mosquitobitten
How To Install An Ikea Ceiling Light On Hdb Wires?
I am trying to install a simple ikea ceiling light fixture but am confused by the wiring. I need to use 2 of the wires, but which two? And what do I do with the third?
HUDC: 25 years old
usually lights use the Live (brown) and Neutral (blue) wires. The earth (yellow-green) wire can be left unconnected, but if can, connect to the metal chassis of the fixture.
my colours are 2 green, 2 yellow and black.
if that case, get a LEW/electrician to verify ur connections, since it does not appear to conform to current standards.
Yellow = Live
Black = Neutral
Green = Earth
You see 2 of each wires is perhaps due to daisy chain. 1 set of cable is incoming (1 green, 1 yellow + 1 black) from main or elsewhere, while the other set of cable is tap to another place.
Just hook up your Ikea light cable to the 2 sets of cable together and it should work.
Edited by northguysg
