mosquitobitten 0 Report post Posted November 29, 2010 I am trying to install a simple ikea ceiling light fixture but am confused by the wiring. I need to use 2 of the wires, but which two? And what do I do with the third? HUDC: 25 years old Share this post Link to post Share on other sites
neubie 2 Report post Posted November 29, 2010 I am trying to install a simple ikea ceiling light fixture but am confused by the wiring. I need to use 2 of the wires, but which two? And what do I do with the third? HUDC: 25 years old usually lights use the Live (brown) and Neutral (blue) wires. The earth (yellow-green) wire can be left unconnected, but if can, connect to the metal chassis of the fixture. Share this post Link to post Share on other sites
mosquitobitten 0 Report post Posted November 30, 2010 usually lights use the Live (brown) and Neutral (blue) wires. The earth (yellow-green) wire can be left unconnected, but if can, connect to the metal chassis of the fixture. my colours are 2 green, 2 yellow and black. Share this post Link to post Share on other sites
neubie 2 Report post Posted November 30, 2010 my colours are 2 green, 2 yellow and black. if that case, get a LEW/electrician to verify ur connections, since it does not appear to conform to current standards. Share this post Link to post Share on other sites
Brandon Xue 0 Report post Posted December 3, 2010 (edited) my colours are 2 green, 2 yellow and black. Yellow = Live Black = Neutral Green = Earth You see 2 of each wires is perhaps due to daisy chain. 1 set of cable is incoming (1 green, 1 yellow + 1 black) from main or elsewhere, while the other set of cable is tap to another place. Just hook up your Ikea light cable to the 2 sets of cable together and it should work. Edited December 3, 2010 by northguysg Share this post Link to post Share on other sites
