outdoor unit quite tall and big for fan dB also very quite. Only can resolve is relocated your bed frame don't face the compressor area. It is will be help you as much. Because your bad facing now is same as my previous Aircon fir every night. Can't sleep as well suddenly wake up n hear the noisy. Can said the vibration until my wall also hear the whining humming sound. Normal has been used at 5-8 years the problem is same. So I change to inverter unit, I can said totally sovle no more facing the noisy sound again. Share this post Link to post Share on other sites
whitefantasy 0 Report post Posted December 3, 2010 (edited) kimsim said: Ya loh, since it install n used for 3 months already. But it is new wow for outdoor unit quite tall and big for fan dB also very quite. Only can resolve is relocated your bed frame don't face the compressor area. It is will be help you as much. Because your bad facing now is same as my previous Aircon fir every night. Can't sleep as well suddenly wake up n hear the noisy. Can said the vibration until my wall also hear the whining humming sound. Normal has been used at 5-8 years the problem is same. So I change to inverter unit, I can said totally sovle no more facing the noisy sound again. In fact my previous carrier brand abt 5 year plus not noisy at all. Even i relocated my bed also no use b'cos the whole room will be echo with the noise no matter which part of it coz my masterbedroom is concealed. Edited December 3, 2010 by whitefantasy Share this post Link to post Share on other sites
edenstrauss 3 Report post Posted December 3, 2010 (edited) My Fujitsu was silent many years ago when it was newly installed but after I started turning it on recently, it does have noise, probably coming from the huge blade fan. I was told that it requires servicing. Is that true? And will that get rid of the noise? It's more than 10 yrs already. Edited December 3, 2010 by edenstrauss Share this post Link to post Share on other sites
kimsim 8 Report post Posted December 3, 2010 (edited) edenstrauss said: My Fujitsu was silent many years ago when it was newly installed but after I started turning it on recently, it does have noise, probably coming from the huge blade fan. I was told that it requires servicing. Is that true? And will that get rid of the noise? It's more than 10 yrs already. Can be solve the problem easily. Can change fan motors or fan bearing. Depend how you like to pay for service。 Edited December 3, 2010 by kimsim Share this post Link to post Share on other sites
